2010 Tundra cranks over but will not start!
Discussion in '2nd Gen Tundras (2007-2013)' started by Vaqueros, Oct 27, 2017.
Tundra will not start
  1. Verified relays
    0 vote(s)
    0.0%
  2. New battery
    1 vote(s)
    100.0%
Multiple votes are allowed.
  1. Oct 27, 2017 at 1:04 PM
    Vaqueros
    Vaqueros [OP] New Member
    Rick
    2010 Toyota Tundra
    driving my truck stopped to get the mail when trying start truck had a rough idle then stopped! Cranks over but does not start! I verified the fuel pump relay plus all fuses in fuse box! Two days ago I installed a new battery any ideas?
  2. Oct 27, 2017 at 1:29 PM
    Did it start two days ago? Any CEL’s? I’d so, what’s the code come up as? I know you installed the battery, but did you test it? Alternator?
  3. Oct 28, 2017 at 10:02 AM
    Vaqueros
    Rick
    2010 Toyota Tundra
    No codes! My truck is Running now! I had a 1/4 tank of gas I hardly ever run it that low I decided to put in a gallon of 91 high octane gas and it fired right up! Fuel gauge not accurate or I put in some bad gas who knows!!
  4. Oct 28, 2017 at 10:28 AM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    Mine did that several months back no codes
    It tried to fire on the first try ran for about 2 sec. then did each try to start was less and less then just cranked
    I disconnected the battery for 10 mins and haven’t had an issue with it since idk. Computers gonna be the death of America lol
