Any way to restore clarity to this convex mini mirror?
Discussion in '1st Gen Tundras (2000-2006)' started by StrawberryBlowpopPrincess, Jul 11, 2025.
  1. Jul 11, 2025 at 12:10 PM
    StrawberryBlowpopPrincess [OP] New Member
    2002 sequoia RWD
    As you can see in the picture, the mini mirror that helps so much (when merging left) has started to fade pretty bad over the past years. Besides replacing it I was wondering if anyone had any tips on restoring it? Thanks
    Jack McCarthy likes this.
  2. Jul 11, 2025 at 12:12 PM
    I would just buy a new one. Do they still make them in that shape?
  3. Jul 11, 2025 at 12:13 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Here are some methods to restore mirror glass:
    • Rub the mirror with toothpaste. The abrasive ingredients in toothpaste can occasionally polish out scratches.
    • Use traditional toothpaste instead of a gel.
    • Apply a jewelry-polishing compound (cerium oxide). This ingredient is sometimes effective in restoring a mirror’s shine.
    • Make a mixture of water and baking soda and apply the paste to the affected areas of the mirror or glass. Leave it there for about half an hour and then wipe it clean using a wet towel and rinse thoroughly.
    • Use a standard windshield repair kit from your local auto supply store.
    • Clean the glass with a soft cloth and an acidic cleanser. Refrain from touching the glass with your bare hands. Apply your chemical mixture provided in the kit.
    NewImprovedRon likes this.
  4. Jul 11, 2025 at 1:01 PM
    shifty` Oh, I have felt Cobain's sarcoma
    If a heavy-cutting buffing compound won't do it, nothing will...
  5. Jul 11, 2025 at 1:26 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    You could try meguires scratch x if its a plastic surface (most likely is).
  6. Jul 13, 2025 at 4:45 AM
    2002 sequoia RWD
    Well I do know the individual ones you can buy in Walmart are TERRIBLE, and do nothing but take up space. (I put one on my other mirror and you can’t see diddly squat from it)
    This one in the picture is factory & fantastic!
  7. Jul 13, 2025 at 4:52 AM
    2mchfun
    I like to use the 3" round. After you adapt to them, they become your primary mirrors.
  8. Jul 19, 2025 at 11:17 AM
    2002 sequoia RWD
    Do you have a picture of these?
  9. Jul 19, 2025 at 11:24 AM
    Retired...finally
    I'm guessing it's corrosion of the reflective coating and no amount of buffing of polishing will fix that.
  10. Jul 19, 2025 at 11:37 AM
    2002 sequoia RWD
    Bummer. Is that an aftermarket part? Before it faded it worked so well, I was always under the impression it was original to the truck? (Sequoia)
  11. Jul 19, 2025 at 12:06 PM
    Retired...finally
    For some reason I'm not able to post a link. search Amazon for 2pcs fan shaped blind spot mirror.
  12. Jul 19, 2025 at 12:08 PM
    2mchfun
