high voltage
Discussion in '1st Gen Tundras (2000-2006)' started by Fractious, Jul 18, 2025.
  1. Jul 18, 2025 at 6:40 PM
    Fractious
    Fractious [OP] New Member
    Leah
    2002 Tundra 4.7 v8 trd 2wd access cab
    So my trucks voltmeter seems to read pretty high all of the time. I had issues last night where the truck wouldn't start, started fine with a jump and got me home but it wasn't smooth. I had had issues with the battery terminals in the past so I replaced those and bought a new battery. Starts good now. I'm worried I'm frying the new battery. Alternator is relatively new, I have a new voltage regulator to install. Anyone have a map of the ground to the alternator for me to check or other ideas?
  2. Jul 18, 2025 at 6:52 PM
    vmkeith
    vmkeith Slow is smooth, smooth is fast
    Vince
    Clark County, Wa
    2014 Super White Tundra SR5 CrewMax 4x4
    Rhino Lining Cooper Discoverer ATP II LT275/70R18 TRD Pro dual exhaust with TRD exhaust tips Lund 5" Cab Length Oval Curved Tube Steps RealTruck TruXedo Pro X15 Tonneau Cover RealTruck Elevate FS Bed Rack Rhino-Rack Carriers Diode Dynamics SS3 LED Fog Light Kit Auxito LED Headlight Bulbs Rydonair 7" antenna
    That's not high at all. You meter scale is 0-18, which means the mid is 9. The needle is sitting approximately in the middle of 9 and 18, so estimate that at about 14-15 volts. Which is pretty normal. While my Tundra is a 2014 Gen 2.5, my battery voltmeter is usually sitting at around 14 volts.
  3. Jul 18, 2025 at 6:53 PM
    That voltmeter looks fine for when the truck is up and running making 13.5-14 volts. Measure the battery with an actual voltmeter to be certain.
  4. Jul 18, 2025 at 6:54 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    That's a dummy gauge. Get a proper multi-meter and check the voltage at the battery terminals then report back. Check the battery voltage before you start the engine, and after a good long drive to make sure everything is charged.
    Most importantly check the voltage at the battery when it's running. Acceptable range when it's running is anywhere between 13.2V and 14.8V, but 14.2-14.8V readings are going to be less common, especially if you're running an AGM without a proper AGM diode fuse/ voltage regulator.
    Anything higher than 14.8V with the engine running, take the battery to get tested ASAP.
    If you have an AGM battery, the battery will read 13.0-13.4V when the engine is off and the battery is fully charged. You won't fully charge an AGM off your truck's alternator without a proper AGM diode fuse/ voltage regulator.
    If you have a standard sealed/ maintenance free lead battery, it should read 12.5V-12.9V when the engine is off and the battery is fully charged.
    If you have a battery where you add water, I recommend checking the water level before looking at the voltage. YouTube can teach you how to check the water levels in a non-sealed battery.
  5. Jul 18, 2025 at 6:56 PM
    This is the correct answer. I’m glad someone else said it so I didn’t need to explain it for the 50th time.
    bfunke and Fractious[OP] like this.
  6. Jul 18, 2025 at 7:33 PM
    Fractious
    Leah
    My bad. I tried not to be that guy but the search brought up damn near the entire forum and I'm impatient. Thanks everyone! Will check with the multi-meter when I get to it to confirm. Y'all do not disappoint.
  7. Jul 18, 2025 at 7:54 PM
    I swear it’s also in the 2000-2004 Owner’s Manual. I know it’s not sexy to read an owners manual or anything, but it’s really helpful with something as generally complex as a vehicle. :thumbsup:
  8. Jul 18, 2025 at 7:56 PM
    des2mtn
    Shady Grove
    Tonto cover
    I don't remember if it's in the manual, but I checked my numbers in the FSM:
    G_unit3000 and shifty`[QUOTED] like this.
  9. Jul 18, 2025 at 8:01 PM
    I don’t think the FSM shows gauges. Toyota has a copy of year every owners manual online, but I’m on mobile so it’d be painful to try and check it for gauge cluster reading. Here’s the link: https://assets.sia.toyota.com/publications/en/om-s/OM34417U/pdf/OM34417U.pdf
    Anyone can grab an owners manual for their vehicle for free by hitting Google with TUNDRA OWNERS MANUAL YYYY
    (where YYYY is your year)
  10. Jul 18, 2025 at 8:04 PM
    Hot damn there it is.
    BroHon and Fractious[OP] like this.
  11. Jul 18, 2025 at 8:06 PM
    But if it were me, I’d be more worried about that check engine light, unless the engine was off at the time of the 1st pic.
    Fractious[OP] likes this.
  12. Jul 18, 2025 at 8:31 PM
    Fractious
    Leah
    des2mtn likes this.
  13. Jul 19, 2025 at 5:30 AM
    If upstream, best get on that ASAP. Bad upstreams cause several other issues.
  14. Jul 19, 2025 at 5:35 AM
    18 volts is acceptable? That doesn’t seem right. It’s practically acknowledging how crappy the voltmeter was designed.
    BroHon likes this.
  15. Jul 19, 2025 at 5:54 AM
    I thought that was weird also.
  16. Jul 19, 2025 at 6:15 AM
    vmkeith
    Vince
    Clark County, Wa
    Consistently 18 volts, that's bad. Lead acid batteries have a tendency of going into thermal runaway at that point. That leads to a battery going boom
  17. Jul 19, 2025 at 6:22 AM
    Strangely that’s not what the owner’s manual is stating. But then again, 2 quarts for transmission fluid replacement isn’t exactly accurate either.
  18. Jul 19, 2025 at 6:24 AM
    vmkeith
    Vince
    Clark County, Wa
    It's an extreme case, not something I'd expect them to put in an owner's manual. wouldn't be a good selling point :rofl:
  19. Jul 19, 2025 at 10:04 AM
    bfunke
    bfunke Tundra Curmudgeon
    Did the OP actually measure it with a decent voltmeter?
