Bumpy Ride
Discussion in '3rd Gen Tundras (2022+)' started by robasce, Jul 18, 2025 at 12:55 PM.
  1. Jul 18, 2025 at 12:55 PM
    robasce
    robasce [OP] New Member
    2024 1794 Edition Tundra TRD Package
    I had my 2024 Tundra (1794 Edition, 4x4 Offroad) lifted to about 2”. I changed the tire to 35, 12.5, 20 using a 26” offset. After the lift, the ride became bumpy. I know after a lift, it will be bumpy but I did not anticipated a real bad ride. I was looking at Westcott lift but somehow my mechanic was able to changed my mind and went with Eibach stage1. I am not familiar with these things… any recommendation to make my ride smoother?
  2. Jul 18, 2025 at 4:09 PM
    ubybc
    ubybc New Member
    2024 Tundra Hybrid Limited
    did you check you tire pressure? makes a big difference if you run them hard/tall or short/soft for which road type your on. My previous lifts have also taken a few days/week to really settle in.
    Nbab23 likes this.
  3. Jul 18, 2025 at 5:56 PM
    Southbound1
    Southbound1 New Member
    2024 TRD Offroad
    I had the Eibach stage one on my 2016, it was a bit harsh at first but settled in nicely. I was pretty happy with it overall. Much better damping, you hit a bump and it absorbs it and levels out, doesn't keep cycling the suspension if that makes sense. Planted is a good way to describe it, may be slightly harsher initially but smoother overall.
    Nbab23 likes this.
  4. Jul 18, 2025 at 6:04 PM
    Southbound1
    2024 TRD Offroad
    I drive a fair amount of washboard gravel road and rough pavement, go faster (within reason) it really smooths out with the Eibach kit. In my 2016 the back end was all over the place in those conditions stock. Thinking about the Eibach stage two for my 2024 TRD OR, but it is pretty good stock so far honestly. Not really worried about a lift, just interested in better suspension performance.
  5. Jul 18, 2025 at 6:39 PM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    I agree with the others. The lift should settle and smooth out after a few rough rides. You can take it on some bumpy or forest roads and that’ll help speed up that process. Also depending upon the type of shock the truck will get smoother the faster you drive, usually when you hit the 35mph range. The 35” tires are going to make it rougher as well in general. Especially if you have a more aggressive tread. I’ve gone through a few different sets and brand makes a big difference as far as smoothness goes. I had 34” coopers that ran rough and 35” falkens that ride amazing.
  6. Jul 18, 2025 at 6:41 PM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Unfortunately 20” wheels have less rubber as well so that will play a factor in ride quality too. Some say it doesn’t but I tend to think it does.
  7. Jul 18, 2025 at 7:05 PM
    Breathing Borla
    Northern Illinois
    Load e heavy tires isn’t helping
    Nbab23 likes this.
