General Supercharger Thread
  1. Jul 16, 2025 at 12:27 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  2. Jul 16, 2025 at 12:46 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Don't the 4 post have an attachment to lift the body for wheel/ axle stuff.
    HulkSmurf14 and Silver17[QUOTED] like this.
  3. Jul 16, 2025 at 1:17 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Yes, typically only one end at a time...and they cost about $2200 for that additional need...youll need more then one to do the entire car/truck...2-post for the win! Build a lean-to on the side and store extra stuff there and outta the way!!
  4. Jul 16, 2025 at 1:18 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Yes you can get bridge jacks for that type of work. A 2 post is still better for body off frame type of work it appears. Also the space is still largely usable and walkable with a 2 post more so than the 4 posts.
    Mdl[QUOTED] and e30cabrio like this.
  5. Jul 16, 2025 at 2:19 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    That’s a 2.9
  6. Jul 16, 2025 at 4:00 PM
    e30cabrio
    It's ready but they say there is oil in the SC coolant. Where would that come from & does anyone know the belt size needed to bypass the 1900?
    Picking it up in an hour, now I have to decide if I want to rebuild the 1900 or go another way Does anyone have a break I can borrow?
    Also Jon Bond or SCOL to rebuild?
    HulkSmurf14 likes this.
  7. Jul 16, 2025 at 4:16 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Who are these people? Really!
    No way for oil to be in SC coolant. Unless the intercooler brick is sitting in oil with a gapping hole. Then you would have coolant in your intake. Don't see it... open coolant hose got contaminated with a little oil?
    You just had SC apart and it looked and sounded fine. Bearings good? If anything pull the ic fuse and run it. It's a closed system.
  8. Jul 16, 2025 at 4:33 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    K080948HD is the stock belt size for the 5.7, that's what I used to bypass my supercharger.
  9. Jul 16, 2025 at 4:37 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Next time your engine blows up let me know and I'll send someone down to pick it up and tow it up here. Pickup and delivery with it guaranteed to work :D
  10. Jul 16, 2025 at 5:03 PM
    HulkSmurf14
    2014 Tundra Limited
    Plus stickers!! And a damn fine burger in Beaver at The Creamery! So many pluses with that offered option!
  11. Jul 16, 2025 at 6:36 PM
    e30cabrio
    Picked it up, feels good, there's something in the SC coolant, is it possible engine oil from the old motor got in there when the motor blew? SC coolant was getting into the intake from the brick.
    IAT was at 101 on the freeway when it was 95 & 60% humidity, got up to 140 at idle which is warmer than I am used to.
    I appreciate the offer, hope it's not necesary.
    HulkSmurf14 and Wynnded like this.
  12. Jul 16, 2025 at 6:44 PM
    Silver17
    Eastern PA
    Glad to hear you got it back! As for your IATs and trying to make a connection to oil in the intercooler circuit, you will find no meaningful data in regards to your IATs since you’re reading it at the MAF sensor before any of that even comes into play. I have no idea why you would have oil in the intercooler circuit. Like MDL said it’s not logical.
  13. Jul 16, 2025 at 7:18 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Maybe one of the I/C hose was in oil or got oil in it. This can cause a film, a little goes a long way. Disconnect the inlet to i/c tank and have it flow into another container an try using i/c pump with hot water in tank. Like a mini flush? Then add your coolant.
  14. Jul 16, 2025 at 7:34 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Glad it’s back up and running!
    Mdl and e30cabrio like this.
  15. Jul 16, 2025 at 7:39 PM
    e30cabrio
    There is no noise, from the SC, it seems fine.
    I'll do it in the morning, thanks
    Thanks.
    Mdl[QUOTED] likes this.
  16. Jul 16, 2025 at 7:42 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Check your coolant level in the little supercharger tank. I wouldn’t worry if the level isn’t dropping.
  17. Jul 16, 2025 at 7:45 PM
    e30cabrio
    I have a big coolant tank, it was full when I left the shop, full when I got home.
    Thanks
    Mdl likes this.
  18. Jul 16, 2025 at 9:27 PM
    blenton
    blenton New Member
    Definitely a Gen 4 2.9L like @reywcms said. Whipple never made a Gen5 kit for the tundra; it was Gen 4 2.9L right up until this year when they switched to Gen6 3.0L. Even those who ordered Gen4 kits a "while ago" were sent Gen6 kits. Knowing it's a Gen4, I would personally skip it and go for a new Gen6 3.0L, even with the discount on that unit. It also bothers me when stuff is posted incorrectly like this unit. It's not a Gen5 or a 3.0L.
    Wynnded, e30cabrio and HulkSmurf14 like this.
  19. Jul 17, 2025 at 8:17 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    It bothers me when people post incorrect information like that. I'll reach out to the seller and let them know.
    e30cabrio, Mdl and HulkSmurf14 like this.
  20. Jul 17, 2025 at 8:29 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Makes me wonder how they came across the items they are selling. Most people that are selling something they purchased know what it is and the details. If it's a shop selling parts from a customer's vehicle they upgraded, they should also know what it is, granted some shops are less-knowledgeable. Or maybe it's from a stolen truck they are parting out...reaching, but I don't trust anyone selling goods on Marketplace or Craigslist, too many scammers out there.
  21. Jul 17, 2025 at 8:37 AM
    Danimal86
    Daniel
    Sacramento, CA
    agreed. The seller is selling a bunch of parts (not just tundra stuff), so maybe they are parting something out or whatnot or maybe they are helping someone sell it that upgraded.
    who knows....i just posted it up in case anyone wanted to look into it.
    e30cabrio, Mdl and armyoffoo[QUOTED] like this.
  22. Jul 17, 2025 at 8:38 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    These posts mostly don't even have the product they're just posting pics of stuff from other adds and scamming people.
  23. Jul 17, 2025 at 9:51 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
  24. Jul 17, 2025 at 10:13 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    bflooks and reywcms[QUOTED] like this.
  25. Jul 17, 2025 at 10:29 AM
    e30cabrio
    Wynnded, Mdl and reywcms like this.
  26. Jul 17, 2025 at 10:32 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Motor sounds smooth glad that machine shop worked out.
    e30cabrio likes this.
  27. Jul 17, 2025 at 10:51 AM
    e30cabrio
    Phoenix was 100% amazing, couldn't have been better. The install was thorny but it's over, hopefully no issues & I am done with this crap for a while.
    Anyone want/need the heads? Pheonix didn't respond to my message asking if they wanted to buy them, motor is sitting on a pallet outside open, free to you guys.
  28. Jul 17, 2025 at 10:59 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I'm sure we can add them to the stock of parts at @snivilous . Have these ported and ready for someone.
    Wynnded, bflooks and snivilous[OP] like this.
  29. Jul 17, 2025 at 11:00 AM
    snivilous
    SW UT
    Read my mind, but only if they're cheap or free considering there's four pairs of heads sitting here right now :rofl:
    Wynnded, reywcms[QUOTED] and Mdl like this.
  30. Jul 17, 2025 at 11:03 AM
    e30cabrio
    Looks like the cams/chains have to come off to get them off no?
