Should I or not, dealership dilimma
Discussion in '3rd Gen Tundras (2022+)' started by tstex, Jul 18, 2025.
  1. Jul 18, 2025 at 6:44 AM
    tstex
    tstex [OP] New Member
    Houston & Colorado County TX
    2024 Silver Tundra TRD
    The tundra just hit 10,000 miles and I'm up for the "free" oil change.
    When I took it in for 5K, they did not even put the tire caps back on 50% of tires. I changed my own oil at 5K and will do so every 5K. The ONLY reason I'm contemplating this is bc it's 98 in Aftn and not real cool. I've just heard a lot of war stories re dealer "tech's" and the oil changers are intro guys for sure. Thanks
  2. Jul 18, 2025 at 6:47 AM
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    Take advantage of the free service but make sure you don't have any leaks, the oil is full, and everything they say they did is done.
  3. Jul 18, 2025 at 6:48 AM
    I’m a do my own maintenance kinda guy. I just don’t trust anyone to work on my stuff. That being said, your dealership may have some good techs. I would love to take advantage of the included service (nothing is free) that is offered. Sad, but you will have to check all of their work, and potentially have them go back to remedy anything you find wrong with their work. Sounds like your last experience was poor. I would expect the same this time.
    ScottieBones likes this.
  4. Jul 18, 2025 at 6:59 AM
    tstex
    Thx guys.
    My dilimma is:
    -do i express my (-) experience prior to wk and put them on notice, then if the "tech" gets po'ed, do a crappy job, or,
    -say nothing & let the chips fall where they may?
    I'm ok w the heat, but i have to take it in for all the other things, so I'm contemplating the oil change too. It's really crappy that you have to Ck their wk. i have OEM filters & crush washers, and use one of the best synthetics there is, next to Pennzoil premium. BTW, what oil do they use? Thanks
  5. Jul 18, 2025 at 7:02 AM
    75tranzam
    Midlothian, Va
    I always give feedback, either I say how good the service was and I appreciate it or I complain. The guys behind the counter have no idea on if the actual service is good or bad so I always tell them in a polite way.
  6. Jul 18, 2025 at 7:08 AM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    There's always the option of a different dealer... I would definitely say something though, as above, the service advisors don't know the condition of the tech's work; and lube techs aren't always around for the long term to know their patterns
  7. Jul 18, 2025 at 7:31 AM
    tstex
    Thank you guys
    75tranzam likes this.
  8. Jul 18, 2025 at 7:44 AM
    Cox3497
    Cox3497 New Member
    Toyota Tundra Crewmax
    I learned my lesson with my 2016 and the first couple free oil changes. Decided I was too busy to do myself before a cross country move, and that was the day they ended up accidentally keying my door. Created a giant headache to deal with literally days before an already stressful major move. Never again. No one will do as thorough a job as you will on basic maintenance items. Especially not the high schooler they have doing the oil changes. YMMV, good luck.
  9. Jul 18, 2025 at 8:35 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I say take advantage of the free service, but as mentioned, check everything before you leave. My check list is:
    1. Make sure the drain plug is tight.
    2. Beforehand, mark the existing oil filter, so you can easily verify it's actually been changed.
    3. Make sure the oil fill cap is on.
    4. Check the oil level.
    5. If you have them do a tire rotation, mark a tire with chalk beforehand, so you can confirm they were actually rotated.
    6. Look your truck over carefully for any damage, both interior and exterior.
    I've also found that you can often casually walk around the outside of the service bay building to find your truck. On several occasions, I've been able to chat the tech up while I watch him do the work.
    MAC25Tundra likes this.
  10. Jul 18, 2025 at 8:57 AM
    I have always skipped any free dealership maintenance. If something goes wrong, I'll chew out the Guy in the mirror.
    whodatschrome and BlackNBlu like this.
  11. Jul 18, 2025 at 9:08 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    I got older, I live in New Orleans...it's hot. I gave up on doing oil changes a long time ago. At least with the stealership I have a better chance of getting them to make it right when they screw something up.
  12. Jul 18, 2025 at 12:10 PM
    tstex
    Thanks again guys...
    Another option is to let them do everything but the oil change, and ask them to give me:
    * 7.7 qts of oil to spec
    * OEM oil filter
    * crush washer
    * no grief
    BTW, what type of synthetic oil do they use?
    Again, thank you for your feedback guys, appreciate it.
    And, there is "no free oil change" or anything free. All of these "free services" are figured into the purchase price of every car they sell.
    Leo's first likes this.
  13. Jul 18, 2025 at 12:32 PM
    Matt2015Tundra
    2023 1794 CrewMax
    They use their own branded synthetic oil. I've read it's made by Mobil and has the same specs as Mobil 1 0w20 . It's outrageously expensive at my local dealership, so I just buy Mobil 1 at Walmart.
  14. Jul 18, 2025 at 12:48 PM
    tstex
    Thanks / do you know what version of Mobil 1? It has a lot of variations.
  15. Jul 18, 2025 at 12:54 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    Just pick a flavor and send it. Frequency and flow (viscosity) matter, flavor doesn't
  16. Jul 18, 2025 at 12:57 PM
    Matt2015Tundra
    2023 1794 CrewMax
    Sorry, I don't know.
    FWIW, I buy the Extended Performance Mobil 1 0w20
  17. Jul 18, 2025 at 3:55 PM
    ubybc
    ubybc New Member
    2024 Tundra Hybrid Limited
    take the freebie. double check their work.
  18. Jul 18, 2025 at 4:01 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    :rofl:They ain’t given you shit
    As stated take the included oil change and check things when done. I’m betting you won’t have any issues
    vtown76 likes this.
  19. Jul 18, 2025 at 4:48 PM
    tstex
    lol / i bet i could talk them into a few things. I had those defective front brakes and they pads snd all were on 3-4 months back order. They had one set for another retrofit and about 2 hrs later, i drove off w the brakes replaced. Now I'm up for another challenge.
    Leo's first[QUOTED] likes this.
  20. Jul 18, 2025 at 8:39 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Yep you ain't shitting about the horror stories. Yep oil change dudes don't give a shit about free scratches. Took mine in for paint sealant, and it came back with scratches. They of course denied it, even though I had photos before said incident. Always take pictures if you are dropping it off for work especially at a dealership. They wanted to fucking charge me for the fucking touch up paint.
  21. Jul 19, 2025 at 6:21 AM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    You already paid for it when you bought the truck (nothing for free) but check the work. I had a really bad experience on one of my free ones that ended up eating away most of a Saturday sitting in the dealership lobby. I would have much preferred to have been in my garage doing the work myself, and it would have taken no more than an hour.
    I doubt they will give you the materials but I guess it doesn’t hurt to ask.
  22. Jul 19, 2025 at 6:23 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Literally could not pay me to take my truck in for a free oil change.
    2mchfun likes this.
  23. Jul 19, 2025 at 7:34 AM
    ScottieBones
    ScottieBones New Member
    NC
    2025 Limited 4x4 TRD OR
    For me, with two young kids and busy job, time is a biggest factor. Nearest dealer is 30 mins away. Add in the the time sitting and waiting, checking over everything, possibly finding something that correction (and more time). So, I passed on the initial included service to DIY on my own schedule. I do acknowledge that some dealers are better than others, and there may be value in building a relationship with a service dept.
    BlackNBlu and Black Wolf like this.
  24. Jul 21, 2025 at 4:43 AM
    tstex
    Well, I changed my oil yesterday at 10.5K for my second one. Used OEM filter and 7.7qts of Quaker State Full Synthetic. I also changed out the Std oil plug, and used one w a magnet, and the blue felt crush washer. I then successfully updated the oil life.
    Two things about the OEM Oil filter:
    1. Why is it so small for suck a lg vehicle?
    2. W my F150, the filters were white, while these are Blk. I marked ea filter w date & current millage w a blk sharpie Kind of difficult to do that w a Blk oil filter, so i first put some white tape on it.
  25. Jul 21, 2025 at 5:18 AM
    turbohardtop
    turbohardtop New Member
    Anyone here use WIX oil filters? I usually use WIX in all my cars even in a built GTR.
    2mchfun likes this.
  26. Jul 21, 2025 at 6:41 AM
    MustangVetAMDO
    MustangVetAMDO Some free advice; Don't.
    Andy
    Moyock, NC
    Prev. OG 2007 CrewMax, pres. 2025 Tundra 1794 Ed.
    Retrax XR Pro, Yakima Overhaul HD
    I want to know if anyone is/has ever actually been successful at having the dealer routinely giving you the oil and filter + crush washer for you to perform the oil change.
  27. Jul 21, 2025 at 6:58 AM
    2mchfun
    x2
    MadMaxCanon[QUOTED] and Daedalus like this.
  28. Jul 21, 2025 at 6:59 AM
    2mchfun
    Only wix here
  29. Jul 22, 2025 at 6:20 AM
    tstex
    I've used WIX for my tractors and similar farm machinery. I use OEM for my autos.
    What i cannot understd (maybe a new thread), is why are the oil filters so small? My JDeere Gator has the same size as my tundra, oil filters on tractors are 2-3X's the size as the tundras.
  30. Jul 22, 2025 at 6:32 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    WIX is my go-to when I don't have OEM filters handy.
    FYI: NAPA Gold oil filters are WIX filters. (Not sure about their "standard" line of filters.)
    Oil filter size: Yep, they're smaller than what I would expect. Lots of filter media surface area inside though.
    But if your changing filters with your oil every 5K miles, does it matter? Probably not.
