Tundra engine recall - interesting news
Discussion in '3rd Gen Tundras (2022+)' started by katekebo, Jul 25, 2024.
  1. Jul 16, 2025 at 3:14 PM
    #4681
    sudobash
    sudobash New Member
    Hearing there is a gasket shortage again. Unsure which one.
    cartage1 likes this.
  2. Jul 17, 2025 at 6:09 AM
    #4682
    Brian422
    Brian422 New Member
    Birmingham, AL
    23 Limited 4x4
    Meanwhile lead of the service department told me he had engines upstairs if mine was a recall....
    sudobash[QUOTED] likes this.
  3. Jul 17, 2025 at 6:18 AM
    #4683
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield
    LOL... I liked your post on this but I DON'T like the schedule, as I am also in Phase 7 which is still TBD. We have more road trips to do this year, so back to rolling the damn dice.
  4. Jul 17, 2025 at 6:35 AM
    #4684
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    From my understanding the recall trucks shouldn't need the gasket set as the engine comes pre-assembled
    22whatwedo, Gepperso and sudobash like this.
  5. Jul 17, 2025 at 7:28 AM
    #4685
    FoopaKing
    FoopaKing New Member
    2024 SR5
    The better question is, what poor first year mechanic is tasked with carrying engines up and down stairs
  6. Jul 17, 2025 at 8:00 AM
    #4686
    Brian422
    Brian422 New Member
    Birmingham, AL
    23 Limited 4x4
    his wordage not mine lol
  7. Jul 17, 2025 at 8:01 AM
    #4687
    Brian422
    Brian422 New Member
    Birmingham, AL
    23 Limited 4x4
    mines not recall...
  8. Jul 17, 2025 at 9:02 AM
    #4688
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    Gravity does the down. They drop them down the stairs and shove it in the engine bay
    Not like it's their truck
    cartage1, PBNB and kirkb like this.
  9. Jul 17, 2025 at 9:22 AM
    #4689
    FoopaKing
    2024 SR5
    The percussive transport method is good for break in. Really jiggles the rings into place
    cartage1, woods and PermaFrostTRD like this.
  10. Jul 17, 2025 at 9:26 AM
    #4690
    PermaFrostTRD
    Northern NY
    Final QC stage to knock the last bit of machining debris out
    cartage1, kirkb, WNY PAT and 2 others like this.
  11. Jul 17, 2025 at 11:08 AM
    #4691
    sudobash
    sudobash New Member
    They would need them at TMMAL for assembly, so we could assume that that takes precedent.
    Mallcrl[QUOTED] likes this.
  12. Jul 17, 2025 at 11:44 AM
    #4692
    Henfield
    Henfield New Member
    They do drop the oil pan after dropping the engine in to remove the last bits of swarf from the engine.
  13. Jul 17, 2025 at 12:05 PM
    #4693
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
  14. Jul 18, 2025 at 1:12 PM
    #4694
    Brian422
    Brian422 New Member
    Birmingham, AL
    23 Limited 4x4
    Well got my truck back today. took a month and 3 days. Glad to have her back. Now lets see how long this one lasts.
  15. Jul 18, 2025 at 1:27 PM
    #4695
    2wheelsforfun
    2wheelsforfun New Member
    Foothills AB Canada
    Glad you got your truck back, hope you enjoy many trouble free miles. In amongst all this doom and gloom I've been wondering about the large percentage of Tundra's that have not, and may not experience a catastrophic failure. I've seen 1% bandied about and according to Lionsfan?? they have had 3-4 catastrophic failures out of 70 engines replaced, so makes 6% seen at that dealer. But that still leaves 94% trucks running fine, at least for now. If it was a design fault, wouldn't we see more failures, at more consistent mileage? The failure mileage is all over the map. Just curious and I guess if this was happening to Ford, RAM or Chevy we wouldn't even be talking about it, but because it's Toyota, well here we are at the Toyota lottery, are you feeling lucky (unlucky) today?
  16. Jul 18, 2025 at 2:35 PM
    #4696
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 2016 Platinum Sequoia, 2003 Tacoma SR5 V6 5Spd
    No.
    3 examples of design flaws with no precise mileage that failure occurs at and failure rates far, far below 100% of units produced:
    1) Subaru head gaskets
    2) Toyota 5vz-fe timing belt tensioner oil seals
    3) Ford Triton V8 Spark Plug Threads
    Edit: 4th example:
    4) 3UR-FE valve spring failures
    2nd Edit: #4 was probably a manufacturing defect but was added to the list to appease those who "own" this section of the forum.
    kirkb and sudobash like this.
  17. Jul 18, 2025 at 3:25 PM
    #4697
    Fatone
    Fatone New Member
    A design flaw can lead to failure under only certain conditions or use cases. There have been design flaws that only occurred in cold weather or high humidity climates for example.
    sudobash likes this.
  18. Jul 18, 2025 at 4:18 PM
    #4698
    WindChillYeti75
    WindChillYeti75 New Member
    2025 WCP Limited TRD Off Road iForce Max
    Everyone can keyboard warrior all they want and speculate all they want. At this point, no one knows if anything is a “design flaw” unless you’re on the higher end of the totem at Toyota. Most, if not all the engine issues are under warranty or under Toyota’s extended warranty. I feel like at the end of the day, chances are better with Toyota than any other manufacturer.
    FrankG, Bulldog6 and jctmundra like this.
  19. Jul 18, 2025 at 4:37 PM
    #4699
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    I agree with you. But I get a little anxiety when this thread updates. I think I said I was going to quit watching these things.
  20. Jul 18, 2025 at 4:52 PM
    #4700
    WindChillYeti75
    Don’t even worry about it man. I owned a 2020 tundra and I STILL love my current tundra way more. It’s better in every way! Toyota is already under the microscope as it is. So any more engines that have issues, I can almost guarantee Toyota will be on it instantly and send an engineer out. The good thing is, extended warranties are relatively cheap in the scheme of things if you decide to get one. Just do your pre 1k mile oil change and every 5k after that and that’s all you can do. I’m grateful for this forum and all of its members (well most of them lol) for sure!
  21. Jul 18, 2025 at 8:28 PM
    #4701
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Agree, luv my Terra Pro !
  22. Jul 19, 2025 at 4:05 AM
    #4702
    szabo101
    szabo101 New Member
    ED
    2018 MGM Platinum 4WD
    Great, you agree with Toyota internet propaganda.
    Love the New Toyota
    It's gotten better in every way
    We're not perfect, but our rep is important to us
    Have an issue, we'll send a special Engineer just for you
    Toyota instantly takes care of all problems, they don't guarantee it, and it hasn't been reality
    If you need peace of mind, just get one of our inexpensive warranties
    Just don't forget to get your routine maintenance done at the dealership
    I (Toyota) am so grateful for the suckers here that bought this
    woods and OHwendTrd like this.
  23. Jul 19, 2025 at 4:16 AM
    #4703
    turbohardtop
    turbohardtop New Member
    Sorry if this has been discussed. I was wondering why the 2024 were not part of the recall. Is Toyota planning to do this in phases and eventually recall the newer year models? I was looking at the spreadsheet and there were lots of questions but none were asked if the failure occurred with aftermarket filters.
  24. Jul 19, 2025 at 5:12 AM
    #4704
    szabo101
    szabo101 New Member
    ED
    After 14 months since the recall announcement, Toyota is still in the middle phases of fixing the original recalled vehicles produced from the end of '21 to early February '23. My guess is that when they are finished with that(probably in about 12 months for those actively waiting), they will decide the failure rate is low enough that they don't have to recall any more vehicles. While there have been failures from '23, '24, and '25, as well as with hybrids, they are not part of the recall. And, failures do seem to be lessening as time passes.
    This would seem positive, but the curious thing about Tundra failures to me is not the rate of failure, but the cost of repair which has been reported at approaching $25-$30k, likely higher for the hybrid variant. While GMs problems are significant too, replacing the 6.2L would cost in the $10k-$12k range by comparison. I do a lot of miles, and an extended warranty to 150k would last me between 4 and 5 years, a $30k repair after that point, totals the vehicle.
    Also, despite the impression of many, Toyota did not 'man up' about this right away. I have no delusions that a corporation can love you back.
    woods likes this.
  25. Jul 19, 2025 at 5:58 AM
    #4705
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Where are you getting the $25-$30K number?
    I've read the total recall of 100K engines will cost Toyota $500 million. That's $5000 per engine. I realize the retail price would be more, but I think $25-$30K is a stretch.
    Maybe NotRyan will know.
    Gonefishingdave likes this.
  26. Jul 19, 2025 at 6:00 AM
    #4706
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    Sounds like somebody had a really bad experience with their 3rd gen.
    Salty
    ScottieBones and WindChillYeti75 like this.
  27. Jul 19, 2025 at 6:38 AM
    #4707
    szabo101
    szabo101 New Member
    ED
    LOL, no, just can tell propaganda when I see it. The only experience i've had with third gens is test drives and discussions with owners. These trucks are not on my radar.
    Do A search on Tundra V35A FTS Engine replacement costs. There have been plenty of posted invoices/work orders, here, Facebook, Reddit. Some of the earlier ones as high as $35k before Toyota announced the recall. I wouldn't anticipate anything less than $25k if you are outside your warranty.
  28. Jul 19, 2025 at 6:59 AM
    #4708
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Laughable you think it’s $5000 / engine, through citation of terrible math.
  29. Jul 19, 2025 at 7:12 AM
    #4709
    WindChillYeti75
    This is exactly who I was talking about. This dude got so triggered he had to chime in once again. He even said it himself “no I just test drove one”. He has no real experience with owning a third gen. Don’t let guys like him ruin your experience with your new truck. I had an engineer sent to my dealership for WIND NOISE coming from my driver’s side mirror and now they’re replacing the whole assembly free of charge. Drive whatever makes you happy because clearly guys like him can’t be happy.
  30. Jul 19, 2025 at 7:16 AM
    #4710
    WindChillYeti75
    You’re never happy are you? Super emotional. What do you suggest they buy? A Ram? A Chevy or GM? A Ford? What a joke dude. Give it a rest and let people be happy with their purchase. I’ve owned both not just “test driven” in your words. I love my current truck way more than my 2020. Oh wait, does that trigger you too?
