  1. Jul 21, 2025 at 12:12 PM
    Back when all of the motorcycles and outboard motors on boats were 2 smokes, we used to keep a box full of extra plugs handy. Swap a fouled plug out, then we would clean the fouled plug up with gas, emery cloth, cigarette lighter etc. as needed and put it back in the box for later.
  2. Jul 21, 2025 at 12:20 PM
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
    Yup, used to be totally normal to carry a couple spare sets of plugs under the seat of your motorcycle, especially if you were trying to tune your carbs. I don't enjoy doing valve jobs, but I'll still take that over how much of a pain in the ass 2 strokes could be.
  3. Jul 21, 2025 at 12:37 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Ok that's good info. I didn't realize how quick a plug could get fouled up like that. That's what sort of had me scratching my head. I guess in my head I've always imagined it taking a long time to get oily and fouled up. But this happened during the course of one cut (a huge cut, to be fair). Makes me think I ought to order a 5 pack of plugs since we are running the saw so hard.
    Milling is just brutal on these saws. It's wide open throttle with 22" of the bar buried in red oak for 4 or 5 minutes straight. We went thru an entire tank of gas with one cut we did.
  4. Jul 21, 2025 at 2:35 PM
    shifty` Oh, I have felt Cobain's sarcoma
    I typically try to change my 2 stroke equipment plugs after about 40-50 run hours. That's probably excessive, but whatever. At this point I'm 4 stroke on everything except my chainsaw, and I'm typically using the electric one if there's an outlet anywhere nearby.
  5. Jul 21, 2025 at 3:31 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    I love my 2-stroke Stihl saw, but I'm like you; unless I'm going to be working the saw all day or all weekend, I'm grabbing my Ryobi 40V chainsaw every time.
  6. Jul 21, 2025 at 3:41 PM
    Redoak
    Redoak New Member
    Dave
    2006 Toyota Tundra DC, Limited 4x4, with LSD
    none
    Do the 4wd 2006 tundras have more height/ground than the 2wd?
    Can't see any sign of lift on mine, buts its couple inches taller at top of bed than a coworkers '06 2wd.
  7. Jul 21, 2025 at 4:03 PM
    TRD, or no? They share suspensions otherwise. Tire sizes could differ between the two creating some disparity. TRDs have a different front coil, but share the rest. Not sure the coil added much if any lift compared to the regular coil. You positive both trucks are stock?
  8. Jul 21, 2025 at 4:09 PM
    Elam.Pingleton
    Elam.Pingleton 1st Gen 04 2WD V-8 DC
    Elam
    Nashville Area
    2004 Tundra DC Limited
    Pulled the trigger on the parts
    bmf4069, Dakillacore and shifty` like this.
  9. Jul 21, 2025 at 4:21 PM
    That reminds me, I need to get new radiator hoses and I think a driver a/f sensor. I gotta remember this next time a sale happens.
    Dakillacore likes this.
  10. Jul 21, 2025 at 4:29 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    I use a 4 stroke on a bandsaw for milling. When I have had problems with my Husqvarnas, I just buy a new carb if I feel I have fuel related issues. When ya mill with a chainsaw, watch the heat. It's easy to cook the bearing seal on the clutch side. This leads to a lean condition that will cause the piston to smear inside the cylinder and a loss of compression.
    shifty` likes this.
  11. Jul 21, 2025 at 4:38 PM
    Redoak
    Redoak New Member
    Dave
    none
    Mine is limited his is SR5.
  12. Jul 21, 2025 at 6:03 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Interesting. I may look down that route if new spark plug doesn’t fix it.
  13. Jul 22, 2025 at 3:02 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Is you buddies also a DC? The DC is taller, wider and longer than AC and RC. Oddly enough the DC sr5 coils are 0.5" shorter than the AC sr5 coils, though.
    Also worth mentioning the stock DC geometry (UCAs), according to Bilstein, can handle a little more lift than the AC/RC.
    Then when talking about the rear, this is according to Archive Garage:
    DC has a 1" higher frame bumpstop bracket which allows 1" more bump travel than AC, but also limits collapsed length of shock
  14. Jul 22, 2025 at 8:53 AM
    Kalannar97
    Kalannar97 New Member
    Michael
    Hillsboro, TN
    2003 Red Tundra SR5 2wd AC V-8 LSD ABS
    New Frame (Recall in 2019), added 17" 4-Runner Snowflake Rims
    I don't know which designation is for which motor. But here is a listing for a supercharger near me.
    455h0le_dachshund likes this.
  15. Jul 22, 2025 at 9:08 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    That's for a 4 cylinder Previa van. Those were pretty sweet. AWD and 5 speed
    Kalannar97[QUOTED] likes this.
  16. Jul 22, 2025 at 9:51 AM
    Kalannar97
    Michael
    Hillsboro, TN
    I had no clue. Just saw it pop up and knew people on here were looking for superchargers for our trucks. Figured I would pass along just in case while on my lunch break. I get random stuff showing up on my FB marketplace since I started looking for a cover for the truck bed. People put them under some weird category titles other than auto parts.
  17. Jul 22, 2025 at 10:06 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Yall see all that shit Joe Hoe is catching right now LOL. People are coming out of the woodworks on Facebook.
  18. Jul 22, 2025 at 10:07 AM
  19. Jul 22, 2025 at 10:29 AM
    Dakillacore
    Georgia
    Yeah same, I have no idea who that is or the situation.
  20. Jul 22, 2025 at 11:05 AM
    This is that clown JoeJoe from Facebook that sells OEM parts at prices people seem happy with, though they're higher than Serra of Birmingham after shipping?
    FFS, that list of charges on the lower half of your shot. What in the actual hell? All that shit is from 2018 also, so the cases have probably been settled by now, even if he had a killer lawyer to drag it out.
    I always knew something wasn't right with that dude...
  21. Jul 22, 2025 at 11:11 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I've got a used centrifugal supercharger kit for our trucks (paperwork says kit works for VVTI and non-VVTI 4.7L) that I haven't decided if I'm going to use on my 2003 or not. Truth be told I'd rather sell it and save up for a roots style blower and air to water intercooler, like the Bullet kit. I might throw it up for sale some day. Only paid $1200 for the whole kit.
  22. Jul 22, 2025 at 11:13 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Is that the Joe Joe clown from FB?
    khooiii[QUOTED] likes this.
  23. Jul 22, 2025 at 11:20 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    $601. J/k if i swap to e85, i could easily use a little boost.
  24. Jul 22, 2025 at 11:21 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You're the only one I'd even consider that price on, because I know you have and probably would continue to earn the other half.
  25. Jul 22, 2025 at 11:24 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Was talking to my buddy duncan about it. I need it tuned to the amount of torque an a/c clutch could handle. I wouldnt wanna drive it all the time, but i could turn it on when i need it. Even 2-3psi would help.
  26. Jul 22, 2025 at 11:31 AM
    Centrifugal>Roots. Do it. DO IT.
  27. Jul 22, 2025 at 11:35 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You do it. :p
    Dakillacore and bmf4069[QUOTED] like this.
  28. Jul 22, 2025 at 11:36 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    It's got a clutch, engages the pulley at 1200rpm, does 5psi. Anyone running boost on the A340 should consider a shift kit though. Even boosted 5vz's have been known to tear up stock A340's. Of course I don't believe the 5vz Tacomas came with trans coolers unless you got the factory tow package.
  29. Jul 22, 2025 at 11:49 AM
    I've already got a S/C car. You need to put it on race truck! I used to have hangups about centrifugals before I drove with one. Now, that roots whine is nice, but banging gears and hearing that blow off valve is the cats meow.
  30. Jul 22, 2025 at 11:52 AM
    Redoak
    Redoak New Member
    Dave
    none
    his is same year, double cab. Mines limited and definitely taller than his sr5.
    Mine also has more rake, whereas his is closer to being level with stock suspension.
    I’ll try to take some pictures of my suspension later and post see if others more familiar with Toyota stock suspension can tell me if mine has been modified.
