2012 tundra V6 2wd no reverse
Discussion in '2nd Gen Tundras (2007-2013)' started by Gary of Lenoir, May 8, 2025.
  1. May 8, 2025 at 3:37 PM
    Gary of Lenoir
    Gary of Lenoir [OP] New Member
    2012 Toyota tundra 2WD truck
    The transmission was working ok until backing uphill. Then it shuddered and quit pulling in reverse. Can the transmission be reset or does it need to be replaced/repaired?
  2. May 8, 2025 at 3:42 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    First change the fluid. Drain and fill more specifically.
  3. Jul 14, 2025 at 12:15 AM
    Gary of Lenoir
    Thanks for the tip, that may be why I hear the engine idle slow down a little when I put it in reverse and it speeds back up when I take it out of reverse. I used to be quite the mechanic, but that was before they put computers in them and I'm to old now to work on them anyway.
