  1. Jul 17, 2025 at 5:41 PM
    Bham TRD
    Bham TRD New Member
    Birmingham, AL
    2017 Tundra Platinum 4WD CrewMax
    I’m considering these, how are they doing for you?
  2. Jul 18, 2025 at 9:13 AM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    I've been thinking of getting one of those since before I bought mine. Helped haul donated cat and dog food on Tuesday, and was glad I didn't. Easy to just have the forklift put the pallet in the bed.
  3. Jul 18, 2025 at 10:00 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Could always do a softopper. Best of both worlds
    Boneskull420 likes this.
  4. Jul 18, 2025 at 12:23 PM
    martyhawg
    martyhawg New Member
    2021 TRD Pro
    Want to do more mods but chemo is sapping the energy plus it’s one hundred and eleventeen degrees outside.
    Fobroader, TreeCat, Yota303 and 7 others like this.
  5. Jul 18, 2025 at 2:04 PM
    SAGE63
    San Diego County
    Best to you with the chemo...
  6. Jul 18, 2025 at 3:23 PM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    Where are you located with those temps, brother?
    Tripleconpanna likes this.
  7. Jul 18, 2025 at 3:26 PM
    Mend0k
    Mend0k New Member
    2015 TRD Pro
    Bedliner made it look like new!
    1UP, AGTundra, Boneskull420 and 10 others like this.
  8. Jul 18, 2025 at 4:10 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I’m way too cynical. Softoppers look cool, but all I see is, all the security and water intrusion of an open bed and also a bunch of time to remove it and put it back if you need an actual open bed. :laugh:
  9. Jul 18, 2025 at 4:33 PM
    Velocity72
    Upstate SC
    2021 Platinum
    I’ve seen a hardtop that hinges where the front by the cab stays in place, and the rest of it flips up like a standard flat hard cover does. I’ll see if i can find it.
  10. Jul 18, 2025 at 5:07 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Decided to try AGM battery to see what all the rave about. Walmart had the H7/94R in stock. Under $200.. not bad. Had to get a different battery tie down since the factory one is not flat. Reused the tie down rods and it fit great.
    Also threw in the voltage booster pro while I'm at at. At the low position i see 13.9v. Switch to high and see 14.4v. Both at cold start up. This is what the maestro shows on the radio. Not sure if i should leave it on low or high.
    Any suggestion???20250718_192740.jpg 20250718_192731.jpg 20250718_193127.jpg
  11. Jul 18, 2025 at 5:41 PM
    I didn't even know Walmart carried AGM.
  12. Jul 18, 2025 at 5:43 PM
    BrandonL812
    Brandon
    Yessir they do. The size 94r/h7 is same as the 27f only shorter.. you need to trim the battery tray on both shorter size so the battery will sit flush. Otherwise it dropped right in..
  13. Jul 18, 2025 at 6:09 PM
    koditten
    Kirk
    Midland of the Mitten
    My experience wasn't so positive.
    Installed an AGM battery in February. Like you noted, it was shorter. I cheated and cut a piece of pine 2 x 10 to raise the battery up so the posts and clamps were not stressed.
    Battery internally shorted in June.
    Let me tell you, the truck does some wild things when a battery is randomly shorting. Radio comes on when you close the door was the 1 st thing I noticed. Cruise
    bulldog93 likes this.
  14. Jul 18, 2025 at 6:11 PM
    BrandonL812
    Brandon
    Oh snap. Which agm battery did you had? I need to keep an eye on it if that's the case. Now I'm paranoid.
  15. Jul 18, 2025 at 6:13 PM
    koditten
    Kirk
    Would shut off, voltage gauge would bounce all over the place, speedo would read 90 mph, then drop back to the 35 mph you were actually going. Those are the things I can recall.
    Happy I made it home. Yanked that POS and installed the original battery that came with the '21.
    Things have been normal for the last month and a half.
    I think I'm ok with flooded cell batteries for now. I'll wait until AGM batteries become more reliable.
    Tripleconpanna and bulldog93 like this.
  16. Jul 18, 2025 at 6:19 PM
    centex
    centex New Member
    You got a “shit happens” battery. AGM is not new technology and is well tested in harsh environments.
  17. Jul 18, 2025 at 6:20 PM
    koditten
    Kirk
    Sorry about the 2 section post. Finger hit send by accident.
    I got the battery from Amazon. The battery is now located in a scrap yard somewhere. I could look for previous purchases, but I really don't want to negatively post info about a sellers item.
    I'm perfectly willing to accept that I got a fluke of a battery. Everything has an allowed failure rate. I just got the bad one. It happens.
    The one thing that I can post that may be valuable...is that I have never had a flooded cell battery go bad so fast. I have always had a week or so of slow cranks letting me know the battery was at EOL.
    The AGM started amazingly right up to the day I noted the weird shit going on with the electronics.
    BrandonL812 likes this.
  18. Jul 18, 2025 at 6:34 PM
    Bham TRD
    Bham TRD New Member
    Birmingham, AL
    I love it, holds my Skoal like a champ.
    rdiddy5 and bradj1 like this.
  19. Jul 18, 2025 at 6:39 PM
    koditten
    Kirk
    Holds my keyless fob perfectly...of course I forget it's there and leave the truck parked in random parking lots. Not remembering until I'm half way home that anyone could have hopped in the truck and off they go.
    #hatekeylessignition
    23Tundy, AGTundra and Tripleconpanna like this.
  20. Jul 18, 2025 at 7:03 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    +1
  21. Jul 18, 2025 at 7:05 PM
    martyhawg
    2021 TRD Pro
    Only in Central Virginia but the dang humidity and the chemo makes me feel like I’m back in Qatar. Freezing inside but burning up outside. I’ll get my energy back sometime and be able to wrench more. Only really like 90’s with high humidity.
  22. Jul 18, 2025 at 7:15 PM
    Azblue
    The Dirty T ( ^_^)_且
    So sorry to hear you are dealing with this. So unsolicited advice, chemo does some weird fucked up shit to your body and mind. Don't push it, working on a truck is the last thing you need to deal with now. There will be time to do that later, get well first.
  23. Jul 18, 2025 at 7:15 PM
    Rakkasan
    Rakkasan New Member
    NorCal
    2020 Tundra- cement-crew max 4x4
    Spray in Bed liner, 2-10”subs/400w.amp, tailgate shock, Tinted windows, seat covers, dash cover, CatShield, Fuel D538 20”wheels, Husky custom floor mats, TSC tool chest, leather seat covers. Genuine Cooling systems transmission cooler, scan gauge OBD2
    Good luck with the chemo, I'm not in that position but I can't really walk very well right now, knee replacement in a couple weeks but I know that's not a big deal.
    Best of luck.
  24. Jul 18, 2025 at 8:28 PM
    AZTundra
    Paul
    Phoenix, AZ
    Replacing the OEM JBL subwoofer tomorrow with a 10” JL Audio 10TW1-2 in a ported box built by Taylor’s Audio. It will be connected to a Kicker CXA660.5 five channel amplifier. The subwoofer output of the amp is 300 watts RMS at 2 Ohms so it should pair up nicely with the new sub.
    TreeCat, Jbehredt, Bergy24 and 9 others like this.
  25. Jul 19, 2025 at 5:13 AM
    If I recall, don't you have the Alpine Halo 11?
    AZTundra[QUOTED] likes this.
  26. Jul 19, 2025 at 5:41 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Had the shop fix the problem with them installing the Eibach boot into the front (should be used for the rears) and since they had the springs off to re-installed the OEM springs. I wanted the factory ride height but with better strut compression. It rides so much better than the OE black struts.
    Today, I'll be installing the rear Eibach shocks, rear brake pads, removing black TRD sway bar and installing the 27lb RED TRD sway bar, removing TRD skid plate and reinstalling the OE thin skid plate for easier maintenance. And maybe do diff fluids and a few of other things. Busy weekend!
    CaptRussia253, blenton, BR73 and 5 others like this.
  27. Jul 19, 2025 at 6:35 AM
    martyhawg
    2021 TRD Pro
    My old lady keeps telling me to take it easy but I’m bored as shit. Will scroll through threads to keep my mind occupied.
    DrRansom, Rakkasan, Uhhhh.... and 6 others like this.
  28. Jul 19, 2025 at 7:19 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    You got me on security, but my softopper on my old Tacoma survived a few good Montana winters and spring and fall rain without missing a beat.
    250000yota, koditten and HulkSmurf14 like this.
  29. Jul 19, 2025 at 7:35 AM
    martyhawg
    2021 TRD Pro
    Never had a knee replacement but my buddy said just start on those meds early and get up while you can and move. Good luck.
    koditten and NewImprovedRon like this.
  30. Jul 19, 2025 at 7:39 AM
    AZTundra
    Paul
    Phoenix, AZ
    I do. I’m running that head unit with the Trail Grid Pro 10 speaker Alpine bundle and the Kicker plug and play amp that I recently installed. I’ve been using the OEM subwoofer until the new box and JL sub arrived.
