Need help with part numbers
Discussion in '2nd Gen Tundras (2007-2013)' started by Hogfandan24, Jun 15, 2024.
  1. Jun 15, 2024 at 4:48 PM
    Hogfandan24
    Hogfandan24 [OP] New Member
    2014 cm tss
    Changing fuel pump today and ran into hiccup. I broke some of my fuel lines on the tank thinking I had a dif style pump. I'll attach some pics. But I need part numbers for 77209d number 1 and 3. Maybe number 2 as well just so I can be certain I'm getting right stuff. Local dealership wants parts paid in advance and no returns. So I don't want to get the wrong parts. I'll attach the pictures of the schematic and the pictures of the lines on the actual solenoid. They will be the green clip lines. May take a bit on the pictures. Trying to upload from mobile and am technology impaired.
  2. Jun 15, 2024 at 7:24 PM
    Tundra Chief
    Tundra Chief New Member
    Wichita KS
    2021 SR5
    Try these:
    #1 77209-OC120
    #2 77209-OC120
    #3 77209-OC130
    Not familiar with the valve.
  3. Jun 15, 2024 at 7:38 PM
    Hogfandan24
    2014 cm tss
    1 and 2 have same number? They are different lengths.
  4. Jun 15, 2024 at 7:40 PM
    Hogfandan24
    2014 cm tss
    77204-0C070
    77209-0C080
    77209-0C120
    77209-0C130
    These are what I got from someone on Facebook. But I'd like to see a schematic that also showed the line numbers.
  5. Jun 15, 2024 at 7:41 PM
    Hogfandan24
    2014 cm tss
    This is 1 and 3 after I broke them.
  6. Jun 15, 2024 at 11:44 PM
    Tundra Chief
    Wichita KS
    2021 SR5
    Sorry. Bad proof reading on my part.
    #1 77209-OC120
    #2 77209-OC080
    #3 77209-OC130
    From Toyota parts look up. Not having your VIN I used a VIN off of a 2014 listed for sale. By your parts diagram and valve pictured I assume you have a flex fuel vehicle, 3UR-FBE. Otherwise the non flex fuel, 3UR-FE diagram is different.
    The 77204-OC070 is the return line. On your picture it is at top left with the number not visible, just the black drawn line. It is the tube the upper most 77241W clip is going into. In your picture of the valve the brown clip tube appears to be #2, the green clipped one next to it (just above in picture) is #1, and the green clipped one on the end of the valve is #3. You might google the P/N's and see if the parts look like what you have. Careful. I googled one of the P/N's and the picture is of an A/C line. Which is decidedly not the right picture used. I hope this helps.
  7. Jun 16, 2024 at 2:54 AM
    Hogfandan24
    2014 cm tss
    Thank you so much sir. The truck is a 2010 flex fuel. But I suspect p/n are the same.
  8. Jun 16, 2024 at 9:13 AM
    Tundra Chief
    Wichita KS
    2021 SR5
    Your profile over to the side says 2014 cm tss is why I used 2014. Yes what I see '10 3UR-FBE have same P/N's
  9. Jun 16, 2024 at 10:17 AM
    Hogfandan24
    2014 cm tss
    I need to change that. I now have 2010 flex fuel crew max limited.
  10. Jul 11, 2025 at 11:25 AM
    Atticus888
    Atticus888 New Member
    Jes
    2010 Toyota Tundra Flex Fuel
    I broke the same lines when I pulled my fuel tank out. I bought the replacement parts and I’m hoping for some feedback regarding where the lines go on the fuel pump itself. I haven’t found any diagrams other than the one that you posted in the picture.
