Howdy! Come watch me polish a turd.
Discussion in '1st Gen Tundras (2000-2006)' started by Nimitz_, May 30, 2025.
  1. Jul 13, 2025 at 6:43 PM
    #121
    Hey man, if it works, it works!
    Nimitz_[OP] likes this.
  2. Jul 18, 2025 at 1:00 PM
    #122
    Nimitz_
    Nimitz_ [OP] LA face with an Oakland booty
    Sam
    Seattle-ish
    06 DC LTD 4X4 4.7 V8
    Finally ran the missing ground, cleaned up the battery mount and put on new terminals. Fair amount of surface rust under the battery tray so I hit that with a wire brush and some rustolium. Still missing my hold down, but my 4th of July shipment from Serra finally shipped yesterday so it’s just a matter of days.
    Also swapped back in the busted ass seat that came with the truck, I started getting an airbag light and didn’t want to eff with swapping seat belts and wiring harnesses.
    Not bad for an hour of work.
  3. Jul 18, 2025 at 1:04 PM
    #123
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    You can take the positive loom loose at the clip under the battery tray (10mm) and slide the clip further down the loom to get more cable and turn that positive terminal 90 degrees to match the negative, if you so choose.
    bmf4069 and Nimitz_[QUOTED][OP] like this.
  4. Jul 18, 2025 at 1:07 PM
    #124
    Nimitz_
    Sam
    Seattle-ish
    Still have high oil pressure and idle but the gas gauge dropped another 1/8th of a tank which seems more accurate based on how much I’ve driven it.
    Speedo is still effed tho. I’m sitting still in this picture.
    Also saw a member has a truck named crackie so I’m thinking about naming her “Methanie”
  5. Jul 18, 2025 at 1:07 PM
    #125
    Nimitz_
    Sam
    Seattle-ish
    You’re a beautiful man.
  6. Jul 18, 2025 at 1:11 PM
    #126
    Tweek, like the character from South Park.
  7. Jul 18, 2025 at 1:13 PM
    #127
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I like it. @Tundra2 will be proud
  8. Jul 18, 2025 at 2:31 PM
    #128
    High? The hell? Are you high?
    For the '05-'06 all gauges (temp, oil, battery) should be at half-mast. Don't confuse it with the '00-'04 which use a totally different cluster. Your gauges are right where I'd want to see them.
    Nimitz_[QUOTED][OP] likes this.
  9. Jul 18, 2025 at 3:01 PM
    #129
    Nimitz_
    Sam
    Seattle-ish
    oh thank you. I was kind of worried about that because I had a bunch of junk in my oil and I thought I had a blocked pick up tube or something. I thought all the first gins had low oil pressure relatively
  10. Jul 18, 2025 at 4:00 PM
    #130
    IMO, if your pickup tube was truly blocked, I'd actually expect for you to both hear knocking when you step on the gas (knocking sounds like deisel engine "clonking" when you shut a diesel down, if you're unfamiliar), and your knock sensors (one per bank, between the starter and SAI pump) to be throwing knock codes. And I personally believe it would be highly unusual for it to just be a single knock sensor on one bank but not the other, knocking only on one hemisphere would be wierd, I know it can happen, but it would take unique scenarios to get there.
    But yeah. I think it's covered in the owner's manual, but in case it's not, on the newer Tundra gauge cluster that started in '05 and continued thru '06, all needles (except gas) should be roughly at middle, and that's normal range (+/- ~5%). Toyota fixed this in 2005. I think the gauges on '00-'04 were a serious mistake, and I find them virtually unreadable and illogical.
  11. Jul 19, 2025 at 11:24 AM
    #131
    bmf4069 Captain wtf
    It's still low pressure, the guage just displays it different.
  12. Jul 19, 2025 at 2:28 PM
    #132
    Nimitz_
    Sam
    Seattle-ish
    Stop, you’re going to make me have an existential crisis
    bmf4069[QUOTED] likes this.
  13. Jul 19, 2025 at 2:30 PM
    #133
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  14. Jul 19, 2025 at 2:31 PM
    #134
    bmf4069 Captain wtf
    Shit, welcome to the club. I think I'm on my 4th at this point.
  15. Jul 19, 2025 at 2:48 PM
    #135
    Nimitz_
    Sam
    Seattle-ish
    But is it still low is the gauge says it’s not or is it the same as the earlier models, which isn’t low, the gauge just says it is?
  16. Jul 19, 2025 at 3:20 PM
    #136
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Yes
    BroHon and Nimitz_[QUOTED][OP] like this.
  17. Jul 19, 2025 at 3:32 PM
    #137
    For '06 you're sitting about the same pressure mine sits at.
  18. Jul 21, 2025 at 12:35 PM
    #138
    Nimitz_
    Sam
    Seattle-ish
    The fun never ends, boys.
    FrenchToasty and Jack McCarthy like this.
  19. Jul 21, 2025 at 2:29 PM
    #139
    You didn't torque it to spec, or did it somehow spin itself off? Hey, there's a lot of action out back, if it fell off while driving, consider yourself lucky. A lot worse could've happened.
  20. Jul 21, 2025 at 2:31 PM
    #140
    The real fun is when it seizes in the bushing and you need to use a cut-off wheel to get it out. Don’t ask me how I know. :anonymous:
    bmf4069 likes this.
  21. Jul 21, 2025 at 3:05 PM
    #141
    Nimitz_
    Sam
    Seattle-ish
    Negative, the PO apparently used a dirty look to tighten the bolt and it’s been rattling around in the mount for god knows how long and is wallowed out.
    Oh and the other side is totally seized and the nut is up against the leaf mount so I am likely going to have to cut it off.
    Fobroader and BroHon like this.
  22. Jul 21, 2025 at 3:06 PM
    #142
    Nimitz_
    Sam
    Seattle-ish
    Got the passenger side shock replaced, letting the drivers side marinate in the futile hope I can bust that nut loose.
  23. Jul 21, 2025 at 3:45 PM
    #143
    BroHon
    BroHon What day is it?
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    Tape off the threads, fill it with JBweld, crank it down. That's what P.O.s do to us, let the next guy pay some dues...
    Sort of joking, sort of not... :rofl:
    Fragman likes this.
  24. Jul 21, 2025 at 3:59 PM
    #144
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    Fobroader likes this.
  25. Jul 21, 2025 at 4:05 PM
    #145
    badass03taco
    My 05 shows oil pressure about half way (50%) when i crank it but falls down to about quarter (25%) when idle and driving normally.
    I have wondered if its the piston squirters, i believe they are open and squirting all the time so its hard to build higher oil pressure.
    I noticed on the 3UZ and V35A have a pressure regulator on the piston squirter system, there is a small spring loaded ball valve that wont allow oil to the squirters until the engine builds at least 20+psi of oil pressure. This keeps the squirters from working at idle and any time there is lower oil pressure. Since i have not seen any indication that the 05-07 2UZ-FE has a pressure regulator on the piston squirter system i have wondered if my "lower" pressures on the gauge are due to the piston squirters at idle reducing the overall pressure in the entire system.
  26. Jul 21, 2025 at 4:07 PM
    #146
    badass03taco
    Hwat?
  27. Jul 21, 2025 at 4:10 PM
    #147
    badass03taco
    When this happens in offroad A-arm and shock assemblies, most people put the bolt thru the tabs and weld a thick washer over the tab. This will allow you to have a new hole to keep the bolt centered without having to cut that tab off and fab a new one.
    Honestly you could just put a backup washer on it and crank the bolt down. Friction from a stiff washer against the tab will keep the lower shock eye from wobbling around like it was.
    Jack McCarthy likes this.
  28. Jul 21, 2025 at 4:37 PM
    #148
    Nimitz_
    Sam
    Seattle-ish
    Thats basically what I’m going to do once I unfuck this thing enough to actually drive it. Right now I gave it a bunch of ugga duggas and it seems to be more or less centered in the mount
  29. Jul 21, 2025 at 5:17 PM
    #149
    Nimitz_
    Sam
    Seattle-ish
    Also,
  30. Jul 21, 2025 at 7:36 PM
    #150
    Nimitz_
    Sam
    Seattle-ish
    Got first crack at a wrecked 2005 DC down in Portland. Heading down at the ass crack of dawn to strip that bad boy. The list so far:
    • Battery tie down
    • Tailgate
    • Black interior trim pieces
    • All interior seats
    • Drivers door control panel
    • Trans cooler
    • Secondary Hood release
    • Cat back exhaust
    • Front coils
    • Rear axle?
    • UCAs
    • Hitch
    • Entire drivers front brake line
    • Load proportioning valve
    • Headlight bolts
    • Factory jack, manual, FA kit
    • Parking brake lines
    • Spare?
