5.7 hard start after sitting for 1+ hours
Discussion in '2nd Gen Tundras (2007-2013)' started by Chillvibe, Jun 19, 2021.
  1. Jun 19, 2021 at 5:03 PM
    Chillvibe
    Chillvibe [OP] New Member
    2011 tundra 5.7
    I've got a 2011 tundra with the 5.7, 148k miles and I'm thinking I've got some leaky injectors, but I'm not sure how it's happening. Cold starts are fine and it fires right up. I have problems when it sits for 1+ hours it stumbles a bit on start, and takes longer to start. If I let it sit overnight it fires right up everytime. Definitely symptoms of flooding, with fuel smell out the exhaust when it stumbles when starting accompanied by a little bit of black smoke out the tail pipe. Thought it might be a leaky injectors so I replaced with a junkyard set to make sure it really was that. Installed the injectors from the junkyard and the problem went away for maybe 750+ miles then the problem came back with the exact same symptoms.
    My question is, is there some sort of check valve, regulator, sensor or something else that can cause GOOD injectors to leak eventually or do you think I got unlucky with the junkyard injectors? Checked the fuel pump and is working fine. I'm positive that fuel is leaking into the cylinder and flooding it, but with time it evaporates out or leaks down which is why I think it starts fine after sitting for several hours is my conclusion. I dont want to buy brand new injectors and the same issue happen 750+ miles down the road, because I'm not looking at the right part. What are the chances that two sets of injectors are leaking? Anything else would cause fuel to get in the cylinders? Any ideas would be greatly appreciated. Been fighting this issue since buying it used.
  2. Jun 19, 2021 at 7:31 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Get a junkyard fuel pump control module and give that a shot. They are common to a ton of different Toyotas and are a lot easier to try than the injectors. If junkyard parts swapping isn't bothersome, this is what I would try next.
    Otherwise these are not the easiest engines to hook a fuel pressure gauge to, and that would also be of interest.
    Really leaky injectors would pollute your oil with gasoline. How does your oil smell?
    Chillvibe[OP] and 15whtrd like this.
  3. Jun 19, 2021 at 8:15 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    You could try the fuel pressure regulator. Someone had a similar issue recently and it was his regulator I think.
    ZPMAN, Chillvibe[OP] and 15whtrd like this.
  4. Jun 20, 2021 at 12:49 AM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
  5. Jun 20, 2021 at 3:42 PM
    Chillvibe
    2011 tundra 5.7
    Gotcha, I'm pretty sure I replaced the fuel pump control module. Isnt it mounted near the frame by the fuel tank? Ill need to confirm on that. Checked the oil dipstick and there is a smell of gas. I'm just perplexed why different injectors fixed it for a little while and now back to doing it again. I wish I knew the process of how the injectors work after you turn the vehicle off. Like something isnt doing its job and pressure allows gas to leak through the injectors or are the injectors never suppose to leak after shut off regardless of pressure if they are working properly. Like injectors are simply on or off?
    I saw that thread, it seemed his symptoms were a little bit different. The truck starts fine warm or cold just fine, only when it's been sitting for an hour or more does it stumble to start. I can run it for hours, fill up gas or get a bit to eat and it will start up fine. I'll take a look at that thread again though. Thanks for the input.
    Thanks for the link, I'll give them a look.
  6. Jun 20, 2021 at 7:36 PM
    audiowize
    Paul B.
    The suggestion to have the injectors you pulled out tested is a good one. I know there's a shop down the road from me that's just a fuel injector shop, and they will put your injectors in their machine right in front of you to show you what's up.
    Knowing that the injectors are leaky would have me wondering if something is up with the fuel filter in the tank among other things, or possibly fuel pressure is just too high. How are your short term/long term trims?
    Chillvibe[OP] likes this.
  7. Jun 20, 2021 at 8:43 PM
    Chillvibe
    2011 tundra 5.7
    Havent checked fuel trims, I suppose I can check the trims with a scangauge, torque app? On my 3rd gen 4runner Ive checked my trims through my scangauge. Havent looked at the tundra trims. When I first tried messing with this, I'm pretty sure I tested the fuel pressure and it was within spec. I appreciate the ideas for sure. Would a gummed up injector from say sediment in the gas tank cause it to leak? What's weird is I'm not getting any lag, cutout, loss of power under driving conditions. I think I'm going to see if I can find someone locally to test out the injectors.
  8. Jun 20, 2021 at 8:49 PM
    audiowize
    Paul B.
    If the ECU is trimming fuel way, way back, that could suggest leaky injectors. An injector shop would be able to confirm this and if the guy working there is older than dirt, he might look at what's in the bottom of the little tubes they have the injectors spraying into and make some suggestions about what's going on.
  9. Jun 25, 2021 at 8:58 PM
    Chillvibe
    2011 tundra 5.7
    I wanted to update this thread. I replaced the set of injectors with some new ones. They were supposedly new denso injectors, but you never really know when you buy online and if they are just refurbished or knockoffs. So far the new ones seem to be working and my symptoms are gone for now. I ran the truck then let the truck sit for 2 hours and then 3 hours and each time the truck started right up without hesitation. Before it would always have a hard time when 2 or 3 hours passed. I'll make an update when more time has passed. Perhaps I just got unlucky with the junkyard injectors and had some leaky injectors twice. Thanks for all your help.
    Dalandshark and 15whtrd like this.
  10. Jun 27, 2021 at 5:06 AM
    FWD Tundra
    Washington
    I would not trust junkyard injectors. You don't know how long they have been sitting and may have dried out and caused corrosion in the injector which would lead to bad things happening. Just chalk that up to a new experience. Hope the new injectors give you good service!
  11. Jun 27, 2021 at 11:05 AM
    Chillvibe
    2011 tundra 5.7
    I definitely think you are right on the money. Lesson learned for sure. So far so good, no issues.
  12. Dec 5, 2021 at 9:47 AM
    Chillvibe
    2011 tundra 5.7
    Just want to give an update. Everything continues to work fine after 5 months. It's safe to say the junkyard injectors were the culprit.
  13. Dec 15, 2021 at 11:14 AM
    FWD Tundra
    Washington
    Good deal!
  14. Jul 10, 2025 at 5:43 AM
    Benlee
    Benlee New Member
    Ben
    2008 Toyota Sequoia (Limited)
    I have the exact same hard start/stumble start issue that is described here, so I am going to replace all injectors with brand new ones. Where is the best place to get REAL Denso (OEM) injectors for the best price?
  15. Jul 10, 2025 at 5:57 AM
    Is yours a flex fuel motor? 3UR-FBE?
  16. Jul 10, 2025 at 6:15 AM
    EmergencyMaximum
    I'd go with rockauto.com
    Picked up a few things from them over the last couple years.
  17. Jul 11, 2025 at 7:58 AM
    Benlee
    Benlee New Member
    Ben
    It is not a Flex Fuel. It is a 3URFE engine
  18. Jul 11, 2025 at 8:02 AM
    Benlee
    Benlee New Member
    Ben
    I looked on Rock Auto, but they only have other after market brands, and I was wanting to stick with the original OEM part, which is Denso. The Denso injectors in there now have part # 23250-0S020 on them. As far as I know, these are the original stock injectors, at least that's my assumption.
  19. Jul 14, 2025 at 9:31 AM
    Benlee
    Benlee New Member
    Ben
    Also, what fuel filter brand do you like for the Tundra? I'm going to replace the fuel filter at the same time.
