Faraday pouches
Discussion in '3rd Gen Tundras (2022+)' started by D&M, Jul 9, 2025.
  1. Jul 9, 2025 at 3:58 PM
    D&M
    D&M [OP] New Member
    Southwest
    2005 RC LB 4x4, 2025 SR5 4x4 8-foot
    Can someone recommend one which actually works?
    Tried three so far - no luck.
    Thanks.
  2. Jul 9, 2025 at 4:07 PM
    al415
    al415 New Member
    We use these… although usually doubled up in a faraday box.
  3. Jul 9, 2025 at 4:10 PM
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    What have you tried?
  4. Jul 9, 2025 at 4:10 PM
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    Are you looking to stop the FOB pinging to prevent theft? If so I just turn my key off.
    Press and hold lock and then press unlock twice. You’ll see the LED flash and the key is turned off which you can test by grabbing your door handle. Then press any button on the FOB to wake it up.
  5. Jul 9, 2025 at 4:11 PM
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    Is it just me or does al415 look like a bot?
  6. Jul 9, 2025 at 4:20 PM
    D&M
    D&M [OP] New Member
    Southwest
    Edit: My fumble fingers did not work properly at first.
    After 20 years with my 1st gen, lots of new gadgets to learn.
    Thanks.
    PapaDave418[QUOTED] likes this.
  7. Jul 9, 2025 at 4:45 PM
    al415
    al415 New Member
    guess it’s just you
  8. Jul 9, 2025 at 4:47 PM
    centex
    centex New Member
    What are you trying to achieve?
  9. Jul 9, 2025 at 4:52 PM
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    it just looked weird. Post count of 1. Amazing picture of a product recommendation. I’m a little paranoid of that kind of manipulation.
    no offense intended to actual forum members.
    mea culpa
  10. Jul 9, 2025 at 5:07 PM
    al415
    al415 New Member
    it’s only 2025 and folk have AI PTSD. No offense taken.
  11. Jul 9, 2025 at 5:19 PM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    Down with Skynet!!
  12. Jul 9, 2025 at 5:24 PM
    SWMO
    SWMO New Member
    2025 Tundra limited TRD off road
    What is the purpose of turning off the key?
    I know why I might want to do it, but I am curious if my idea is reasonable.
  13. Jul 9, 2025 at 5:50 PM
    Observer
    Observer New Member
    Assumption-turning off the key: 1. Does not emit or recieve a signal . 2. saves battery. I have my spare FOB turned off to extend it's battery life.
  14. Jul 9, 2025 at 6:05 PM
    D&M
    D&M [OP] New Member
    Southwest
    Cloning prevention?
  15. Jul 9, 2025 at 6:10 PM
    SWMO
    SWMO New Member
    I had not thought of those reasons.
    I have thought about hiding the door key on my truck and leaving the fob hidden inside the truck. Just in case I lose my other fob in a lake, river or woods.
  16. Jul 9, 2025 at 6:50 PM
    WineryCowboy
    WineryCowboy New Member
    2022 White Tundra SR5
    Timbrens SES Rear
    I use a GoDark vault faraday cage. Goes in every night. Here in Ontario car thefts are crazy, had a friend who went to help his son move apartments, spent all day packing and had their truck loaded up. Next morning truck was gone.
  17. Jul 9, 2025 at 10:46 PM
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Turning off the key prevents cloning and someone getting in and starting your truck like they have an key. Faraday boxes work great but you have to bring them with you if you aren’t parked at home. For example I turn off my key at hotels in case someone goes down the hallways picking up FOB signals. And yes it saves batteries as well. For long off road trips I put my spare hidden in the truck turned off so if I lose my primary set I’ve got options. Turning off my key is second nature now as I’m walking into the house
  18. Jul 9, 2025 at 10:54 PM
    TerraOnMyTundra
    TerraOnMyTundra New Member
    That's how people are stealing modern vehicles.
    They pick up the fob signal with a tool, and spoof it to the vehicle.
    Pretty common in areas of Canada, and a little bit in SoCal.
    Hurray for having a garage
    al415 likes this.
  19. Jul 10, 2025 at 8:20 AM
    JayDee
    JayDee New Member
    A sheet of aluminum foil folded into a pocket will work. It's not very heavy duty but you could use any type of pouch and just line it with foil on the inside.
    I once ordered a Faraday Cage pouch for my phone from InfoWars. I tested the wi-fi signal strength when the phone was in the pouch verses outside the pouch. The pouch amplified the signal. So, whomever made the pouches was either incompetent or it was intentional. Intel agencies often pose as security agencies for obvious reasons.
    D&M[QUOTED][OP] likes this.
  20. Jul 10, 2025 at 8:48 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    FYI, on a recent cross country roadtrip, I turned my spare FOB off and stuck it in the center console. Then I hid the metal key in a waterproof magnetic box that I stuck to the frame rail under the truck. My thinking was, if I lost my main FOB, I'd simply reach under the truck, unlock the door with the hidden metal key, and my spare would be in the cab ready for use. Only one problem...the magnets on the box apparently weren't strong enough to withstand a 4500 mile roadtrip. It was gone when I got home.
    I still think it's a good plan, but I'm going to find a box that I can zip tie under the truck, instead of relying on magnets.
    22Tuns, Paul499 and D&M[OP] like this.
  21. Jul 10, 2025 at 8:58 AM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    One can never be to safe,so wear foil!
  22. Jul 10, 2025 at 10:50 AM
    guru
    guru the one and only
    New England
    ● '24 MBM TRD Pro
    but then you've have to leave your truck unlocked.
  23. Jul 10, 2025 at 11:02 AM
    Tiger85
    Tiger85 New Member
    2025 Mag Gray Platinum i-Force MAX
    I bought one off Amazon years ago for work by EDEC. Definitely worked for cell phone. I think mine was branded Black Hole but when I go through history it's now OFFGRID.
  24. Jul 10, 2025 at 11:04 AM
    SWMO
    SWMO New Member
    I was planning to take the battery out of the fob. Now I am just going to turn the fob off. I did not know that trick. Thank you, PappaDave418, for the education.
    PapaDave418 likes this.
  25. Jul 10, 2025 at 12:19 PM
    Tundra2n3
    Tundra2n3 2.5 Gen
    2015 Tundra DC SR5 TSS Off Road V8 5.7L 4x4
    I don't have personal experience with it, but from a Privacy book I'm reading, they recommend SLNT
    Phatty likes this.
  26. Sep 3, 2025 at 7:34 PM
    Breckler23
    Breckler23 New Member
    Georiga
    2025 Limited TRD OR Black
    Had this in my 4 runner for 10+ years. Mine was on top of a rail, so it was sitting and being held as opposed to be held upside down.
    I actually need to get a spare key
    Like that again, but I actually had a key to start the car, so it won’t work now with the fobs
  27. Sep 3, 2025 at 10:40 PM
    Wraith
    Wraith New Member
    '25 Limited Crewmax
    This is hilarious
  28. Sep 4, 2025 at 5:54 AM
    obgod3
    obgod3 New Member
    NC
    2023 Tundra Limited
    It’s doesn’t matter all you personal information, all of it, is already on the dark web, fact!
    DRP likes this.
  29. Sep 4, 2025 at 6:35 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    This.
    Just turned my spare fob off.
    Be sure to test after you do this. I didn't get it right the first time.
  30. Sep 4, 2025 at 9:45 AM
    tundras00
    tundras00 New Member
    I connected the dots... lol Although I have watched plenty of documentaries, there's a trail that makes it seem as Alex operates different as it shows in public.
