Water leaking in dripping out of body
Discussion in '2.5 Gen Tundras (2014-2021)' started by W27, Jul 19, 2025.
  1. Jul 19, 2025 at 6:24 PM
    W27
    W27 [OP] New Member
    The last few days I’ve noticed odd wet spots as I come out to my truck. I finally got a chance to try to track it down. The water appears to be coming in through the rear passenger door. It’s seeping out of the body of the truck.
    I know it’s normal for a certain amount of water to leak into the door. Do I have a drain blocked somewhere or which weather seals do I need to replace? Nothing seemed out of place. I appreciate any input. See pictures below
  2. Jul 20, 2025 at 2:38 AM
    W27
    W27 [OP] New Member
    I’m an idiot. I was at work when I posted that. It made no sense where the fluid was coming from. I had a new pint of brake fluid in the door that developed a hole and started leaking. Hoping it doesn’t destroy the paint and cause me rust issues. ‍♂️
    NewImprovedRon and woods like this.
  3. Jul 20, 2025 at 5:00 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Glad you got it tracked down. I was going to say that I would suspect rain running down the small void where the door opens, runs down until it hits the bottom, and then runs out. But, I like your answer better! :thumbsup:
    W27[QUOTED][OP] likes this.
  4. Jul 20, 2025 at 5:55 AM
    bfunke
    bfunke Tundra Curmudgeon
    Wash off the BF ASAP. It will cause your paint to bubble up and come off.
    W27[OP] likes this.
  5. Jul 20, 2025 at 8:49 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    That sucks, use dawn dish soap to wash it off and if you want to help protect from corrosion this stuff is great.
    W27[OP] likes this.
