2005 DC 4x4 LSD
Discussion in '1st Gen Tundras (2000-2006)' started by MYOTA67, Jul 11, 2025.
  1. Jul 11, 2025 at 5:55 AM
    MYOTA67
    MYOTA67 [OP] New Member
    Joe
    Golden Colorado
    2005 Tundra DC 4x4 4.7L
    My truck has a LSD, and I’m curious of it’s gearing? I was going to ask the group if the 05 DC 4x4 with a LSD and tow package had 4:10 or 4:30 gears.
    couldn’t find a thread and figured I ask before spinning the axle off the ground and checking.
    thanks,
  2. Jul 11, 2025 at 5:59 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    What's in your rear end? | Toyota Tundra Forum
    2000-2003
    3.91 - V8, 4x4, auto trans
    3.92 - V8, 4x2, auto trans
    4.08 - V6, 4x2, auto trans or manual trans
    4.10 - V6, 4x4, manual trans
    4.30 - V6, 4x4, auto trans
    2004, Regular Cab or Access Cab
    2004, Double Cab
    4.08 - V8, 4x2, auto trans
    4.10 - V8, 4x4, auto trans
    2005-2006
    3.77 - V6, 4x2, auto trans
    4.08 - V6, 4x2, manual trans
    Bought2Pull, MYOTA67[OP] and MooreKen like this.
  3. Jul 11, 2025 at 11:08 AM
    MYOTA67
    Joe
    Golden Colorado
    thank you!!!
  4. Jul 11, 2025 at 11:57 AM
    cal1971
    cal1971 New Member
    New York
    2022 Tundra
    Hey Joe, from what I’ve seen 05 DC 4x4 LSD w/ tow package usually came with 4.10 gears stock. It’s plenty torquey, good luck, man, enjoy!
  5. Jul 11, 2025 at 12:01 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    There seems to be a lot of misinformation floating around online regarding the differential gear ratios in first gen Tundras. The information is all laid out in the sales brochures, most of which can be found in the MEGATHREAD. Towing packages have no effect on gear ratios, they only add things like trans coolers and a 7 pin wiring harness. The axle code printed on the vin plate on the door won't tell you what you need to know. The dealer can determine the gear ratio from the vin.
  6. Jul 11, 2025 at 1:15 PM
    MYOTA67
    Joe
    Golden Colorado
    I still have the sticker from the window when it was new. I don’t remember seeing it on there but I will have to double check when I get home. If not displayed there I will call the dealer to run the vin. I’m very curious now. Thanks everyone
  7. Jul 11, 2025 at 1:22 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Bought2Pull and shifty` like this.
