Flip Key for 2nd Gen Tundras with Dot Key
Discussion in '2nd Gen Tundras (2007-2013)' started by AbracaDaniel, Jan 28, 2022.
  1. Jan 28, 2022 at 6:59 PM
    AbracaDaniel
    AbracaDaniel [OP] New Member
    Daniel
    2008 Toyota Tundra Double Cab
    Scoured the forums and videos for a complete start to finish explanation on how to create your own key fob and hopefully copy it so you get to enjoy it for yourself
    Final Product
    Things you'll Need
    1. Keyecu Keyfob Shell (This has a blank on it, along with a mock button set for dropping in the fob buttons I'll explain later)
    2. Tundra keyfob (You don't need this specific one, you can get one from a locksmith that works on vehicles)
    3. Immobilizer Chip (This is the one that works for Dot key Tundras)
    Steps
    . Dissasemble the Keyecu fob, should be one screw on the back. (There is a spring in there so be careful, don't loose it. Nor the screw it's very small)
    WIN_20220128_19_14_06_Pro.jpg2. You'll need to take the key blank and an existing key to your local locksmith and have them cut a clone of the truck key, then test it everywhere. Door locks, bed locks, glove box, and even ignition. Without an immobilizer, you'll spin the engine indefinitely without starting but it'll show that it will at least work.
    3. While you're there, have them program your lock/unlock fob and confirm that the doors cycle locking.
    From here, once you've gotten your immobilizer chip it's time for assembly.
    4. Using a key, separate the keyfob and pull out the chip with the buttons, it should all come out in one piece minus the plastic.
    5. Drop this in the slot on the KeyECU remote, it should pop in the same way it came out of the old fob,
    6. Slot the Immobilizer chip into the small rectangular pocket near the top of the key, I would use super glue to hold it in place unless you like listening to your key rattle for the rest of its life. (The chrome is pointed at the immobilizer pocket.)
    7. Reassemble the key itself, In case things fell apart, it goes spring, chrome tube, and the finalized cut key.WIN_20220128_19_41_46_Pro.jpg
    (The button has three wings, the two on the same side should be facing up) Also, Try twisting to have more tension on the key, it'll help it swing out faster.
    Finished Product:WIN_20220128_19_48_59_Pro.jpg
    Video of key Functioning
  2. Jan 29, 2022 at 12:40 AM
    pyrite808
    pyrite808 Real TRD Pros are built not bought
    Anthony
    Mid Tennessee
    08 DBL Cab Pyrite
    Nice DIY :thumbsup:
    Probably the only thing I really miss about my old audi, fun to fidget with.
  3. Mar 24, 2024 at 7:29 PM
    Cochiloco777
    Cochiloco777 New Member
    Central Oregon
    2008 Red Tundra TRD
    I know it's an old thread, but maybe you'll respond. Did you need to get the immobilizer chip programmed as well?
    I also looked as the link is broken, but is it a 4D-67 Transponder Chip? Thanks!
  4. Mar 25, 2024 at 8:53 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    I have a flip key.
    A local locksmith did it for me, $100 including key.
    3 locksmiths told me it's not possible before this guy did it.
    IDK why so many say it's not possible, maybe it's harder or maybe they truly don't know it's possible?
    Medicineman likes this.
  5. Mar 25, 2024 at 9:05 AM
    Cochiloco777
    Central Oregon
    2008 Red Tundra TRD
    Hmm, I was planning on doing this myself. I've already got the shell for the flip key. Plan on getting some normal aftermarket "dot" keys and programming them via techstream. Then I figured I'd take the newly programmed key and cannibalize the transponder chip and swap that with the fob internals into the new flip "shell"
    Ohannon7 likes this.
  6. Mar 26, 2024 at 5:09 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    I didn't mean to suggest anything otherwise, I just wanted to share my experience and offer an alternative solution. IF I had the ability to DIY then I'd take that route!
  7. Mar 26, 2024 at 7:49 AM
    Cochiloco777
    Central Oregon
    2008 Red Tundra TRD
    Ah I see, sorry I was misunderstanding. Well I'll give the diy a shot and if I have some success I'll post up here
  8. Apr 19, 2024 at 7:23 PM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    I bought the flip key shown by OP, it lasted a year and broke. Then I did the same thing, took its G code chip and dropped it in new case, and programmed door locks with Techstream as the PCBA was different...
    This thing is solid. The blade swapped from broken flip key to so there was zero cost. I have thread somewhere here...
    oh here it is
  9. Jul 13, 2025 at 7:19 AM
    gotanickle
    gotanickle New Member
    Sunday
    2008 tundra Crewmax
    Do you have a link or who manufactured the better remote fob.
