  1. Jul 14, 2025 at 2:38 PM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Finally installed my Stillen CAI. Thanks to @TacomaTRD4x402 for the plexi lid and info. Installing the box bolts and TRD airflow accelerator was a b****. I only ended up using the rear bolt. The front hole wasn’t even close to lined up in my truck. But looks good.
    Also did the first wash of the summer :anonymous: and retro TRD vinyl on the grill.
  2. Jul 14, 2025 at 2:54 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Looks good! :thumbsup: Nice lookin truck!
    HulkSmurf14 and RobertD like this.
  3. Jul 14, 2025 at 3:18 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Lid is awesome... I need to do that to my Stillen .Stuff a 42" light bar in that bottom bumper hole too PXL_20250711_204817123.jpg PXL_20250301_194637620.jpg PXL_20250312_002148921.jpg
  4. Jul 14, 2025 at 3:20 PM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    Thanks for the details! By Jim, do you mean the Genuine Cooling Systems package, or is there another I am unaware of?
    I monitored my transmission temps for the first time yesterday, I bought an Xtool A30M for my upcoming drain and fill.
    I was pulling my boat with the fam and a light load in the truck, certainly no more than 1500lbs for the boat & trailer combined (old aluminum 14' Jon) and no more than 700 total pounds in the truck.
    It was 85° out and I was seeing high 220s most of the trip, saw some 230s, and a spike of 251. I was going 79 (speed limit is 75 in mid MI), had tow/haul mode on, but let the truck do its thing. I didn't feel like the lite boat and low payload of the truck called for me to be using s4.
    This obviously concerns me a bit and makes me think I need to explore a cooler. When I take the same trip next week, I will pry slow down to low 70s and see what type of difference that makes temperature wise
  5. Jul 14, 2025 at 3:39 PM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
  6. Jul 14, 2025 at 3:42 PM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    woah. i got an 18 w/ the factory cooler. towing 5K trailer, in the heat and up steep grade and i rarely saw over 220 and it quickly dropped back down.
  7. Jul 14, 2025 at 4:30 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Installed the raingler attic net and its awesome. So much extra storage and it does not obstruct the rear view mirror. Really impressed.
  8. Jul 14, 2025 at 4:41 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
  9. Jul 14, 2025 at 4:49 PM
    therealjonwick
    JR
    2019 OR
    Light bar looking good! My bumper shims prevent it. Have to figure something out. Or just get a new bumper haha. What paint did you use on the lid? Wanting to do the Stillen tube and my engine cover letters.
    BR73[QUOTED] likes this.
  10. Jul 14, 2025 at 4:51 PM
    Xcumminsguy
    NY
    All said and done I think I’m in for 420.00 ‘ish.
  11. Jul 14, 2025 at 7:10 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    AutoZone sells touch-up pens that have a brush along with the pen applicator in Toyota factory colors.Make sure to clean the surface with an alcohol rub and scuff it so the paint will adhere. What fasteners did you use on your lid?
  12. Jul 14, 2025 at 7:21 PM
    Henry1jg
    MI
  13. Jul 14, 2025 at 8:07 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    S4 is your friend while towing... It allows the TQ to lock up in 4th (which it won't do in drive) and this keeps your trans temps a bit cooler as it's a 1:1 ratio. The engine will work a little harder, but it won't be shifting so much and bouncing up and down in gears especially on grades :thumbsup:
    This video is dry AF in terms of delivery, but if you can sit through it, it will give you an idea of what's happening with the gears, clutching, and other operations of our transmissions and the they work through the various gears. It will also demonstrate why S4 allows for significantly cooler operation, especially while under load...
    https://youtu.be/YM40HOYtLNc
  14. Jul 14, 2025 at 9:43 PM
    Bham TRD
    Bham TRD New Member
    2017 Tundra Platinum 4WD CrewMax
    Wait until morning, drain the pan, measure how much came out, put that much back in, plus a slight smidge for what stayed in the original pan before you measure it.
    I use Kool-Aid pitchers that have markings on them.
    Did this on my GX for years & 200k plus miles and never had any issues.
  15. Jul 15, 2025 at 3:41 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    I've towed our boat (~5,500lbs) through mid-MI and upper-MI several times, slowing to 70 will only help to save on gas. As stated above, S4 is your friend while towing.
    I put together a cooler kit with OEM parts, Setrab cooler and a bracket another member designed and supplied the file for, just have to find time to install it
  16. Jul 15, 2025 at 8:39 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    It's been a dusty week for the truck. Two separate hay hauls, this one being the smaller of the two but damn, I am NOT 18 anymore...500 bales over two days has reminded me of parts of my body I forgot existed.
    I'll tell you though, being classically trained in OG Tetris on the original NES has never paid off more...:amen:
  17. Jul 15, 2025 at 8:46 AM
    That reminds me about the vinyl option....
  18. Jul 15, 2025 at 8:50 AM
    I'm looking into a different approach on those bolts that will make life easier.
  19. Jul 15, 2025 at 9:01 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    I’ve used that skill maaany a time lol
  20. Jul 15, 2025 at 10:16 AM
    therealjonwick
    JR
    2019 OR
    It was absurd. Even if I didn’t use the TRD accelerator, the front one wouldn’t line up. Also, the actual hole in my truck for the front bolt was super shallow and the screw would turn maybe once or twice before bottoming out. Idk if my truck was messed up? I’m interested in what you come up with.
  21. Jul 15, 2025 at 12:00 PM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
    I started to sweat just looking at that picture.... brings back some not so fun memories!
    Dad = "What are you doing next weekend? Its Father's Day and I'd like for you to come home"
    Me = "No problem, Dad, I will see you next weekend"
    Dad = "GREAT! We are putting up hay!"
  22. Jul 15, 2025 at 12:30 PM
    Fergie
    Fergie New Member
    Had a similar pattern w my Dad, but it was usually to go wood cutting and stack the wood...and split the wood...and bring a bunch up to the house.
  23. Jul 15, 2025 at 12:34 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Watch that front passenger side mat. The one in our Sequoia would always come loose from the floor and shift around too much. Now it hardly has form fit capability so I removed all of them and went with Husky. MUCH better, imo.
    ToyoMafia and bulldog93 like this.
  24. Jul 15, 2025 at 12:48 PM
    250000yota
    Russ
    Berthoud, CO
    That's pretty close to what he said in a text Sunday night at around 10:30.
    Dad-"You working tomorrow?"
    Me-"No, I've got the kids, Emily is working, why?"
    D-"Bring them down, your mom would love to see them."
    M-"ok, that'll be fun."
    D-"She can watch them while I bale, I've got 45 that need delivered. Think you can handle that?"
    :anonymous:
  25. Jul 15, 2025 at 1:28 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Picked up the wheels from the powder coating company. New rubber and OEM TPMs installed. Just need to finalize an order with @memario1214 so I can get the suspension going. IMG_2038.jpg
  26. Jul 15, 2025 at 2:29 PM
    easleycrawler
    Travis
    Easley, South Carolina
    19 TRD SPORT CM MGM 4WD
    Got back In a Tundra, after a little over a year without.
  27. Jul 15, 2025 at 3:13 PM
    ToyoMafia
    Magic carpet.
    Congrats man.
  28. Jul 15, 2025 at 3:20 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Welcome back.
  29. Jul 15, 2025 at 3:23 PM
    easleycrawler
    Travis
    Appreciate it. My 1st two was a 14 double cab 2wd and a 17 double cab 2wd. This is my 1st crewmax, really liking it, plus it's 4wd.
    Appreciate it.
  30. Jul 15, 2025 at 3:29 PM
    TacomaTRD4x402
    Southern California
    She's a beauty! Welcome back. What's gonna be the very first mod?
    Mine was tint the front windows. That's a must for me. Then it spiraled outta control.
