  1. Jul 21, 2025 at 6:57 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    4.88 with wavetrac LSD. Installed by Premier West Gears in Riverside, CA.
  2. Jul 21, 2025 at 7:01 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Thats where i went for my regearing as well. Also got a rear e-locker installed by them as well.
  3. Jul 21, 2025 at 8:30 AM
    Just wait till you have to do the uppers.
  4. Jul 21, 2025 at 8:32 AM
    Honestly, with the press kit and my big impact, the uppers went pretty smooth for me with the spindles off the truck.
  5. Jul 21, 2025 at 8:33 AM
  6. Jul 21, 2025 at 8:37 AM
    I couldn't get the upper to pop off. I dented my UCA beating it.
    Filthyphil and oscardog86 like this.
  7. Jul 21, 2025 at 9:15 AM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    I rented (deposit, which you get back, so it's free?) from O'Rielly's but I wasn't impressed. Bought a front end service kit from OTC at Zoro.com.
    Buggered up an outer tie rod's threads with the kit but ended up replacing outer tie rods anyway. I had used the pulled suggested in a video but another in the kit did the job without damage. Lesson learned for 90K miles from now.
  8. Jul 21, 2025 at 9:31 AM
    Filled er up this weekend. I know it's not much, but the last time I filled up was in May or so, right after getting back from T2S. Weren't y'all talking about tank size earlier? This turned out to be 11.33 mpg on this tank, not accounting for the 33s.
  9. Jul 21, 2025 at 10:57 AM
    shifty` Un‐Reborn Again
    Yup, I filled up yesterday too. Man, I miss all those road trips up to Helen GA in May/June timeframe. This last tank was 100% city driving, kid-caddying.
  10. Jul 21, 2025 at 10:59 AM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    A couple milestones(no pun,but I guess it works) this week on both my vehicles.
    2012 Altima 1st pic
    2002 Tundra 2nd pic
  11. Jul 21, 2025 at 11:13 AM
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    Outside of PDX OR
    2003 SR5 V8 AC TRD 4x4
    Passenger side is done.
    The one I bought and destroyed yesterday was the same one they rented out. To get the other side finished I ordered a cheapish/better than parts store front end service kit and a good set of pickle forks. If this was something that I had to deal with more than every 100K miles, I'd look into getting the proper high end stuff. Maybe when it comes time to swap out my shocks and springs.
    My biggest problem is that I'm already having to build out a second full tool box setup because I don't have any room for all my motorcycle suspension tools and random stuff that only gets used every few years.
    Here's the finished job from yesterday. I was gonna add grease to the tie rod fitting, but couldn't find my grease gun until I had put everything away. Deal with it when I do the other side. It's been raining today and that's my excuse for not working on it today, not the fact that my back is killing me and I'm feeling my age.
  12. Jul 21, 2025 at 11:13 AM
    MooreKen
    MooreKen New Member
    Ken
    1GT RC V8/2WD
    Minor upgrade but needed. Wasn’t getting any codes, but noticed there was zero resistance to removing the cap when fueling. The new cap feels good…kinda like it’s spring loaded or something. My concern was fuel evaporating in this scorching heat. I did Order from Scamazon…. The seller was Toyota Parts of North Miami. I just placed another order with them for 2 x 4litre cans of ATF -WS fluid. My dealership said that the p/n had been discontinued. IMG_2305.jpg
  13. Jul 21, 2025 at 11:18 AM
    Upshot Knothole
    Thatchery
    Outside of PDX OR
    I need to replace mine. I keep getting a minor evap system leak code that I suspect is from the gas cap. I asked the last time I was at the dealership if they had it and the part number came right up, but they didn't have it in stock.
    MooreKen[QUOTED] likes this.
  14. Jul 21, 2025 at 11:23 AM
    MooreKen
    MooreKen New Member
    Ken
    1GT RC V8/2WD
    As with all things Toyota I hang on to all my original parts just in case.
  15. Jul 21, 2025 at 11:24 AM
    Note that 2003-2004 trucks are part of the fuel filler neck TSB. If "what the fuck are you talking about, shifty`?" is the first thing that went through your head, go search the first page of the megathread for 'FILLER'.
  16. Jul 21, 2025 at 11:29 AM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Upshot,
    Did you re-use the LBJ bolts or replace with new?
    Advice on this site is to buy new bolts.
    I did mine lying on my back, in the yard. I would not do this job again without power tools.
    Ignore the one bolt too far out....I had torqued to spec but was still a bit out. I asked on here but consensus was it was a bit rusty up in there. I got it all the way in with a breaker bar.
  17. Jul 21, 2025 at 11:31 AM
    Upshot Knothole
    Thatchery
    Outside of PDX OR
    Just ordered one from a dealership on Amazon. I checked Ourisman first, but the shipping was more than the discount.
    G_unit3000 and MooreKen[QUOTED] like this.
  18. Jul 21, 2025 at 11:32 AM
    Upshot Knothole
    Thatchery
    Outside of PDX OR
    New bolts, properly torqued, with blue loctite.
  19. Jul 21, 2025 at 11:33 AM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Good. Same as me. :)
  20. Jul 21, 2025 at 11:35 AM
    MooreKen
    MooreKen New Member
    Ken
    1GT RC V8/2WD
    Btw…any of you guys that have the newer trucks that use ATF-WS, this is a pretty good price.IMG_0870.png
  21. Jul 21, 2025 at 11:41 AM
    Upshot Knothole
    Thatchery
    Outside of PDX OR
    I'll check closer after I replace the fuel cap if I keep getting the code. Mine needs replacing anyway because the tether broke ages ago and the cap itself is feeling pretty tired. Guessing it's the stock 22 year old fuel cap. And I did look and my vin is part of the TSB.
  22. Jul 21, 2025 at 12:02 PM
    Smoke test should (hopefully quickly) reveal if the neck is cracked, although it didn't seem to work great for at least one person, it has worked for others. There are modified caps/plugs to pop onto the tank that will seal it for you to pipe smoke in.
  23. Jul 21, 2025 at 12:10 PM
    EyeSpyA1stGenTundra
    EyeSpyA1stGenTundra New Member
    Eric
    Looking for my future 1st Gen Tundra
    Are you taking care of these properties? Just helping where you can? Is this your business? Maintenance stuff?
  24. Jul 21, 2025 at 12:19 PM
    EyeSpyA1stGenTundra
    Eric
    Did this in our Sienna ion spring getting our garden ready....as soon as I filled the van, I said this is why we need a 1GT truck for this kind of shi* (looks at wife, wife rolls eyes)
  25. Jul 21, 2025 at 12:29 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    BroHon and EyeSpyA1stGenTundra like this.
  26. Jul 21, 2025 at 12:31 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    That probably explains why my 03 sometimes acts stupid AF when I'm trying to fillup
  27. Jul 21, 2025 at 12:37 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Wife and I do odd jobs yes, but this is for a friend. If it wasn't for us, he couldn't afford to get it done. He intends to sell this once we get it cleaned out and the rest of the trees and brush cut down and removed.
    Why?
  28. Jul 21, 2025 at 12:47 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    When swapping the cap also checked for corrosion on the mating surface and decided to plug the neck and smooth it out.
  29. Jul 21, 2025 at 4:39 PM
    Azblue
    The Dirty T ( ^_^)_且
    It appears that you haven't cleaned it since T2S either.
  30. Jul 21, 2025 at 4:58 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Heck yeah nice man way to knock it out.
