  1. Jul 10, 2025 at 8:41 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Good to hear! I need to do this when I finally throw in the bigger injectors and party pulley! I'm at 109k, myself...
    Tripleconpanna, Corndog123 and BR73 like this.
  2. Jul 10, 2025 at 9:01 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    "Party pulley!" :rofl::bananadance:I love it!
  3. Jul 10, 2025 at 10:51 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Yeah i could have easily went longer but i had the rare free time and had the plugs sitting in the garage. So why not!
  4. Jul 10, 2025 at 2:02 PM
    Bham TRD
    Bham TRD New Member
    2017 Tundra Platinum 4WD CrewMax
    Leveling kit? Any rubbing?
    Boneskull420 and woods like this.
  5. Jul 10, 2025 at 2:41 PM
    JohnWhicker
    JohnWhicker New Member
    Nope, no kit, no rubbing, still riding beautiful.
    Boneskull420, woods, Tunrod and 3 others like this.
  6. Jul 10, 2025 at 4:50 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Might need to look into that as I need new glass for my pass side mirror. Pretty sure this happened at T2S, but not sure how...
    bulldog93 and Tripleconpanna like this.
  7. Jul 10, 2025 at 5:21 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Glass is replacable w/o replacing the entire mirror....
    The glass removes by prying straight up gently w/a pry tool... it's held in by 3 (IIRC) slotted channels. Once it's pryed up slightly (you'll feel it pop loose), then it'll come right out :thumbsup:
  8. Jul 10, 2025 at 5:59 PM
    Bham TRD
    Bham TRD New Member
    I’ve watched all the YT videos I could find on oil flushes, treatments, etc. I’m definitely against oil treatments like Lucas, DuraLube, etc.
    I believe Valvoline Restore & Protect is the best option for your concern. If it’s really bad, remove the valve covers and clean as much as you can before running Restore & Protect.
    Have you sent a borescope in the oil fill or drain port?
    Pennzoil Ultra Platinum would be other choice once it’s cleaner.
    If you believe it’s got a lot of sludge, I’d change the filters often, they’re only $5, much better to go overboard on filters then stop up your pickup screen.
    woods and bulldog93 like this.
  9. Jul 10, 2025 at 7:31 PM
    Leedaar
    Leedaar New Member
    2016 Tundra CM
    Replaced a leaking return power steering hose today. While i was there i also replaced the reservoir with a rockauto part too. Gave the truck a free oil bath after accidentally turning on the truck with the return hose disconnected. Not a very fun day lol
    Two new hose clamps/clips are a must!
  10. Jul 10, 2025 at 8:05 PM
    Boneskull420
    Boneskull420 New Member
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    Thanks, I ordered it from AmazonScreenshot_20250710_230426_Amazon Shopping.jpg
    DirkS, woods, HulkSmurf14 and 5 others like this.
  11. Jul 10, 2025 at 8:45 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    I don't think its inherently an issue. Performance-wise you'll have the same braking, but my guess is the pads wear faster from the inside than the outside?
  12. Jul 11, 2025 at 6:34 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
  13. Jul 11, 2025 at 6:59 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    JMGmanAZ likes this.
  14. Jul 11, 2025 at 7:04 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Just a bass boat. Helps with the blind spots.
    RobertD likes this.
  15. Jul 11, 2025 at 7:11 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    I was referring to the person you quoted, they tow a camper. But yes, helps with a boat as well, that's what I tow and they help when I'm backing into the driveway to see where tires of the trailer are when I have it turned at a sharp angle. But I've really found them more useful than I thought during regular driving as well, happy with the purchase.
    JMGmanAZ and HulkSmurf14 like this.
  16. Jul 11, 2025 at 7:57 AM
    SD Surfer
    Bruce
    So Cal
    Too bad that wasn't the driver's side, I'd have just sent you my glass.
    Amazingly, the actual mirror was the only thing that didn't break in the impact.
    bulldog93 and JMGmanAZ[QUOTED] like this.
  17. Jul 11, 2025 at 8:15 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
  18. Jul 11, 2025 at 8:21 AM
    Edemoya160
    Edemoya160 New Member
    Enrique
    2017 Tundra 1794 edition
    Hi, does anyone know if the 3.5 M1s can be adjusted to 3 inch lift?
  19. Jul 11, 2025 at 8:24 AM
    If I was doing a 3 inch lift, I would definitely use something other than Rough Country.
  20. Jul 11, 2025 at 8:26 AM
    Edemoya160
    Enrique
    What do you recommend? My truck is used daily, more on asphalt than off-road.
  21. Jul 11, 2025 at 8:30 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Bilstein 6112 up front
    5100 rear
    Coachbuilder Shackles+2 rear
  22. Jul 11, 2025 at 8:39 AM
    Bilsteins. Those RC's at less than $400 for the pair is like putting on shocks from Walmart.
    ATV25, French Avocado, woods and 3 others like this.
  23. Jul 11, 2025 at 8:46 AM
    Edemoya160
    Enrique
    Ahahahaha I understand, thank you for the help
    ATV25 likes this.
  24. Jul 11, 2025 at 9:36 AM
    Mend0k
    Mend0k New Member
    2015 TRD Pro
    Hello fellow comrade !:yes:
    Corndog123[QUOTED] and BR73 like this.
  25. Jul 11, 2025 at 9:37 AM
    Mend0k
    Mend0k New Member
    2015 TRD Pro
    Just installed anytime backup camera on my 2015 TRD Pro. Almost unnoticeable from the front :)
  26. Jul 11, 2025 at 11:07 AM
    Boneskull420
    Tn
    Anyone have any experience with the OTT tune, specifically the spicy/extra spicy....(I think) settings compared to the medium/spicy settings and drivability? Speed and fuel mileage isn't a big issue just wondering how much of a difference there is and others opinions! Thanks in advance.
  27. Jul 11, 2025 at 11:11 AM
    RobertD
    Robert
    DFW, Texas
    Might get better responses in the OTT thread.
    https://www.tundras.com/threads/ott-tune-for-stock-na-tundra.132757/
  28. Jul 11, 2025 at 11:12 AM
    Boneskull420
    Tn
  29. Jul 11, 2025 at 11:14 AM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    Okay, cool. Mine lives in the state it was born in, so no rust.
  30. Jul 11, 2025 at 11:41 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Greetings and salutations!!!
    BR73 and Boneskull420 like this.
