Car Care Nut head gasket warning
Discussion in '2.5 Gen Tundras (2014-2021)' started by ejes, Sep 7, 2024.
  1. Sep 27, 2024 at 5:49 AM
    #151
    grayscale
    grayscale New Member
    DFW
    2013 Tundra CM TSS 4X4 5.7FFV
    Interestingly long conversation on coolant change, but I tend to worry more about its ability to not freeze. One bad winter and you could be screwed far worse. I change mine every couple of winters, I've seen the floating balls do silly things with coolant that was only a year or two old. Freeze plugs are not a reliable/viable excuse. I suppose if you live in southern FL or CA you could get away with ignoring it.
    No matter how you slice it though it's not worth the trouble of neglecting it just to save a few bucks over years worth of time.
  2. Sep 27, 2024 at 6:51 AM
    #152
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Imagine how much toyota coolant has sold only as a result of this video lol. Im guilty i ordered some. 15 years of use im probably too late
    CasperTheFriendlyTundra and vtl like this.
  3. Sep 27, 2024 at 7:02 AM
    #153
    packfan
    packfan New Member
    2021 Tundra Crewmax 4x4 1794
  4. Sep 27, 2024 at 7:44 AM
    #154
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    For Volts - DC setting - direct volt on multimeter.
    Black tip always goes to ground point and Red on what you are testing unless, like in this instrance I assume we are just making a closed circuit connection. So it doesn't matter.
  5. Sep 27, 2024 at 7:55 AM
    #155
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I now suspect Toyota paid him to avoid bashing the gen3 motor. Replaced 3 head gaskets on gen 2 - > skies are falling. Gen 3 two model years recalled for engine replacement -> nothing to see here, please disperse.
  6. Sep 27, 2024 at 8:15 AM
    #156
    borla123
    borla123 The Pits
    Ontario
    hah hah
    vtl[QUOTED] and AZBoatHauler like this.
  7. Sep 27, 2024 at 12:24 PM
    #157
    Retired...finally
    I did as the video suggested and got wavering voltages. Can't reach the coolant in the overflow tank so had to pop the cap. I'll change it at 5 years and should have about 50,000 on the truck.
  8. Sep 27, 2024 at 12:50 PM
    #158
    Fobroader
    Fobroader New Member
    Alberta
    2020 Platinum
    testerdahl and vtl[QUOTED] like this.
  9. Sep 27, 2024 at 12:54 PM
    #159
    borla123
    borla123 The Pits
    Ontario
    That usually means a bad ground. can you reach the negative terminal on the battery for ground?
    Mine reads .06 on the 4Runner. Its design allows me to reach the overflow coolant.
  10. Oct 1, 2024 at 4:22 PM
    #160
    NotSpongeWorthy
    NotSpongeWorthy i member
    Ricky
    Valkenvania, PA
    2020 Tundra SR5 TRD Sport Crewmax
    Furry steering wheel cover
    That video is just the chefs kiss isn’t it?
    “Hey gen 2 owners, your motors are bad”
    “Hey everybody, here is my beautiful gen 3. Wouldn’t you believe it, still runs like a top after a whopping 1,000 miles, har har har! If the engine ever needs to be replaced, I can just do it myself, so that nullifies the normal concerns of everything else around the engine getting damaged, har har har!”
    testerdahl, vtl and Retired...finally like this.
  11. Oct 2, 2024 at 5:46 AM
    #161
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Don't be jealous that they get a new head gasket from Toyota for free by 40k miles.
  12. Feb 5, 2025 at 1:01 PM
    #162
    quikz
    quikz New Member
    2012 5.7 DC 4x4
    TRD Intake 'Accelerator'
    FWIW.
    My local Toyota dealer serviced writer told me he has never seen a Tundra 5.7 w a blown HG. But they have seen a bunch of cam tower leaks. I don't use Seafoam for that possible reason.
    Mine was bought in 2023, exactly 2 years ago, Feb 2023. I am the 4th owner. Miles at 135k at that time. Was a CPO around 2017. Mostly local dealer serviced, w records. Mine is a 2012 DC 5.7 4x4. Gets off road use a lot. Pine Barrens. No accidents, no rust.
    Around 2021 the 3rd owner replaced water pump, t-stat and radiator and rad cap. Dealer repair.
    My timing chain tensioner went out after 1st month of purchase. But I believe my local Chevy dealer knew and therefore took $5k off price in 2023. I had it done by my mechanic, for $3900 which also fixed timing cover and valve cover seepage and inlet hose to timing cover leak all fixed, "for free" as result, including belt tensioner w/ seized bolt, using 'oem' parts. I have NO cam tower or valley plate leaks. Was pressure tested around 2023 and a few months ago again around Oct 2024. NO leaks.
    Did full coolant flush at dealer, right before all this latest CCN HG video stuff. Because it was 'the right thing to do.'
    Coolant level is stable in coolant reservoir since I'm paranoid now. But no hanky panky from the HG or anything else for now. Current mileage is 152k. Feb 2025.
    My buddy bought a 2007 used around 2010 with approx 84k miles. Drove it to 500k miles at around 2021. He was on worker's comp for over 10 years LOL.. He drove all up and down the east coast. No major issues. He had a new water pump around 180k miles(?) BUT never changed the coolant otherwise. And never changed his trans fluid. Changed his oil around 10k miles since he put roughly 34k miles per year. So oil changes based on time rather than mileage. Died at 500k miles due to bad engine computer. Rodents? Lightning strike? Not sure. Traded it in and still got $5000 back in 2022.
    Tundra Dude 45 and Tunrod like this.
  13. Feb 6, 2025 at 10:13 AM
    #163
    ff4life4
    ff4life4 New Member
    2017 Black SR5 Crewmax, TRD Offroad
    https://youtu.be/EDU5CNpCXUE 10:50 in the video.
    It seems Car Care Nut posted a new video addressing this. Mentions that the issue he only sees on 07-13, and never seen 14-21. Additionally mentions there were some part changes in the 2014 year for the 3UR.
    Mend0k and equin like this.
  14. Jul 19, 2025 at 10:27 AM
    #164
    Mend0k
    Mend0k New Member
    2015 TRD Pro
    Omg this eased my mind so much lmao.. i'm the third owner of my 2015 w/ 139k miles. I've been stressin because the only time the coolant was changed was 5 years ago at 93k miles. I'm been replacing all the worn parts/areas and fluids, including the coolant recently, but it bothered me so much that the first coolant change was 43k miles "too late" based on the 50k recommendation of CCN lol..
  15. Jul 20, 2025 at 1:00 PM
    #165
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Did my coolant last week finally. So ridiculously easy i can’t believe i hadnt done it yet. @ViktorG has a perfect youtube video for it very thankful.
    my truck has 135k but the radiator was replaced under warranty at 78k so it was definitely needed
    AZBoatHauler likes this.
