4x4 owners
Discussion in '3rd Gen Tundras (2022+)' started by D&M, Jul 14, 2025 at 2:09 PM.
  1. Jul 14, 2025 at 2:09 PM
    D&M
    D&M [OP] New Member
    Southwest
    2005 RC LB 4x4, 2025 SR5 4x4 8-foot
    Had mine a few days, now.
    Checking fluid levels and find ATF in the transfer case? Just seems wrong.
  2. Jul 14, 2025 at 2:17 PM
    99ways2die
    99ways2die New Member
    NJ
    2022 Tundra Platinum
    You must be new (to 4x4s, and transfer cases, in general).
    Welcome,
    Stay a while...learn........
    Blufin and D&M[OP] like this.
  3. Jul 14, 2025 at 2:21 PM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    Why does it seem wrong?
    IIRC Jeep used ATF in transfer cases years ago and there are a number of manual transmissions that use ATF instead of your typical "gear oil", so it would seem logical that, if designed for it, the transfer case could use ATF instead of 75W or similar
  4. Jul 14, 2025 at 3:23 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Wait until you hear what some manufactures use in their power steering systems...
    raylo likes this.
  5. Jul 14, 2025 at 3:34 PM
    D&M
    D&M [OP] New Member
    Southwest
    Seemed to me that gear cases needed higher viscosity.
    Just checking with the experts, here.
  6. Jul 14, 2025 at 4:24 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Depends on the design of the "gear cases". Certain designs have smaller lubrication passageways, and synchronizers, which the specific properties of ATF are better for. It also dissipates heat better.
    I had a Jeep CJ with a manual T-5 transmission that required ATF in the 1980's.
    D&M[OP] likes this.
