Billet Aluminum triple Baja Designs 3rd Brake Light for 2G Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by Supertoyotabros, Jan 21, 2024.
  1. Jan 22, 2024 at 6:51 PM
    Supertoyotabros
    Supertoyotabros [OP] New Member
    AJ
    Thank you. This exactly what we need to improve on these, This is V1.
    And YES, sealant on that edge is not great, but that’s not the part’s fault.
    About the lens colors, this is what this particular customer wanted, those can be arranged in any manner you want.
    Normally the 2 outside ones would be chase/cargo lights with one acting as brake light.
    Baja used to have a mask inside of all squadron SAEs so having a mask inside is fine for brake lights because they aren’t on as often.
    Pricing could be improved with volume but as of now we are a smaller shop and we can’t make 500 of them without any sales.
    We’re adding antenna mounts to V2, that’s already in the works.
    Camera add-on is also in the works. again, thanks for the feedback.
  2. Jan 23, 2024 at 4:05 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    Butyl tape is a superior sealer, fwiw.
  3. Jan 23, 2024 at 10:07 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Without seeing more details of the construction of it, how the light plate is sealed, etc. it’s hard to really see how it might be lightened up, though I’m certain there’s opportunities.
    I would look closely at how the BPD one mounts - it provides significantly better mount strength over factory without much challenge to how it seals. Their instructions are here and you can see how they add two holes in the flat part of the cab (unlike the Evil mount) and then use a custom clamping “nut” plate that goes on the back side. Part of this is so that they can retain the factory mounts for the re-used factory light housing (not needed in the case of your design). From the look of your design, it looks like something similar for nut plates would be fairly easy to incorporate.
    Using a faying seal, I’d go the route of a butyl gasket myself - another reason to have a more robust mount solution. If made to fully cover the mated surfaces and around the anchoring bolts it would be pretty damn hard to leak.
    As someone sitting here with a pair of S2’s and a set of stubby antennas on my desk that I’m looking to set up on my roof or roof rack for work/chase lights and comms, I see a lot of potential here but just can’t stomach that price for less function out of the box than the others at considerably lower price points. Better looks will only get you a date - if you can’t cook and like expensive jewelry then you’re not marriage material for me.
    I’m less concerned with camera mount options myself, but I’m n=1. If the design is modular enough to accommodate them or allow the use of one like what evil is offering, then no big deal.
    Yes, this is a low volume product in a low volume market, but you’ve got to be careful not to make it a non-seller out of the gate. The right price makes it more appetizing for resellers to jump in board as well.
    Really would like to physically put hands on one to be able to provide better review. It’s hard to do that from a couple internet pictures, no instructions or tear down info, etc.
  4. Jan 24, 2024 at 1:12 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Supertoyotabros[OP] likes this.
  5. Jan 24, 2024 at 4:55 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Also. Not sure about the general public's stomach to poke holes in their trucks, but adding a mod like this isn't done by the faint of heart anyway. A couple of additional holes with rivnuts or a nut plate as @RainMan_PNW pointed out, to help cinch the surfaces together, is something a ton of guys on this forum wouldn't think twice about. With the obligatory 'should only be done by professionals' disclaimer in the installation guide, of course. The truck would benefit from the stability after you add the weight of the housing, lights, antennas, and additional horsepower it's going to give the truck.
    TRDFerguson, texasrho83 and bulldog93 like this.
  6. Jan 24, 2024 at 6:30 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Big fan of rivnuts. Biased of course.
    rockmup and TRDFerguson like this.
  7. Jan 24, 2024 at 6:42 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Are you saying that one should make sure to blind-drill into the roofline airbags, in order to find the most secure mounting points? :monocle:
  8. Jan 24, 2024 at 6:49 AM
    1794TX
    Steven
    N.TX
    '20 1794
    How else would you get those holes in there?
  9. Jan 24, 2024 at 8:34 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I drilled the holes but made sure I didn't puncture anything. All worked out.
  10. Jan 24, 2024 at 9:02 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Just ask yourself “What would Victory 4x4 do?”
  11. Jan 24, 2024 at 9:36 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Shoot all the bad guys and smoke a bunch of cigarettes...
  12. Jan 28, 2024 at 6:54 PM
    Supertoyotabros
    AJ
    It looks like we may be able to retrofit an antenna mount into these lights we already made. Most likely 2 for those who need that.
  13. Oct 1, 2024 at 9:06 AM
    Johnny.SoCalTundras
    Johnny.SoCalTundras New Member
    Johnny
    2016 Toyota Tundra
    Johnny from Socaltundras here, is there a link yet to purchase? Any already in stock?
    reywcms likes this.
  14. Oct 1, 2024 at 9:45 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    I see a link in the very first post
  15. Oct 2, 2024 at 9:20 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    So here are a couple photos of when I installed my EVL MFG 3rd brake light.
    This isn’t for the faint hearted if you aren’t willing to drill into your vehicle - and also, this isn’t just a simple mod. I’m sure this product being offered by @Supertoyotabros will be a similar install process to the EVL MFG 3rd brake light as it requires the entire removal of the OE 3rd brake light assembly to be replaced.
    If you’re going to purchase this one or any other fabrication shops take at 3rd brake lights, you all must drop your headliner. It’s going to sound difficult, but guess what? When you drop a bolt or nut or washer inside or when you’ll have to drill into the roof to install rivnuts, spending that extra hour to drop the headliner will save on headaches.
    Edit:
    Also, I didn’t trust the gasket that came from EVL MFG, so after speaking with Rey, he recommended black RTV. Which has given me ZERO leaking problems after installing this. Only caveat is that it’ll be tough to take out once I gotta fix something up there. I may eventually swap out the black RTV for clear RTV since it’ll be easier to clean upon removal.
    And another note is that if you’re going to drill the holes, I’d suggest put a piece of electrical tape for a stopping point on your drill bit. That way once it penetrates, you can immediately pull it back out without damaging anything internally or over drilling.
  16. Oct 7, 2024 at 5:08 AM
    Johnny.SoCalTundras
    Johnny
    2016 Toyota Tundra
    Idk how I missed that but thanks!
  17. Apr 9, 2025 at 10:37 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    King 2.5s custom gold rock warrior wheels 2020 sequoia LED headlights
    Any update on these? I still see them for sale but just wondering how the final product came out and what tweaks were made.
    how are the sold or tested products holding up after a while?
    any plug and play harnesses available?
  18. Apr 10, 2025 at 6:43 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Paging @snivilous we need to get out billet unit going lol the people are in need my friend!
    RobertD and HulkSmurf14 like this.
  19. Apr 10, 2025 at 7:42 AM
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    Maybe I’m super simple today, I can’t find the price or product on the website.
  20. Apr 10, 2025 at 7:44 AM
    #50
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    shows starting at $499 with no lights
  21. Apr 24, 2025 at 10:43 PM
    #51
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    well, I did a thing and ordered.
    got mine in today, it is a heavy beast. So that is my first concern
    second I want to come up with the most effective way to seal it to the cab, gasket maker and RTV are going to be my method.
    I really like the finish, gloss wrinkle style finish.
    My set up will be, left cargo light, center red brake, right chase light
    Im going to make a plug and play harness for the cargo and brake to plug into the factory plug.
    I will update when I get this going
    HulkSmurf14 likes this.
  22. Apr 25, 2025 at 6:01 AM
    #52
    Tundra1D6
    What about using windshield adhesive?
  23. Apr 25, 2025 at 10:06 AM
    #53
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    Probably a great option. It never breaks down and will keep water out right?
    im willing to apply whatever to make this permanent. I don’t anticipate this ever being removed
  24. Jul 18, 2025 at 8:35 AM
    #54
    subspd
    subspd New Member
    Seth
    SW Florida
    2015 Tundra Platinum 4x4
    Magnuson Supercharger - TRD Exhaust - TRD BBK
    Jeesh these things are all so expensive. Feels like modifying the Morimoto third brake light to accept a strobe light would be another option maybe? Subbing to this thread...
  25. Jul 18, 2025 at 9:33 AM
    #55
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Few options out now for third brake lights with more coming. Grove fabworks has one and a billet one coming from jld.mfg
    subspd and TRDFerguson like this.
