Anytime camera issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by rmorse, Jul 11, 2025.
  1. Jul 11, 2025 at 4:45 PM
    rmorse
    rmorse [OP] New Member
    Bobby
    Bowie, MD
    2021 DC Cavalry Blue SR5 TRD Sport 4x4
    Hi guys, very confused here and trailgrid pro is currently closed until Monday. I have the anytime front and rear camera setup and just finished running the wires and putting the camera where I want it. However, the image is inverted. Not a problem….install instructions say to cut the purple loop to flip the image. Unfortunately, when I cut the loop, the screen goes to black.
    I stripped the purple wires and twisted the loop back together and the camera worked fine again. Any ideas? Everything else is working as it should. Would love to have my truck back for the weekend lol.
    Thanks!
  2. Jul 11, 2025 at 4:52 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Could be they connected the wrong color wire. You could disconnect other colors and see if that inverts it.
  3. Jul 11, 2025 at 4:55 PM
    rmorse
    Bobby
    Bowie, MD
    The other ones are disconnected (white mirrors it side to side and green takes out the grid lines). There is another blue loop but none of the instructions mention a blue loop so I figured I shouldn’t snip it.
  4. Jul 11, 2025 at 5:02 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Sounds like something wasn't connected properly on the circuit board in the camera... Sounds like you aren't doing anything wrong, so I'd probably order up another camera, swap them out and return the defective one.
  5. Jul 11, 2025 at 5:25 PM
    MadMaxCanon
    I'd wait until Monday and call them first.
  6. Jul 11, 2025 at 6:04 PM
    Mend0k
    Mend0k New Member
    2015 TRD Pro
    Did you buy the prewired kit or the one you have to solder/assemble yourself? I actually just installed mines today and it was the prewired one. I also cut the purple (vertical flip) and white wires (horizontal flip).
    If you bought the prewired kit then they must've screwed up when they were assembling it, otherwise i'd think there was a misstep while you were assembling it
  7. Jul 12, 2025 at 11:02 AM
    rmorse
    Bobby
    Bowie, MD
    I actually got a used kit that was in a 2025 4Runner but it was the prewired one. I'll call them up on Monday and see what they say.
  8. Jul 12, 2025 at 5:39 PM
    Mend0k
    Mend0k New Member
    2015 TRD Pro
    Oh I wonder if the cables are different based on the model
  9. Jul 13, 2025 at 2:19 AM
    rmorse
    Bobby
    Bowie, MD
    Nah they aren't. I called them before I bought it and thy said it's the same across the board.
    Mend0k[QUOTED] likes this.
