  1. Jul 15, 2025 at 3:31 PM
    bflooks
    bflooks New Member
    Metrowest MA
    reywcms, Mdl, bulldog93 and 5 others like this.
  2. Jul 15, 2025 at 3:32 PM
    easleycrawler
    Travis
    Easley, South Carolina
    19 TRD SPORT CM MGM 4WD
    Yep, front windows tinted then black out the interior. No chrome or silver.
  3. Jul 15, 2025 at 3:54 PM
    Boneskull420
    Boneskull420 New Member
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    Once you pop your cherry on the 1st mod its all down hill from there. 1st comes the 1st simple mods then comes many excuses and asking for all kinds of forgiveness from the ol lady :rofl:
  4. Jul 15, 2025 at 4:12 PM
    Cthulhu
    JR, I don’t know if you’ve seen others mention it elsewhere in the forum, but regarding the TRD accelerator, there is a lip/ring around the shaft :rolleyes: circled in the pic below that you think would rest on the interior fender wall to create a seal, but Toyota may have changed the air box size a little bit in the 2.5 gens, and to your point, if you try to use the ring as a seal, you can’t bolt down the front air box bolt. Most of us push the ring through the hole in the fender, and then the front bolt can be tightened down. Yes, a little gap is there where accelerator goes into the hole, but I don’t know if it affects actual intake temps significantly since you’re still not pulling air directly from the engine bay. So you basically have to choose, either sealed and no front bolt, or push it through and bolt it down. Of course I might be talking out of my ass :rofl: since your Stillen box might have a different situation going on. I hope this helps. :thumbsup:
  5. Jul 15, 2025 at 5:50 PM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    Snagged this the other day for wireless Android Auto, and to my surprise, it works like a charm! We'll see how long it lasts
  6. Jul 15, 2025 at 5:53 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Keep me posted in that Amazon wireless AA/CO adapter! My Motorola is shit if it's warmer than 70°F!
  7. Jul 15, 2025 at 5:58 PM
    What suspension are you putting on it?
  8. Jul 15, 2025 at 5:59 PM
    HulkSmurf14
    2014 Tundra Limited
    The ballin' Billies?!
    Tripleconpanna likes this.
  9. Jul 15, 2025 at 6:00 PM
    I don't ask. I just do it and make sure the costs are unknown.
  10. Jul 15, 2025 at 6:02 PM
    They sure are pretty aren't they? :D
  11. Jul 15, 2025 at 6:18 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    A icon set that’s been rebuilt with custom valves and upgraded seals. It will have all the clicks necessary to sit In a mall parking lot.
    bulldog93, Yota303, bflooks and 8 others like this.
  12. Jul 15, 2025 at 6:18 PM
    Henry1jg
    MI
    It was 91° today and working just fine!
  13. Jul 15, 2025 at 7:05 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :benchpress:
  14. Jul 15, 2025 at 7:33 PM
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    Those look great. Question on your front set up? Did they come set up or did you adjust them before install? What's height did you go with?
  15. Jul 15, 2025 at 7:37 PM
    bmw345
    bmw345 New Member
    CT
    Napa covered the new front replacement rotors which pulsated slowing down from highway speeds after 15K miles. New pads not covered but installed.
  16. Jul 15, 2025 at 9:06 PM
    bradj1
    bradj1 Ol' Blue
    Salt Lake City
    2018 CM TRD Limited Calvary Blue
    Land Cruiser blower motor upgrade. Moves air a lot better than stock.
  17. Jul 16, 2025 at 12:20 AM
    They come preset to their highest setting right out of the box.
    reywcms, Tripleconpanna and ATV25 like this.
  18. Jul 16, 2025 at 3:08 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    I'm going to install the Fumoto valve on the next oil change coming up. I like your setup!!
    Dr3wski[QUOTED] and BR73 like this.
  19. Jul 16, 2025 at 3:10 AM
    Corndog123
    Sam
    Tennessee
    Get off my lawn!!! 1969 here as well. Will be 56 next month. Yaaaaay!
  20. Jul 16, 2025 at 3:33 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Sam you will like the Fumoto valve.I have one on my 2020 Tundra and the wife's 2022 Tacoma.The first oil change on the Tundra was a struggle with the plastic oil filter housing being waaay too tight and had to remove it with a 1/2 drive impact. Luckily I had already purchased a metal housing so I swapped it out with the correct center tube.All is good now PXL_20250517_210945276.jpg PXL_20250517_210920439.jpg Screenshot_20241214-145727.png
  21. Jul 16, 2025 at 3:37 AM
    Corndog123
    Sam
    Tennessee
    I may switch over to the aluminum filter housing as well. The plastic one has been fine but I like things to be stronger than they need to be.
    Thank you so much for the info!!!
  22. Jul 16, 2025 at 3:43 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    That was my thinking also especially when it wouldn't come off without force.I was afraid of the threads being damaged.Dang dealership did a presale service and had a gorilla doing the oil change.... Lawd
  23. Jul 16, 2025 at 3:52 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Be sure to get the right one (Toyota OE), not any type of aftermarket brand, and ensure it has the right tube length. I ended up going back to the plastic OE. Edit: I also change my own oil so I don't worry about over-tightening.
  24. Jul 16, 2025 at 3:54 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    I've had one of the aftermarket housings for over a year and no problems
  25. Jul 16, 2025 at 3:55 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    :thumbsup: oil problems don't occur quickly.
    HulkSmurf14 and Corndog123 like this.
  26. Jul 16, 2025 at 4:04 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
  27. Jul 16, 2025 at 4:14 AM
    trevorklat
    trevorklat Don't Mess with Texas!
    The Lone Star State
    2018 Super White Platinum Tundra 4WD CM
    Linex bed liner, Retrax roll-top bedcover, Ranch Hand Summit brush guard, SDHC ABS sensor guards, Interior LEDs, Cargo lamp LEDs, Reverse Light LEDs, Rear TRD sway bar, Valhalla's Shield Cat plates, Husky floormats
    What model are those?
  28. Jul 16, 2025 at 4:46 AM
    Henry1jg
    MI
    This was actually my thought process as well. I bought a spare just in case something were to happen to the original
    OHwendTrd[QUOTED] and Corndog123 like this.
  29. Jul 16, 2025 at 5:11 AM
    Corndog123
    Sam
    Tennessee
    Yeah, I've seen people get crazy with an impact as well. It doesn't need THAT much!!!
    OHwendTrd and BR73[QUOTED] like this.
  30. Jul 16, 2025 at 5:21 AM
    MGMTundra18
    MGMTundra18 New Member
    Charlotte NC
    2018 MGM Tundra 4x4 TRD Sport
    Pulled into the garage last night at all 9's
