25 Tundra making new noise.
Discussion in '3rd Gen Tundras (2022+)' started by Woo1178, Jul 17, 2025 at 7:41 AM.
  1. Jul 17, 2025 at 7:41 AM
    Woo1178
    Woo1178 [OP] New Member
    Willie
    Silver 25 Tundra SX
    None
    25 Tundra with 4158 miles 2 months 10 days old making noise. Clanking noise and then rattling happens low rpm some time does happen more often in idle with air on. Any ideas. Its at dealership someone metion #5 blown bearing rod in a post on FB.
    https://youtube.com/shorts/v33mBFR8dF8?si=O22XAEeZjJAU3A5d
  2. Jul 17, 2025 at 8:55 PM
    terraj66
    terraj66 New Member
    Las vegas
    That don’t sound right
    Mallcrl likes this.
  3. Jul 18, 2025 at 10:36 AM
    Hammertimerrrr
    Hammertimerrrr New Member
    2024 MGM Limited OR
    Following. My July '24 built 2024 Limited does this as well. But I suspect it could be something as simple as an exhaust hanger loose somewhere - had that happen in the past on my tacoma with a similar noise.
    Interested to see if anyone else knows what this is
    Tundrastruck91 likes this.
  4. Jul 18, 2025 at 10:44 AM
    Woo1178
    Willie
    Silver 25 Tundra SX
    None
    Toyota called back they were able to replicate it so warranty will be used. The advisor even said thats not normal they checked exhaust and pipes nothing wrong from physical inspection. Advisor mention teardown of engine if engineers see nothing with diag tools. This could get dirty quick.
  5. Jul 18, 2025 at 10:47 AM
    Maine TRD PRO
    Maine TRD PRO New Member
    2023 Ice Cap Tundra TRD PRO(Rioja Red interior)
    Dang. Sorry to hear that OP.
    Also sorry this is about to turn into an 800+ response thread full of experts on engine design
    kirkb, SDT-Online and 75tranzam like this.
  6. Jul 18, 2025 at 10:47 AM
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    Sorry to hear. I hope everything goes well.
  7. Jul 18, 2025 at 10:52 AM
    Woo1178
    Willie
    Silver 25 Tundra SX
    None
    Yup if they do do it its not gona run the same. I just may ask for buy back. I thought Toyota would have fixed all issues with it being 4 years later.
  8. Jul 18, 2025 at 10:54 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield
    Some folks have a transmission rattle... maybe that is what this is? That would be better then a failing main bearing anyway.
  9. Jul 18, 2025 at 10:58 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    ^^This.^^
    I'll eat my hat if that's a bearing noise.
  10. Jul 18, 2025 at 10:59 AM
    Woo1178
    Willie
    Silver 25 Tundra SX
    None
    Is that fixable issue or nor.al to Toyota. Be cause a new truck that cost 50g and up shouldn't sound like the tow truck from the Cars movie.
  11. Jul 18, 2025 at 11:03 AM
    BlackNBlu
    Rich
    MN
  12. Jul 18, 2025 at 11:10 AM
    Woo1178
    Willie
    Silver 25 Tundra SX
    None
    Its non hybrid. I heard that ticking noise i have that too only wjen engine is idle or while in drive with breaks applied but not while moving. Took it in 1st month wich was last month Engineers said normal. Its the fuel injectors.
  13. Jul 18, 2025 at 2:08 PM
    Hammertimerrrr
    2024 MGM Limited OR
    My truck has been doing this for months - but only seems to happen with the A/C is running. I can't really hear it in the cab. Truck is running excellent though, beyond the annoying trans learning that I have to reset every 4-5k miles until they get the shift maps worked out.
    I'd be surprised if this was directly engine-related given the source of the sound underneath the truck. Transmission rattle possible, but it's making the noise in park with the trans disengaged so...
    PLEASE let us know what they find out and if possible press them for specifics on the fix. I'm only at 15k miles on mine, literally the exact same sound when idling / AC on.
  14. Jul 18, 2025 at 2:17 PM
    Woo1178
    Willie
    Silver 25 Tundra SX
    None
    Master mechanic said it did it in low rpm while in reverse. I kniw there are ticking in rhythm like you said. That's normal tech said its fuel injectors. I give update.
    Hammertimerrrr likes this.
  15. Jul 18, 2025 at 2:32 PM
    Hammertimerrrr
    2024 MGM Limited OR
    Thanks for the update! I don't think it's a catastrophic thing - I've easily driven 7-8k since I noticed it and no performance issues... but would prefer it to not sound like a jalopy :)
  16. Jul 18, 2025 at 3:41 PM
    Woo1178
    Willie
    Silver 25 Tundra SX
    None
    Ditto not all sound like it our friend has a 25 build date in Feb got in March has 8g miles. Got appointment in 2 weeks enginers will look at it fir a few days. Pay 50K shoukd sound like a trash truck. Totally agree with you.
  17. Jul 18, 2025 at 3:59 PM
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    Sounds like the compression shaft is binding up against the blowdown sensor housing assembly.
    Tunrod likes this.
  18. Jul 18, 2025 at 4:10 PM
    Woo1178
    Willie
    Silver 25 Tundra SX
    None
    Is that hard to fix. My friend who's a advisor mention ac or or exhahust pipes. If is the ac issue thing a tear diwn be needed.
