Should I Take The Risk
Discussion in '2.5 Gen Tundras (2014-2021)' started by DG868, Jul 16, 2025.
  1. Jul 16, 2025 at 5:29 PM
    DG868
    DG868 [OP] New Member
    2017 Tundra Crewmax 5.7 L
    Looking into buying this one with 180k miles drives very smooth no engine knocking almost sounds better than my ‘17!!!! But noticed this underneath. Should i take the risk on buying it and making the repair? Didn’t notice any stains where it has been parked for the past few days.
    *****2014 Tundra****
  2. Jul 16, 2025 at 5:30 PM
    Have you identified what’s leaking?
  3. Jul 16, 2025 at 5:36 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Looks like it's the rear main seal. Hardly worth crying about.
    2mchfun and Y0TA PR0 like this.
  4. Jul 16, 2025 at 5:40 PM
    Could be cam towers. Valve covers. Literally anything above that spot.
  5. Jul 16, 2025 at 5:44 PM
    DG868
    Didn’t see any other areas with any type of fluids leaking, just that area.
    Henry1jg likes this.
  6. Jul 16, 2025 at 5:44 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    That underneath looks the same as my 15 did.
    Mine turn out to be rear main seal.
    DG868[OP] likes this.
  7. Jul 16, 2025 at 5:50 PM
    centex
    centex New Member
    An oil weep at a 180k would be like item number 865 on my list of things to be concerned with.
  8. Jul 16, 2025 at 5:52 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Pretty sure my rear main is leaking and I'm at 110k
  9. Jul 16, 2025 at 5:53 PM
    Coastal_Tundra
    Coastal_Tundra New Member
    2003 5vzfe 5spd manual 2wd
    +1 for rear main seal.
    Just make sure to top it off before driving off, and replace the oil when you get home. Overall not something that would make me pause.
  10. Jul 16, 2025 at 7:01 PM
    Mdnitedrftr
    Mdnitedrftr TAKITEZ
    Rich
    NW, CT
    '21 1794
    Pardon my ignorance, but if it is the rear main seal, isn't that kinda of a pricey fix?
  11. Jul 16, 2025 at 7:02 PM
    or cam towers. Good to know what you’re up against before making the purchase. May even help negotiate the price based on needed repairs.
  12. Jul 16, 2025 at 7:19 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I'm at 300 and my stain is not that big..
  13. Jul 16, 2025 at 8:09 PM
    Coastal_Tundra
    Fair point. I drive stick, so you usually just get a new one with the clutch. But definitely hum and haw about it and get a discount.
  14. Jul 16, 2025 at 8:25 PM
    2mchfun
    Let this example serve as a reminder to change your pcv valve about every 30-40k or so. Excessive crankcase pressure is hard on seals.
    OHwendTrd and HulkSmurf14 like this.
  15. Jul 17, 2025 at 6:41 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I changed mine and still have the leak :notsure:
    Come to think of it, I don't think I've had a truck that didn't have a little oil coming out of the rear main
  16. Jul 17, 2025 at 6:48 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I'd replace the PCV and call it a win! The RMS seep is typical to clogged PCV...nothing 10 min and a $20 part can't fix...
    OHwendTrd and 2mchfun like this.
  17. Jul 17, 2025 at 6:48 AM
    HulkSmurf14
    2014 Tundra Limited
    All that is ,is horsepower sweat!
  18. Jul 17, 2025 at 7:06 AM
    2mchfun
    Well you may have still prevented other issues such as valve seals leaking and so on. Be glad you don't have a steady stream blowing onto a clutch in a manual, that becomes a problem quickly!
  19. Jul 17, 2025 at 7:11 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Wish I had a manual.
    HulkSmurf14 and 2mchfun[QUOTED] like this.
  20. Jul 17, 2025 at 7:12 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Exactly! Haha
    HulkSmurf14[QUOTED] and 2mchfun like this.
  21. Jul 17, 2025 at 7:18 AM
    2mchfun
    sequential shifting helps ease the pain a little bit:thumbsup:
    HulkSmurf14 likes this.
  22. Jul 17, 2025 at 8:13 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Needs a clutch.
    2mchfun[QUOTED] likes this.
  23. Jul 17, 2025 at 8:43 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Something I did not know to do. At 56k now, I’ll be ordering this part. Thanks!
  24. Jul 17, 2025 at 10:17 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    I think I would be more concerned about the rust I see.
    Fobroader likes this.
