CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. Feb 25, 2025 at 9:42 AM
    #2911
    blaserdude
    blaserdude New Member
    Eugene
    2019 Tundra Limited Double Cab
    none
    Yep. I waited a couple of weeks and got a discount.
    bc
    OldGuy03 and Wynnded like this.
  2. Feb 27, 2025 at 12:16 PM
    #2912
    blee
    blee New Member
    2017 Tundra XSPX
    So which is the cam tower seal and which is the valve cover seal. I had a little oil but just had an oil change that might have been messy… sprayed it with brake cleaner and keeping an eye on it.. if what I think is the cam tower seal is right is a gray seal.
  3. Feb 27, 2025 at 12:20 PM
    #2913
    blee
    blee New Member
    2017 Tundra XSPX
    Is this the cam tower seal?
  4. Feb 27, 2025 at 1:54 PM
    #2914
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That is correct.
  5. Feb 27, 2025 at 2:14 PM
    #2915
    blee
    blee New Member
    2017 Tundra XSPX
    Got it. Think I’m in the clear on that one but possibly a valve cover seal issue
    Wynnded[QUOTED] likes this.
  6. Mar 16, 2025 at 5:20 AM
    #2916
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    2021, 51k miles. Driver side looks good. Picture below is the passenger side. It looks a little damp/orange. But I also use Amsoil HD metal protectant so I wonder when I was undercoating it splashed on there. Perhaps someone smarter than me can take a look to see if there's more to it. Thanks!
  7. Mar 16, 2025 at 10:27 AM
    #2917
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I see no concerns.
    OHwendTrd[QUOTED] likes this.
  8. Mar 16, 2025 at 6:08 PM
    #2918
    blee
    blee New Member
    2017 Tundra XSPX
    Kind of hard to sea the cam shaft seal in this pic but don’t see anything that looks like an active leak
    OldGuy03 and OHwendTrd[QUOTED] like this.
  9. May 15, 2025 at 8:30 AM
    #2919
    TheBeast
    TheBeast The Beach
    use UV dye in your oil and monitor if you see it seeping. I used that before and after mine was repaired back in 2017. It will ease your mind. Always tough to tell when trying to take a picture.
  10. Jul 17, 2025 at 11:06 AM
    #2920
    subspd
    subspd New Member
    Seth
    SW Florida
    2015 Tundra Platinum 4x4
    Magnuson Supercharger - TRD Exhaust - TRD BBK
    Does this staining look like the leak? So besides paying $6000 for toyota to fix it what do I need to do? Just keep an eye on the coolant level? Truck has 115k miles. Thanks!
    HulkSmurf14 likes this.
  11. Jul 17, 2025 at 11:17 AM
    #2921
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That looks like a bit of rust to me. I recognize no evidence of a cam tower leak in your photo.
  12. Jul 17, 2025 at 11:40 AM
    #2922
    blee
    blee New Member
    2017 Tundra XSPX
    im not seeing anything that looks like an issue here… is this the drivers side or passenger side? If driver side sometimes you could be seeing left over spillage from a sloppy oil change … spray some brake cleaner on it and monitor if you see something but I’m not seeing anything
    subspd[QUOTED] likes this.
  13. Aug 19, 2025 at 9:58 AM
    #2923
    iamsmokey
    iamsmokey Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    Several months later, had any luck with what this is? Mine is identical. 2018, 48xxx miles. Typical cam tower leak locations appear fine, valve covers appear fine. Dipstick reads normal. Just enough seepage for me to want to know what it is. Degreased and cleaned the engine bay, small amount of seepage reappeared in this exact location over the course of 3-4 months on both driver and passenger sides. Took it in to the dealer as I was worried about it being a head gasket (someone else on the forums got told it was the head gasket by their local dealer). Mine said they can't find anything... even after showing pictures and pointing it out to the service advisor...
  14. Aug 19, 2025 at 12:43 PM
    #2924
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
    most dealers will deny seeing anything because they flag rate doesn’t pay enough and it’s such an awful horrrible job the techs don’t want to deal with it
    iamsmokey[QUOTED] likes this.
  15. Aug 20, 2025 at 11:26 AM
    #2925
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    I purchased my truck used with about 130k on it. No idea how it was treated by previous owner. After i had it a bit i noticed stain on heat shield and once in a while i smelled oil when it dripped on hot parts. Saw it was cam tower and figured I'd just watch it until really had to be adressed.
    Changed PCV and sprayed engine cleaner to get oil off engine. Best I can tell it has been dry since. Or if there is oil weeping at all, it is very slight and not enough to form drips anymore that I have noticed.
    PCV may be a cheap bandaid fix for some of you guys too.
  16. Aug 20, 2025 at 6:05 PM
    #2926
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Or a possible preventative?
  17. Aug 21, 2025 at 7:27 AM
    #2927
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    If you are concerned about your head gasket…. There has been a video and discussion of the 5.7 head gasket failure due to galvanic corrosion of the gasket due to “old” coolant. I changed my coolant after six years on my 2018 although I had only 40K miles. I’ll change it every 5 years. (The tech in the video had a few trucks he was scheduled to work on).
  18. Aug 21, 2025 at 10:26 AM
    #2928
    iamsmokey
    Oahu, HI
    Thanks! Yup, have everything I need to exchange the coolant except for the time to do it! Haha.
    WAtundra4x4[QUOTED] likes this.
  19. Aug 21, 2025 at 2:49 PM
    #2929
    TheBeast
    TheBeast The Beach
    I have seen that video but it's missing analysis of the coolant before getting to that conclusion. I recently PH tested a 8 years old coolant and brand new in bottle Toyota before flushing the radiator and they both had the same exact PH/color. Jury is still out imo.
  20. Aug 21, 2025 at 5:12 PM
    #2930
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Lots of folks posting photos questioning if they have a cam tower leak and the photos are spotless. If you have the leak, it will look like my truck here. Had the leak for 70k miles and never got worse. Obviously sweats oil but not enough to drip. Made the decision a long time ago I won’t get it repaired. Just drive it into the ground. Most reliable truck I’ve ever had.
    Tunrod, TheBeast, OldGuy03 and 5 others like this.
  21. Aug 28, 2025 at 3:09 PM
    #2931
    07RCSB
    07RCSB New Member
    2007 Tundra RCSB
    none yet
    I have been looking for a double cab and I have found 4 out of the 5 I looked at had the Cam tower leak. Frustrating because for the most part the rest of the trucks have been in good condition.
