Leaking valley plate / heat exchanger
Discussion in '2.5 Gen Tundras (2014-2021)' started by Gene_in_FL, Dec 13, 2023.
  1. Dec 18, 2023 at 8:22 PM
    Gene_in_FL
    Gene_in_FL [OP] SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    If I understand your question correctly, I would say yes, the $800 was BS. We're talking about the short stubby tube with O rings at each end, right?
  2. Dec 18, 2023 at 8:55 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I recently did my water pump and was still smelling coolant. Come to find out it was a squeeze clamp that I'd neglected to secure back on. However, I still caught faint whiffs of Pentofrost so upon closer look, I saw traces of dried coolant on rubber hoses with dried splatter in the proximity. Noticed I was losing coolant out of the reservoir. Come to find out there's a small squeeze clamp that holds the overflow hose to the bottom of the tank and it was a mite weak for my taste. I put a real hose clamp on it and filled up the tank to the full line. Will see tomorrow how it looks when I get home from work.
    To make this relevant, I too went looking for the dreaded valley leak and didn't see anything close to what you see. Damn sure didn't have coolant running down the under carriage. Whew.
    Gene_in_FL[OP] likes this.
  3. Dec 18, 2023 at 9:00 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Does it tie into the pump itself?
  4. Dec 19, 2023 at 5:06 AM
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    Yup. Thanks for perspective
    Before work started w warranty the warranty group said the pipe wasn’t covered. I told dealer to go ahead w repair since at that point I thought it was a warranty issue. I had them save the part. So then I started discussing w warranty just to finally get to the point that it is just the part not covered. If dealer just replaced the o rings then that was covered. I said I wasn’t worried about $20 part but the labor to do it. They said dealer never put in for the labor and seems like double charged. Now I’m trying to get ahold of service manager.
  5. Dec 19, 2023 at 7:55 AM
    tyr0981
    tyr0981 New Member
    07 TRD Tundra 5.7
    Head unit, sub's , components, front / back camera's, too many lights to mention, dual battery, winch / bumper, TRS projector headlights, roof nest hard-shell, integrated backup spot lights, vault, all aluminum radiator / water pump, tailgate storage, plenty of dents and scratches
    To get the valley plate out and redo the FIPG of the plate, the inlet pipe has to be removed to get the plate out, because the pipe feeds coolant into the valley plate. That should be written into the procedure i think? :confused:
  6. Dec 19, 2023 at 10:20 AM
    bfunke
    bfunke Tundra Curmudgeon
    Yup you never reuse o-rings on Toyota water pipes.
    pro2amendment likes this.
  7. Dec 19, 2023 at 10:36 AM
    Jaywhy
    Jaywhy New Member
    Jeff
    2016 SW TRD Pro CM
    I noticed coolant running down the transmission a few weeks ago and when researching possible issues came across this video: https://www.youtube.com/watch?v=PnUL0GR6mfs
    He does a pretty solid job of showing how to correct it, but there is definitely some critical steps left out.
    My truck is going in for a new timing chain tensioner (so new chains, sprockets, water pump, etc) and a preemptive cam tower fix since he's 90% of the way there anyway. Mechanic said he'd solve the leak for cost of parts since he's gonna be so deep inside the engine anyway. ~$5000 for the whole shot in case you're curious.
  8. Dec 19, 2023 at 4:16 PM
    pro2amendment
    Indiana
    Bullet liner
    Bingo! Thanks. The part right at 6:54 that’s sticking out of the plate cost me 800 ADDITIONAL dollars to replace saying they “had to dig further”. Super helpful to clarify where it is.
  9. Dec 19, 2023 at 5:30 PM
    tyr0981
    tyr0981 New Member
    07 TRD Tundra 5.7
    AMEN Brother!
  10. Dec 20, 2023 at 3:37 PM
    Gene_in_FL
    FLORIDA
    It sounds kinda like doing a tire rotation for $20, and then charging an extra $10 to remove and reinstall the lug nuts.:rofl:
  11. Apr 21, 2025 at 8:41 AM
    BA_from_GA
    BA_from_GA New Member
    Figured i'd revive this discussion rather than post a related question independently. Have this leak that's just shown up on my '16 1794 CrewMax w/ 217k miles.
    Planning to handle it myself. Process videos on youtube are pretty good guides, as is the discussion here. My main question is what else should I replace while i'm in there?
    backcountryj likes this.
  12. Apr 21, 2025 at 10:04 AM
    2mchfun
    Much depends on your budget and how long you intend to keep it. Personally, I would do water pump, thermostat, secondary air injection valves, all coolant hoses, the fan/serp belt, the belt tensioner, flush out the heater core, and of course clean the throttle body while it was all apart. At that mileage, maybe even a new radiator. Just my .02 :thumbsup:
  13. Apr 21, 2025 at 10:31 AM
    backcountryj
    backcountryj New Member
    GA
    2016 Crewmax
    Where are you in GA? My 2016 will also need this repair at some point. Currently just feeding it the pink stuff as needed and rolling :anonymous:
  14. Apr 21, 2025 at 10:40 AM
    BajaTurd
    BajaTurd Burrito Champion
    Aj
    San Diego
    19 4x max
    Camburg uppers Kings Deavers
    FYI if you are going to a dealership, and you've been a long-time customer, use TFS, multiple Toyota owner or vehicle is just out of warranty. Go ahead and call Toyota customer service and let them know the situation. They will negotiate with the dealership A LOT of the times. Usually cover parts you pay labor or the whole thing. I got this covered and I was out of warranty. This can apply to any failure/repair.
  15. Apr 21, 2025 at 1:56 PM
    BA_from_GA
    Buford.
    Unfortunately (or maybe fortunately?) I'm not a dealership customer. Owned multiple toyota's but all purchased used outside of warranty. O-rings and FIPG are gonna run me less than $80 from the dealer, I figure I'll spend a Saturday to save the labor. Local shop quoted $1800 for the whole job.
    I'm planning to do the heater core flush, o-rings, pcv valve etc. Water pump and thermo don't look too terrible to get to if needed later. Appears they are accessible with out removing the intake, is that the case?
    backcountryj[QUOTED] likes this.
  16. Apr 21, 2025 at 4:33 PM
    backcountryj
    GA
    2016 Crewmax
    I order most of my OEM parts from Lagrange Toyota online sales sites. Nationally competitive pricing with minimal shipping costs. Anything of size I just go pick up, but they’re only 30 min or so down the road from me.
    https://toyotaparts.lagrangetoyota.com/
    BA_from_GA[QUOTED] likes this.
  17. May 4, 2025 at 7:00 AM
    BA_from_GA
    Did the job yesterday. All in it took less than 6 hours. 3 to tear it down, about 2.5 to reassemble. Very glad I did it my self vs. Paying a shop. This isn't at all a difficult repair for someone mechanically inclined.
  18. May 4, 2025 at 9:10 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Besides intake gaskets, 2 coolant O rings, sealant, anything else needed ??
  19. May 4, 2025 at 10:10 AM
    BA_from_GA
    I replaced every gasket or seal I encountered. Intake gaskets, secondary air pumps, oils separator, etc. May have been overkill but for a few bucks at 220k miles I wasnt going to miss the chance to replace cheap parts
    2mchfun and TheBeast like this.
  20. May 5, 2025 at 12:44 PM
    #50
    backcountryj
    GA
    2016 Crewmax
    Got a part list with part numbers ?:anonymous:
  21. May 5, 2025 at 6:11 PM
    #51
    BA_from_GA
    Nope. Just called guy I know at the dealership and told him what I was doing. He has a box waiting for me with all the seals/gaskets. Was exactly what I needed but I never went through specifics on my own.
  22. Jun 21, 2025 at 5:17 PM
    #52
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    That's good to hear. I've been watching my coolant but unable to pinpoint a small leak, until this morning. I was unaware of this failure point, though it appears to be common.
  23. Jun 21, 2025 at 5:21 PM
    #53
    agrestic1
    2016 CrewMax
    20250621_161936.jpg Well just verified mine is leaking 2016, 113,000 miles..Ordering gaskets , O rings , etc to do it... Anyone replaced the coolant heat exchange cover while in there ??
  24. Jun 29, 2025 at 6:43 AM
    #54
    JimboSlice413
    Bakersfield
    I just finished mine. I don't see any reason to replace the cover plate. I had on hand: oil separator gasket, intake manifold gasket, and 2 o rings for the water inlet. Lube those o-rings up also, they don't hug the inlet pipe as well as they should, and there's a lot of room for them to distort. I'm going to scope mine out over the next week to make sure there's no leaks from the inlet pipe.
    Also, make sure you're familiar with how these electrical supports disconnect. There's two attached to the rear of the intake manifold. You'll have to get them by hand, you can't see them. Luckily, they're very large, I was able to disconnect them without tools. Everything else is pretty easy
  25. Jul 13, 2025 at 11:55 AM
    #55
    grayscale
    grayscale New Member
    DFW
    2013 Tundra CM TSS 4X4 5.7FFV
    Which one is this?
    Also, did you apply your fipg to the plate or the block? Just curious which approach makes more sense
  26. Jul 14, 2025 at 10:04 AM
    #56
    Bergmen
    Bergmen New Member
    Ukiah, California
    I hate to see someone remove the intake manifold and not plug up the intake ports. Stuff some rags in there to keep ANYTHING from dropping in (nut, bolt, whatever).
  27. Jul 14, 2025 at 11:57 AM
    #57
    JimboSlice413
    Bakersfield
    I applied to the plate. In hindsight, the oil separator gasket probably did not need to be replaced, but it was recommended, so I had it on hand. The o-rings for the inlet though, very important.
    Also, mark the centerline of your knock sensors before removing them. I didn't, but the manual said reinstall them within +/- 10 degrees of how they were originally installed. I didn't see that until after. Knock on wood, I haven't had any issues.
    In case you want it:
  28. Jul 14, 2025 at 12:02 PM
    #58
    grayscale
    DFW
    Awesome, thanks! I assume the rear gasket for the separator was fine as well? I'm actually wondering if I can clean the separator case out while I have it out of there, they can get pretty nasty. EDIT: looking further into it I'm just going to replace it, $70 for the 3 parts.
    Thanks for the note on the knock sensors as well, hadn't run across that yet.
  29. Jul 14, 2025 at 1:25 PM
    #59
    JimboSlice413
    Bakersfield
    The rear side (drain side I think?) has no gasket. The plastic case nipple stabs into the drain hose. It all looked in great condition.
  30. Jul 14, 2025 at 2:27 PM
    #60
    grayscale
    DFW
    Here's the 3 parts I ordered for the oil separator -
    Part Number____Part Name
    12215-38010____Separator, Case
    12273-38020____Gasket, Oil Separator Vent Pipe
    12269-38010____Gasket, Oil Return Pipe
    Mine is a 2013, enter your VIN on your parts site to get the correct parts. The gaskets appear to be the same for 2nd/2.5 gen, but the separator itself seems to have changed in 2014
