Spring Compressor
Discussion in 'Suspension' started by RickPlatinum2020, Jul 11, 2025.
  1. Jul 11, 2025 at 6:31 AM
    RickPlatinum2020
    RickPlatinum2020 [OP] New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    All, looking to change out front struts, what kind of spring compressors have you folks used? I saw some on Amazon that looked kind of good, but the reviews showed they were creaking and bending and just overall not too safe. The springs on these trucks are pretty beefy, do not want to cause more problems than it is worth. There are some real nice ones out there, but they are about $1k, I will not use it that much, easier to pay someone at that point...
    Just looking for some ideas.
  2. Jul 11, 2025 at 7:26 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I have used these on my truck without issue.
    https://www.autozone.com/test-scan-...p/oemtools-strut-spring-compressor/555557_0_0
    For me, at least, I have found them to be acceptable if you follow every best practice and only compress the springs enough to relieve tension, not to complete compress them. Always do the work with the springs laying on the ground, feet and limbs out of the way, compressing both sides equally vs one side completely and then other (think u-bolt). They are tight, but they do fit our springs.
  3. Jul 11, 2025 at 7:33 AM
    caboj
    caboj New Member
    CA
    2018 CM TRD OR
    Used the same, they work perfectly fine. Make sure end pieces are fully seated on spring, keep rods directly across from each and parallel, evenly tighten and un tighten. They rent out those, you essentially buy them, then you get your money back upon return.
    bflooks[QUOTED] likes this.
  4. Jul 11, 2025 at 7:43 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
  5. Jul 11, 2025 at 7:43 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I do believe that is how I ended up with them in my toolbox. They worked so well I figured it was worth having, and they were brand new when I rented them. I watched them walk over to the shelf, pull them, and then take the plastic wrapper off.
    caboj[QUOTED] likes this.
  6. Jul 11, 2025 at 10:02 AM
    art64
    art64 New Member
    I bought one of those hydraulic ones from Amazon. Used it a few times when I swapped coil springs on my King shocks. Comes with different forks for different size coil springs. I haven't checked on it to see if the hydraulic jacks are still good. Last used was 2017, 2018. I was planning on swapping to 700 lb springs.
  7. Jul 11, 2025 at 8:42 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Short of getting something wall mounted or hydraulic, this style is the way to go. I have the exact same thing. Way safer than the cheap ones you can buy or rent. I've used them for two spring replacement jobs but...I had to compress the springs multiple times each job to get the shock/spring alignment just right. So I've probably used mine a dozen times and they still work great. And they're pretty damn cheap.
    I've used the type below and lived to tell the tale, but anyone who has ever used this type didn't enjoy the experience. And they're what, like $10 cheaper?
  8. Jul 11, 2025 at 8:57 PM
    2mchfun
    Bought me a used Branick 7200 a long time ago and it gets the job done easily in a matter of just a few minutes. A very good choice IMO.
  9. Jul 13, 2025 at 11:05 AM
    blenton
    blenton New Member
    Those Branicks for for $500 used these days. But that's they way to get it done.
    I went for the middle ground and got one of these hydraulic compressors. It's seen some good use already. This weekend I helped a neighbor kid install 6112's; they were set at max height be we knocked them down to 1.9". He fought the standard McPherson strut type compressors for nearly an hour to get one side swapped around before he called me. I brought over the hydraulic unit and it took all of a couple of minutes to pull the shock assembly apart, move the circlip, and reassemble.
    https://www.amazon.com/VEVOR-Compre...hvlocphy=106466&hvtargid=pla-4583520404546125
    chugs and 2mchfun[QUOTED] like this.
  10. Jul 13, 2025 at 1:15 PM
    Daedalus
    Daedalus New Member
    Another vote for the Bilittools one.
    Just used this the other day. 14mm socket for the bottom bolt, and coincidentally it’s the same size as the top nut on the strut.
  11. Jul 13, 2025 at 5:51 PM
    RickPlatinum2020
    Rick
    Eastern PA
    Thanks everyone! I may buy a Bilittools set, look pretty safe and useful
    2mchfun likes this.
  12. Jul 13, 2025 at 5:58 PM
    2mchfun
    IF a man can buy right, use, and sell it is nearly free. Just need to have good luck and some play money. Good on you for helping a man in need!
    blenton[QUOTED] likes this.
  13. Jul 13, 2025 at 6:02 PM
    Superdave1.0
    Superdave1.0 New Member
    Dave
    LX470, 2025 Civic Si
    I had one of these. Bent the whole thing badly on the first set of 6112 I did.
    Since I do a ton of suspension, I bought a Branick 7600 brand new. It's by far the best and safest way to compress a spring. You get what you pay for.
    Lord Helmet and 2mchfun like this.
  14. Jul 13, 2025 at 6:11 PM
    blenton
    blenton New Member
    Can’t argue with that. Still much better than the small McPherson type compressors, IME. I made it half way through one spring with those and they were bent like a banana. The cheap tower has done 6112’s four or five times, several sets of stock tundra coils, DK 2.0 and 2.5’s, and a handful of others. I must have got lucky.
    Superdave1.0[QUOTED] and 2mchfun like this.
  15. Jul 13, 2025 at 6:14 PM
    blenton
    blenton New Member
    That’s the problem - I can never find a decently priced one when I need it! May have to start using my Milwaukee tool buying approach - just buy it when I find a good price and put it on the shelf.
    2mchfun[QUOTED] likes this.
  16. Jul 13, 2025 at 6:20 PM
    blenton
    blenton New Member
    Sorry - wrong thread…
  17. Jul 13, 2025 at 6:23 PM
    MT-Tundra
    Montana
    For someone with a shop, that's the way to go. For those of us doing our wrenching out in the gravel and no garage storage, even deciding to buy a spring compressor at all is questionable. For me, not having to rent one of the crappy ones, and the small size of the bilitools one made it worth buying. I did a lot of wrenching for years before deciding a floor jack was worth the space it took up, and it's a pretty critical tool for anyone doing most of their own work. I have mine sitting in the living room right now. I have to carry it up a flight of stairs and out the door and use it in a gravel driveway... :D But I'm still happy with that decision.
    blenton and 2mchfun like this.
  18. Jul 13, 2025 at 6:23 PM
    2mchfun
    Estate sales and pawn shops brother! Buy right and you can almost always get your cash back if you need to for some reason. I like eBay too because in the event of a loss it will be very easy to prove my purchases to an insurance adjuster.
  19. Jul 15, 2025 at 9:35 AM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Made my own for the shock change over I just did. I was kind of a necessity thing as they gave my wife the wrong spring compressor kit at Oreilly's. We live 45 minutes from town and its 45 minutes to get down the mountain to the main highway to go to town. I had already pulled the truck apart by this point. I used 1/2 all thread and hooks from old ratchet straps. It worked great with 0 issues and no flexing of the all thread or the hooks. I did both sides and even had to go back into the first one I did as I inadvertently mounted the seat for the spring upside down.
  20. Jul 15, 2025 at 1:09 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I don't know if the second gen trucks are setup the same way, but there is a method without a spring compressor. On my old T4R and my truck before I had adjustable coilovers I did my suspension work this way. Coilover stays bolted in and you use your jack to compress the spring.
