So glad I paid for junk
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by siberian723, Jul 16, 2025.
  1. Jul 16, 2025 at 12:04 PM
    siberian723
    siberian723 [OP] New Member
    2021 Tundra TRD Pro
    2021 Tundra TRD Pro, somewhere around 60k new, 4yrs later here I am looking at a $2100 repair bill on what they think is a bad fuel pump.
    So much for reliability
  2. Jul 16, 2025 at 12:31 PM
    Did you check your VIN for the recall?
    Mr Badwrench likes this.
  3. Jul 16, 2025 at 12:33 PM
    But then again....having only 13 messages since becoming a member in 2020 doesn't say much either. :notsure:
  4. Jul 16, 2025 at 12:38 PM
    I’ll buy this POS from you for the cost of the repair bill, and some skittles for your trouble.
  5. Jul 16, 2025 at 12:40 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah and probably only came on to bitch those other 12
  6. Jul 16, 2025 at 12:42 PM
    siberian723
    2021 Tundra TRD Pro
    yep, not part of it
  7. Jul 16, 2025 at 12:45 PM
    Is yours a flex fuel engine? 3UR-FBE
  8. Jul 16, 2025 at 12:55 PM
    siberian723
    2021 Tundra TRD Pro
    no
  9. Jul 16, 2025 at 1:08 PM
    Is it part of the fuel pump recall? If not, how is a fuel pump a $2100 repair?? Seems to be between $100 and $400 part depending on how much you are replacing. Can’t imagine $1700 in labor to drop the tank.
    Tripleconpanna and snivilous like this.
  10. Jul 16, 2025 at 1:09 PM
    Retired...finally
    How many miles you got on this piece of junk? Trade that junker in one a Ford, Chevy or Ram. They say they are much more reliable.:anonymous:
  11. Jul 16, 2025 at 1:14 PM
    I will one up this guy and offer rainbows and skittles.
  12. Jul 16, 2025 at 1:17 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    That's a bummer. Definitely not a repair you expect from a Toyota truck that young in its life. Have they confirmed it's a fuel pump? That's a big bill for what "they think" is a fuel pump
  13. Jul 16, 2025 at 1:19 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Who is they? Shouldn't be to hard to confirm and shoot down a fuel pump? What symptoms?
    GODZILLA likes this.
  14. Jul 16, 2025 at 1:19 PM
    The fuel pump directly from Toyota ranges 350-365.00.
    I put a 62 gallon tank in my Dmax by myself.
    I would look around on shop labor.
  15. Jul 16, 2025 at 1:21 PM
    siberian723
    2021 Tundra TRD Pro
    that is the quote from the local toyota dealer
  16. Jul 16, 2025 at 1:21 PM
    siberian723
    2021 Tundra TRD Pro
    I probably will
    HulkSmurf14 likes this.
  17. Jul 16, 2025 at 1:22 PM
    siberian723
    2021 Tundra TRD Pro
    140k
  18. Jul 16, 2025 at 1:23 PM
    siberian723
    2021 Tundra TRD Pro
    local toyota dealer, was stalling out after start, sometimes won't start, sometimes dies while driving. Today they told me it wouldn't start at all
  19. Jul 16, 2025 at 1:24 PM
    I would be pissed too, don't get me wrong.
    It might be easier to remove the drivers side bed bolts, loosen the passenger side, prop up the bed using a 4x4. This will give you access to the top of the tank. Don't forget to take the filler neck screws out up top by the door.
  20. Jul 16, 2025 at 1:24 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I used ratchet straps to lower the tank and beer for me...should be easier than you can think...YT University it up and make it happen over the weekend. Perhaps don't use that dealership for the part...also, make sure they can define the "think" part of their suggestion...it is or it isn't, the fuel pump...
  21. Jul 16, 2025 at 1:25 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    That ain't covered under warranty?
  22. Jul 16, 2025 at 1:26 PM
    siberian723
    2021 Tundra TRD Pro
    Yeah I need to go up there and have a serious conversation before they do anything else, they have not even torn it apart to really confirm it, service manager told me today the tech tried to manually force the pump to start and it didn't. So far they seem like they don't have a clue about much
    HulkSmurf14[QUOTED] likes this.
  23. Jul 16, 2025 at 1:27 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  24. Jul 16, 2025 at 1:36 PM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    There is an entire industry built around this stuff breaking. Mechanical items fail, and some vehicles are worse than others. Sometimes it’s just bad luck. Seeing the truck has a 140k miles, I don’t think you can say it’s that big of a surprise if it needs a fuel pump, or perhaps the fuel pump power module has failed.
    2mchfun and ZappBrannigan like this.
  25. Jul 16, 2025 at 1:36 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    In the back of bed or in the frame rails?
  26. Jul 16, 2025 at 1:39 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I'll replace it for $1000 including pump, just drop it off in southern Utah for a day. You can even borrow a vehicle to drive around and see the sights while I work on it. :D
    OldGuy03, bulldog93, 2mchfun and 16 others like this.
  27. Jul 16, 2025 at 2:00 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    You're not getting bent over by an unreliable truck. You're getting bent over by a stupidly high dealership repair quote. Find a trusted local shop (they do exist). Look for local shops that specialize in Land Cruisers or Toyotas in general.
    Not at 140k miles.
  28. Jul 16, 2025 at 2:02 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Some info here. https://www.tundras.com/threads/fuel-control-pump-control-module-removal.141123/
    I initially was thinking fuel pump control module but since they tried to manually run the pump they probably know what they're doing. I don't know if you can run the pump using tech stream or if they tried through module harness?
  29. Jul 16, 2025 at 2:32 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Look there, saving over $1K AND you get to see some beautiful country.
  30. Jul 16, 2025 at 3:52 PM
    frame rails.
    That's a big 'ol boy. Had some 245.00 fill ups.
