  1. Jul 13, 2025 at 9:37 AM
    CORNELIUSGUN
    CORNELIUSGUN New Member
    2006 DC SR5 TRD 4x4, Blue
    EZ Lift ARE High-rise Camper Topper
    Love em so far!!
  2. Jul 13, 2025 at 9:39 AM
    CORNELIUSGUN
    Put the tent in today - getting the bed base cut down to size later. 18 in tall lots of storage under for big items.
  3. Jul 13, 2025 at 10:11 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    That's frickin awesome!
  4. Jul 13, 2025 at 10:25 AM
    really wish this system wasn’t so expensive, because it is awesome!!
    :smokertransformer::smokertransformer::smokertransformer:
  5. Jul 13, 2025 at 11:14 AM
    Kalannar97
    Kalannar97 New Member
    Michael
    Hillsboro, TN
    2003 Red Tundra SR5 2wd AC V-8 LSD ABS
    New Frame (Recall in 2019), added 17" 4-Runner Snowflake Rims
    My spare was probably original with the truck and looks just like that. My dad never used it. I got rid of mine though. 20250527_161221.jpg
  6. Jul 13, 2025 at 11:38 AM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    OK, I know that the general consensus is to F that sway bar, but I just can’t anymore. Today I replaced the factory bushings with energy suspension greaseable poly
    Also found the bolt for the hardline bracket broken, so zip ties for the win
    BroHon, oscardog86, bmf4069 and 5 others like this.
  7. Jul 13, 2025 at 12:18 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    So I actually did this a couple weeks ago, but I tightened my suspensionmaxx sway bar links down. Tight. The installation instructions led me to believe that I was supposed to tighten them about hand tight and then like one more revolution or something like that (wish I saved the installation instructions, but I didn’t). Well that seemed to not be working because I was getting popping noises every time I turned or went over any kind of bump in the rain. I could tell it felt like something slipping or shifting. Then it even started to do it when everything was dry. With everything tight - no more weird popping noises. Not sure if this was user error or manufacturer instruction problem. I’m happy. If I smoke the bushings after 50k I’ll just buy new ones. Worth it to be rid of the noise and know what it was.
  8. Jul 13, 2025 at 12:21 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Fancy
    Tripleconpanna likes this.
  9. Jul 13, 2025 at 12:21 PM
    You can readily download copies of the instructions online. Here's the one Summit has stored: https://static.summitracing.com/global/images/instructions/spx-smx-1222260t.pdf
    It's more about tightening until you start to see the vertical wall of the bushing start to engage. If it has clear curvature, you've gone too far and will wreck the bushing pretty quickly.
  10. Jul 13, 2025 at 1:25 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Today we loaded up the big zero turn and the riding mower (with tire chains) and headed south to Crackhead Corner.
    We got rained out but we got all the mowing done.
    On the drive back we accelerated up the 5% grade hill, me "putting my foot into it" this time. We hit 60 mph at one point before coming to a bottleneck and having to slow to nearly 35 mph due to an RV broke down in the slow lane. (We called and reported this to WV Turnpike).
    I noticed the "low tire pressure" light is OFF. I assume that was in fact the spare tire I pumped up yesterday. :)
    4wd Hi worked fine and came back out fine too.
  11. Jul 13, 2025 at 2:15 PM
    Seat “leathers” came in.
    Definitely lighter color than the aged oak in my truck. Material feels thick and looks nice.
    my OEM ones are splitting at the seams and getting pretty ragged.
    When I remove my leathers, I’ll have the wife stitch the seat back up where the seam is splitting and I’ll save them.
  12. Jul 13, 2025 at 2:57 PM
    Nimitz_
    Nimitz_ Ballin Outrageous
    Sam
    Renton Wa
    06 DC LTD 4X4 4.7 V8
    My tailgate opens now
  13. Jul 13, 2025 at 2:59 PM
    That’s one way to do it!
    Kimosabe and Nimitz_[QUOTED] like this.
  14. Jul 13, 2025 at 3:03 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Hell yeah
    Nimitz_[QUOTED] likes this.
  15. Jul 13, 2025 at 3:17 PM
    Nimitz_
    Sam
    Renton Wa
    That’s exactly what I said when it worked on the first try.
  16. Jul 13, 2025 at 3:31 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Yes, indeed, I too applaud your innovation. :)
    What happened to your rods though?
  17. Jul 13, 2025 at 3:37 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    That's neat. I've decided to replace mine this fall (we'll park the truck for winter) and get the tire replaced with a P265/70/R17 to match the other four. Also, I want to get the rim sandblasted and painted black.
  18. Jul 13, 2025 at 3:39 PM
    Nimitz_
    Sam
    Renton Wa
    No idea, there were none in the tailgate when I bought it and the panel covering it was missing too. That’s next. I have some HDPE in the garage that’s big enough I think.
    BroHon and Bought2Pull[QUOTED] like this.
  19. Jul 13, 2025 at 3:55 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Thanks for the reply....oddly enough I just read it in Dave in Texas' thread about his tailgate handle saga.
    Panel was missing too? Ugh! You can find one easily enough at www.car-part.com BUT you'll probably have to buy the whole tailgate. That was the answer I got when I asked about getting a rear door handle from a yard advertising on there.
    Previous owner probably took that apart for some reason and lost the parts. SMH LOL
    You did a great job on the rod substitute so I'm sure this panel you make will work fine. :)
    Be sure to get us a pic of the panel install!
  20. Jul 13, 2025 at 3:57 PM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    I think assdog has/had a panel for sale for the tailgate
    Nimitz_ and Bought2Pull like this.
  21. Jul 13, 2025 at 5:10 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I'm trading it to Frank for ammo soon.
  22. Jul 13, 2025 at 5:34 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    So there really isn't a member named "assdog?" :monocle:
  23. Jul 13, 2025 at 5:59 PM
    I was wondering how he did that too but he just got his member number and substituted in the name assdog.
    Bought2Pull[QUOTED] likes this.
  24. Jul 13, 2025 at 6:02 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    You know the hyperlink factor didn't enter my mind! :p
  25. Jul 13, 2025 at 6:02 PM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    No Greg
    Correct Bill
  26. Jul 13, 2025 at 6:05 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    It's kinda sad actually.
    455h0le_dachshund likes this.
  27. Jul 13, 2025 at 6:07 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    @Black Snek
    Where do you find a member number?
    I just knew the @ edit trick.
    Black Snek
    NVM I figured it out.
    The Black Mamba likes this.
  28. Jul 13, 2025 at 6:11 PM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
  29. Jul 13, 2025 at 6:11 PM
    On TT and TS we used to embed NSFW pics within pics by clicking on them.
  30. Jul 13, 2025 at 6:23 PM
    Nicklovin
    Nicklovin Yap Yap
    Huntington Beach, CA
    00’ 4.7 AC 4x4 - GFC
    That's awesome. Question, how'd you mount your whip/flag. Got a closer pic? Looking for a new way to do that
    Is your tailgate kind tight in the last few inches to close? I got one of those from somewhere else and man I have to slam the tailgate to get it close the last bit otherwise it sticks out about an inch or two
    Whewwww those things sure are cool but man they're price
