New LBJ (yes oem)
Discussion in '1st Gen Tundras (2000-2006)' started by 808basswolf, Jul 11, 2025.
  1. Jul 11, 2025 at 3:54 PM
    808basswolf
    808basswolf [OP] New Member
    Los Angeles, CA
    2002 tundra SR5 v8 AC 2WD
    Hey all. I got some new suspension parts and was looking at doing a rebuild. So far I did the lbj and ubj, both oem, 4k miles ago. (Yes im doing the links, i have them already.)
    Upon inspecting my suspension to see what other parts I need to order, i see grease all over my lbj. Really bad as you can see in the photo. Should I go to toyota for a warranty? What else should I check as far as leaking? Like I said, oem lbj are only 4 thousand miles in.
  2. Jul 11, 2025 at 4:28 PM
    SavageAsFlux
    SavageAsFlux New Member
    2006 Tundra SR5 DC Auto Blue Metallic
    Is there any damage to the LBJ boot? That would be my first thing to check to see where the grease is coming from. Seems some boot damage and leaking grease is most likely culprit, but youd have to examine boot first. Looks like 2WD so no CV boot to leak.
  3. Jul 11, 2025 at 4:50 PM
    Let us know how the warranty works out. Toyota usually provides a 1 year warranty on parts. I’m not sure how they handle it if you installed it yourself. They MAY want to charge you to have one of their techs look at it. I’m not sure and I certainly don’t hope so.
  4. Jul 11, 2025 at 5:25 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    With Subaru (my only experience) go to your local dealer, present the receipt of purchase of the part with the failed part in hand. Tell them you don't have a shop repair order because you installed it yourself. They will have their service department write a repair order (part only, no labor) and then swap your failed part for the new one. After that, the repair order is closed under warranty so that the dealer is reimbursed and you get to install the warrantied part.
    Corndog123, BroHon, MooreKen and 2 others like this.
  5. Jul 11, 2025 at 5:31 PM
    808basswolf
    Los Angeles, CA
    Thanks. I will try that and let you guys know how it goes. I'll make sure to get new bolts too to not chance possible failure again.
  6. Jul 11, 2025 at 5:51 PM
    808basswolf
    Los Angeles, CA
    I actually called the dealership I got them from. They said they have no way of knowing miles so I have 1 year date of purchase. They will inspect them and see whether or not they can switch them out. As long as I bring my receipt I should be good. So that's a relief.
    I guess that brings my next question, if I wanted to replace my lower control arm in the future, is it okay to re-use my lower ball joints if im just removing and putting them back on?
  7. Jul 11, 2025 at 6:14 PM
    That’s good to know. I know my local dealer wants to get paid for evaluation.
    :spending:
    Yes, I’ve done it twice myself.
    Corndog123 and The Black Mamba like this.
  8. Jul 13, 2025 at 2:50 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Is the boot torn?
  9. Jul 13, 2025 at 4:34 AM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    Should be no problem reusing the LBJ but if it were me I would get new bolts, they're cheap enough. Just my $.02.
    Corndog123 likes this.
  10. Jul 13, 2025 at 5:52 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    You appear to have the longer bolts (black bolts) which are mainly supposed to be used with the ball joint cover which you don't have, this is fine as long as there's no issues with the bolts bottoming out in any of the holes. If you do get new bolts it would be best to either install covers or just get the shorter bolts. The bolts you have are only supposed to be torqued to 37 ft-lbs.
    LINK to the ball joints and bolt part numbers.
  11. Jul 13, 2025 at 10:08 AM
    TnPlowboy
    TnPlowboy New Member
    2004 Tundra SR5 AC 4.7L 4WD, Tow Package: Blue Marlin Pearl
    Good eye...good catch.
  12. Jul 13, 2025 at 11:23 AM
    808basswolf
    Los Angeles, CA
    oh man, thanks for catching that. When you say cover, do you mean the dust cover for the lbj? Does not using the dust cover increase the chances of bottoming out even if I use the dust cover and the correct bolts? Honestly it seems the dust cover is not even expensive so I think ill just grab that too along with the bolts.
  13. Jul 13, 2025 at 12:32 PM
    TnPlowboy
    Toyota calls it a protector (dust cover) and introduced it midway in the 2001 model year and fully across your model year (2002). This required a longer bolt which also changed the torque spec which resulted in lower torque values than the shorter bolt used in LBJs without the ball joint protector.
    This is off the top of my head, so grain of salt and all.
  14. Jul 13, 2025 at 2:15 PM
    NickB_01TRD
    KY
    Sounds spot on to me.
  15. Jul 15, 2025 at 6:30 AM
    This "looks" off to me. if this is truly an uneven gap, is it the longer bolts pushing the bottom of the joint down?
    Jack McCarthy likes this.
  16. Jul 15, 2025 at 6:41 AM
    Looks like the inner bolts by the dust shield broke off.
  17. Jul 15, 2025 at 7:54 AM
    Could explain the issue. And if you're right, holy shit. You may've just saved @808basswolf 's truck.
  18. Jul 15, 2025 at 10:04 AM
    808basswolf
    Los Angeles, CA
    Holy moly, yeah good eye. Looks like the that piece is shifting up and down and causing it to leak even more joint grease. Here's a current picture. You can see it has shifted back up and the gap is closed. Going to get that fixed up hopefully this weekend and not drive it.
    @shifty` is it safe to just get the arp bolts and run without dust covers? My fear is putting on the dust covers at a lower torque with longer bolts. Maybe im just overthinking. But im grateful for catching and issue and getting help from you all.
  19. Jul 15, 2025 at 10:05 AM
    808basswolf
    Los Angeles, CA
    When i tear it apart I'll take a picture of the bolts.
  20. Jul 15, 2025 at 10:08 AM
    I doubt it's shifting, I think the first picture may just be a matter of perspective in that pic.
    BroHon, tvpierce and PNW15 like this.
  21. Jul 15, 2025 at 1:34 PM
    You don’t NEED dust covers. I’ve run without them for well over 100k miles.
    KNABORES and 808basswolf[OP] like this.
  22. Jul 16, 2025 at 3:24 AM
    tvpierce
    Maine
    That surface isn't flat. You're fine.
    BroHon likes this.
