2025 Tundra Hybrid disable start/stop
Discussion in '3rd Gen Tundras (2022+)' started by 308sniper, Jul 14, 2025.
  1. Jul 14, 2025 at 4:14 PM
    308sniper
    308sniper [OP] New Member
    James
    2025 Tundra Hybrid
    This truck turns off a dozen times just going to the store. There is no way that can be good long term. Since it';s a hybrid there is no button to disable it. Anyone have a solution to this?
  2. Jul 14, 2025 at 4:15 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Trade it in for a non-hybrid.
  3. Jul 14, 2025 at 4:18 PM
    308sniper
    James
    2025 Tundra Hybrid
    Can't afford to trade a truck with 2000 miles on it.
  4. Jul 14, 2025 at 4:20 PM
    WindChillYeti75
    WindChillYeti75 New Member
    2025 WCP Limited TRD Off Road iForce Max
    It is perfectly fine and normal. The actual starter doesn’t start the truck hardly ever (only after you fill up at the gas station). The HV electric motor that’s sandwiched between the engine and transmission starts up the engine mostly.
    messagelost likes this.
  5. Jul 14, 2025 at 4:24 PM
    308sniper
    James
    2025 Tundra Hybrid
    It's almost a seamless action. I'm concerned about wear from no oil pressure constantly. Haven't been through a winter yet so will see how that affects warmup etc.
  6. Jul 14, 2025 at 4:37 PM
    WindChillYeti75
  7. Jul 14, 2025 at 5:08 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Weird, never had this probem or notice any shutting off. Maybe you push the brakes too hard ?? In park, I'll hear engine shut off, which is a plus not a negative as don't need whole engine running to enjoy the radio.
  8. Jul 14, 2025 at 5:10 PM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    You want your hybrid to not be a hybrid?
    js312, Raven67, vtown76 and 2 others like this.
  9. Jul 14, 2025 at 5:32 PM
    Maine TRD PRO
    Maine TRD PRO New Member
    2023 Ice Cap Tundra TRD PRO(Rioja Red interior)
    Start/stop is great on the hybrid. Tf?
    Siblue, GoHuskers and Tundrastruck91 like this.
  10. Jul 14, 2025 at 5:33 PM
    Maine TRD PRO
    Can confirm it’s all good in the winter. It doesn’t turn off really below a certain temp
  11. Jul 16, 2025 at 5:05 AM
    nodak67
    nodak67 New Member
    JR
    there is no traditional starter on bof hybrid currently so i dont know why the concern (and that is why there is no button to turn it off on a hybrid) unlike the non HV models which have one)
    since the hybrid motor is sandwiched between the engine and transmission, it solves the problem of having a conventional starter.
    on the hybrid there is sorta like a clutch pack that either
    engages the engine directly to the hybrid motor which then engages the transmission
    or
    the clutch pack disengages the motor (and turns it off) from the hybrid pack and runs the transmission directly
    to the start the engine the clutch pack engages with the hybrid motor and it fires up
    this is just in a nutshell how it operates
  12. Jul 16, 2025 at 6:27 AM
    kjinxx2
    kjinxx2 New Member
    It's an interesting question but I'm pretty confident that Toyota's got the engineering down pat in their hybrids. The oil pressure gauge does drop to 0 when the engine turns off while driving (at least it displays 0), I'm not sure if it actually is dropping to 0 but I would imagine it is working as intended.
  13. Jul 16, 2025 at 6:31 AM
    Maine TRD PRO
    I mean, the ICE literally turns off
  14. Jul 16, 2025 at 6:38 AM
    kjinxx2
    kjinxx2 New Member
    Yes I know - OP said they were concerned that oil pressure dropped (i have no idea what the concern is) and somebody said there is an electric oil pump. I was just saying that the oil pressure does drop to 0 even when the engine is off and the electric pump is not maintaining pressure. I have no idea why you'd be concerned about it
    Maine TRD PRO[QUOTED] likes this.
  15. Jul 16, 2025 at 8:04 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    Toyota has this system down, they've used it on many platforms with no issues for almost 30 years. It's not the same system as the non hybrid start/stop feature. It's a non-issue
    I'd be much more concerned about getting a 500 and 1000 mile break in oil change done
    messagelost and kjinxx2 like this.
  16. Jul 16, 2025 at 8:08 AM
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    So frequent starts with zero oil pressure on an ICE is a non-issue? How does Toyota's system deal with it, if at all?
  17. Jul 16, 2025 at 8:12 AM
    kjinxx2
    kjinxx2 New Member
    I just read on another forum:
    This concept (though not necessarily disabled cylinders) would make sense - that the electric motor cycles the engine very briefly to rebuild pressure and lubricate components.
  18. Jul 16, 2025 at 8:13 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    Yes, non-issue! I can't tell you how they deal with it, I can tell you they've been building them for almost 30 years and they've remained one of the most reliable manufacturers, at least until recent events.
    As others stated, I'm not sure that the oil pressure goes to 0psi, the gauge may just be indicating the ICE is no longer running.
    It seems most likely that there's a check valve or something in place to maintain oil pressure.
    Tundrastruck91 likes this.
  19. Jul 16, 2025 at 8:15 AM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    Huh. Wonder what that noise is when I start after a fill up?
  20. Jul 16, 2025 at 8:20 AM
    jctmundra
    Northern VT
    Guess I better stop running all my ICE engines as starting with zero oil pressure is a reliability concern.
    Seriously, without a prelube system which it not typical from OEM, how do you generate oil pressure without a crankshaft rotating? Seems we have been starting ICE since inception with 0 oil pressure until it starts.
  21. Jul 16, 2025 at 8:24 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    How does crank shaft rotation affect oil pressure when the oil pump is electric?
  22. Jul 16, 2025 at 8:34 AM
    jctmundra
    Northern VT
    vtown76 and sudobash like this.
  23. Jul 16, 2025 at 8:45 AM
    kjinxx2
    kjinxx2 New Member
  24. Jul 16, 2025 at 8:45 AM
    WindChillYeti75
  25. Jul 16, 2025 at 9:03 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    That was just Google AI, and after reading a bit about it, it looks like it may be mechanically driven, electronically controlled, using about 10 psi until 3000 rpms. Then going to 40 psi above 3000 rpms.
    Nevertheless, I haven't seen or heard of any TSB's or recalls, or failures due to oil starved engines in the hybrid systems going back almost 30 years.
    Not trying to be the KBW, but you may be fixating on an issue that isn't there
    vtown76 likes this.
  26. Jul 16, 2025 at 9:05 AM
    tronz151
    tronz151 New Member
    2024 Tundra Platinum
    The transmission has the electric oil pump not the engine. He talks about it at 10:18.
  27. Jul 16, 2025 at 9:13 AM
    sudobash
    sudobash New Member
    Nope.
    jctmundra likes this.
  28. Jul 16, 2025 at 9:13 AM
    sudobash
    sudobash New Member
    Nope.
  29. Jul 16, 2025 at 9:13 AM
    sudobash
    sudobash New Member
    Yup. This is the correct answer.
  30. Jul 16, 2025 at 9:17 AM
    WindChillYeti75
    That’s what it was. My bad!
    sudobash[QUOTED] likes this.
