Where did I drop the bolt head washer????
Discussion in '1st Gen Tundras (2000-2006)' started by jeremycasey20, Jul 15, 2025 at 10:20 AM.
  1. Jul 15, 2025 at 10:20 AM
    jeremycasey20
    jeremycasey20 [OP] New Member
    Jeremy
    Toyota Tundra
    Ok, here we go...
    2004 Toyota Tundra, With the 4.7L, 2UZ engine.
    My son and I are in the process of doing a head job, and replacing the head gasket,
    WHEN............................................................................................................
    In removing the "Right" head (Passenger Side), we accidentally dropped the bottom
    Right Head Bolt WASHER (when looking at the head) down the oil passage hole.
    (See Pic's 2, 3 & 4)....
    My question/s are:
    1-Where did the washer go?
    - Did it go straight down to the oil pan?
    - Did it go into the oil pump? (concerned after looking at Pic #5)
    2-What is my next step?
    -Can I just remove the lower oil pan and retrieve the washer?
    -Do I have to remove the oil pump in order to retrieve the washer?
    Additional Information.... We've been trying to use a magnet but have not been able
    to retrieve the washer......
    Thank you for your help, and,
    I used the below linked video, and pictures from the video in an attempt to best illustrate
    what we're going through.
    (Pic 1)
    https://www.youtube.com/watch?v=cRlcN6vRHhg&t=2s
    AD_4nXco4UU-mdZm9caHUODdnWdEkazVSA2Su7uD_dcbb6ddf3f97e6a91d46f958d92f57dc74d3f34d.png
    (Pic 2)
    AD_4nXcB7j7Hyvvq5uueTETNPRj0a4GHMnwHfYkG_8cac4c2097ee6756550662ab51b3a690ea049c53.png
    AD_4nXfd8hqvoUdflITADFMsGwAAa34XzTKF5egi_55593b738ce8f344841a326a666f02fe25fece77.png (Pic 3)
    (Pic 4)
    AD_4nXfdIrIHTWtHtO80DX8qpabOuZDlpqnRbTBI_09b24f83a3eea165ff39054b396bf1376fede59d.png
    (Pic 5)
    AD_4nXcbL0VXrk3gmcezRqt-TPN7CXiBddFQFtkh_bb78d5344a53cff0a5e59711e84fb491d6f684e4.png
  2. Jul 15, 2025 at 1:32 PM
    Look up telescoping magnet. Would that work to fish around and attempt to pick it up?
  3. Jul 15, 2025 at 6:36 PM
    04TundraTRD
    04TundraTRD Once upon a time....
    Neil
    Kentucky, near Louisville
    2004 Tundra TRD 4WD AC
    TRD Supercharger, Bilstein 5100's on all four corners, Setting 4 on the fronts, 1" Front Diff Drop Kit, Suspensionmaxx Front Sway bar end links, 1" lift shackles out back, 1.5" wheel spacers all around, 285/75R16 BFG AT TA/KO2's, Front Brush Guard with 20" LED light bar, Kool Vue Dodge style tow mirrors, Yellow Box Speedo Corrrecter by Yellr, Volant CAI, Banks Monster 3” Catback Exhaust, LED's on the interior, LED Headlamps and LED Back Up Bulbs
    jeremycasey20[OP] and KNABORES like this.
  4. Jul 16, 2025 at 7:52 AM
    jeremycasey20
    Jeremy
    Toyota Tundra
    Morning guys (Shifty & 04 TundraTRD),
    My plan this morning is to go by WallyWorld or Harbor Freight and see about an inexpensive borescope/camera,
    to at least see around the first corner....I just don't want to go further down the rabit hole than I "Need" to, and
    disassemble this thing any more than it already is, if I don't have to....
    Thank you for the recommendation....I'll circle back with pictures, God willing.
    Jeremy
  5. Jul 16, 2025 at 8:36 AM
    Honestly, grab a telescoping magnet while there. The kits with multiple sizes are under $10 last I checked. You may not even need a borescope, just fish around with the magnet and you may pull it up. Depending on where it fell (I'm not drawing a great mental pic), it may have fallen all the way down into the pan, I think, but I'd have expected you to hear something in the moment that was indicative of that.
  6. Jul 16, 2025 at 8:39 AM
    Did you spin the motor upside down on the motor stand to see if it would fall out?
  7. Jul 17, 2025 at 7:21 AM
    jeremycasey20
    Jeremy
    Toyota Tundra
    Shifty,
    Yes, we've tried that ("telescoping magnet"), because you're correct, we definitely "THINK" we heard it "land".....
    Also, the gentleman who completed the valve job agrees with you....thinking it probaly dropped all the way to the pan...
    I'm just worried to drop the pan if it went into the oil pump...but looking at "that" job (removing the oil pump), I have
    to remove the pan anyway.....so I'm thinking I just need to drop the pan no matter what....
    Thank you for your continued input,
    Jeremy
    UPDATE: Ordering a Borescope off Amazon to see what we can see...
    Knabores,
    No, can't flip the motor because it's still in the truck...the pics I used to show what happened was from a youtube video.
    But right there with you, and wish I could have...
    Jeremy
  8. Jul 17, 2025 at 7:42 AM
    Doing all that work on the motor with it still in the truck??? You like pain.
  9. Jul 17, 2025 at 8:19 AM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Get your cars are pain shirt here lol
    KNABORES[QUOTED] likes this.
