General Supercharger Thread
  1. Jul 17, 2025 at 11:03 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I'd donate them but getting them off/to you might exceed the value.
  2. Jul 17, 2025 at 11:03 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Yes sir, chains, cams, I think the rockers, essentially everything besides the valves
    HulkSmurf14 and mustang67408 like this.
  3. Jul 17, 2025 at 11:04 AM
    snivilous
    SW UT
    Yea if it's like $200 to ship them I'll take them, if it's worth more time and money than that not really worth it imo. They're just gonna sit on my shelf anyway
  4. Jul 17, 2025 at 11:05 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yea
    e30cabrio[QUOTED] likes this.
  5. Jul 17, 2025 at 11:06 AM
    e30cabrio
    I have kids coming & Wife having another surgery tomorrow, so just don't have the bandwidth to deal with it, if someone local wants to do it I can tell the shop they are coming, it's in Glendale
    Maybe send the block? The crank & 7 pistons/rods might be ok?
    :p
  6. Jul 17, 2025 at 6:31 PM
    snivilous
    SW UT
    @reywcms engine update:
    Cylinder 7:
    Current theory we have:
    Ringland broke (not sure why yet). Engine was "fine" and ran for awhile. Rey had ALL of his plugs go bad at the same time at the beginning of the year, probably from so much blowby and the catch can unable to keep up. He replaced plugs, ran fine. Drove it from Oregon to Las Vegas. Blowby at the fractured ring land was slowly carving material out and leaking more and more, but still somewhat functional and able to run. Eventually the compression and blowby were able to wear through the piston skirt. "Coincidentally" this was exactly where the oil squirter was. The piston constantly had oil being sprayed right into the burned through hole, and this was especially bad at bottom dead center where there was 30-60psi of oil coming out a straw half an inch from the hole. This happened once Rey was near Las Vegas and the engine started running terribly----it had been limping by with #7 mostly working, but now #7 turned into an oil chamber and stopped working completely and was pumping oil through the exhaust. The piston wearing down was blowing particulate through the engine and onto the #7 components---the cylinder wall isn't worn down so much as seems to have buildup of the remains of the piston. The rod is discolored from piston residue blasting onto it.
    I think this explains the chain of events that lead to the engine ultimately running bad and why it looks so catastrophic. What we aren't entirely convinced by is what actually initiated this failure. Is it coincidence the oil squirter is exactly where the blow through happened? Maybe. Or did the piston or rings get hot and the oil squirter shocked them and caused a crack? Did it coincidentally fail right there from knock? The top of the piston and the other pistons don't show any signs of knock, but that doesn't mean much. But in all of the ringland failures I've had with other engines, two parts of the ringland crack and the whole chunk breaks free, usually large chunks. But the section of ring land missing is pretty small, so while not impossible is just a much different/smaller ringland failure than I've seen across two other types of engines. Maybe the ringland didn't fail at all? But it certainly looks like something caused all the blowby to happen in this region, which would most likely be a crack in the ringland that was just left unchecked for a long time.
    I've had two engines that cracked ringlands on me, a LS and a 2JZ. Both had the ringland crack in a 90deg+ span, and both kept running totally fine with the only real tell tale being extra blowby that was only visible because the catch can wasn't hooked up yet. It seems likely that was the issue and Rey never noticed since #7 was mostly fine until the hole formed. I just think it's really odd it's right where the oil squirter is, of all places, it's directly above it.
    Nonetheless, very cool failure, rest of the engine and all the bearings look beautiful. I will talk to the machine shop tomorrow about cleaning it up, porting the heads, and some other tweaks and we'll go from there!
  7. Jul 17, 2025 at 6:34 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    OH HO HO HO!!!!!
    reywcms likes this.
  8. Jul 17, 2025 at 6:45 PM
    centex
    centex New Member
    10mins with a welder and some channel locks and it’ll be good as new.
    It looks almost like a torch was slowly working away at it. Piston got a hot spot, oil hit it and cracked it, ignition and heat slowly melted it.
    HulkSmurf14, reywcms and M3Tundra-JK like this.
  9. Jul 17, 2025 at 7:07 PM
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    I took my first road trip with the newly Supercharged Tundra up to Maine about 170 miles each way for 10 days of vacation. It was hot and I hit some stop and go traffic and I was loaded down heavy. The truck did not skip a beat and effortlessly cruised at ahem highway speeds even fully loaded up! I would say it's the best mod you can do with the truck and I am so happy with it! Even turning 37's is effortless now! If you're thinking about it don't hesitate!
  10. Jul 17, 2025 at 7:09 PM
    koditten
    Kirk
    Midland of the Mitten
    Not that I know of, but am interested in being educated.
  11. Jul 17, 2025 at 7:16 PM
    blenton
    blenton New Member
    Hohleey smokez.. :eek2:
    I have a theory..
  12. Jul 17, 2025 at 7:33 PM
    blenton
    blenton New Member
    BTW, FedEx has my blower in transit. It was in NorCal this morning with about 800 miles to go. Supposed to show up Friday by end of day. Who thinks it will actually show up tomorrow?
    mustang67408, HulkSmurf14 and reywcms like this.
  13. Jul 17, 2025 at 7:58 PM
    LILTRD
    LILTRD New Member
    East Bay, California
    2013 Tundra RCSB
    Hidden Winch Lighting Suspension/Air bags Wheels/Tires Audio Center Console swap
    Picked up my Whipple today(finally)as the second box(blower box) arrived at the shop I ordered from. So, I think it will as the delivery time was accurate. Shipped yesterday and arrived today. I'll plan on the thermal blanket application this weekend.
  14. Jul 17, 2025 at 9:05 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That is kinda odd. Usually ring butt ends overheat and touch blowing out the ring land. Gasses trapped and blew? That's one I really wouldn't expect. Pretty wild.
    reywcms and ARES35 like this.
  15. Jul 17, 2025 at 9:08 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @Silver17 mentioned bridge jack for the 4 post but limits amount of work that can be done.
