Brake Rotor Upsizing
Discussion in '3rd Gen Tundras (2022+)' started by Just_Tito, Jul 7, 2025.
  1. Jul 7, 2025 at 9:29 PM
    Just_Tito
    Just_Tito [OP] New Member
    23 Tundra
    My Porsche Cayenne Brembo brakes for my Audi came with 6pt calipers and 365mm rotors. I was able to upsize them to 380mm with just an adapter. Does anyone know if we can do this with these Toyota calipers?
  2. Jul 8, 2025 at 3:28 AM
    nodak67
    nodak67 New Member
    JR
    could try r1 concepts, but i think i can count on 1 hand the number of people that have done that.
  3. Jul 8, 2025 at 5:45 AM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    The only kits I've seen are full BBKs... I don't believe there is a larger OEM rotor that uses the same caliper on anything
  4. Jul 8, 2025 at 8:44 AM
    Just_Tito
    23 Tundra
    I gotta find the manufacturer of the calipers. With Porsche, Brembo makes the rotors and calipers.
  5. Jul 8, 2025 at 8:56 AM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    Are you feeling fade in your current application? A minimally larger rotor may slightly increase brake torque, but nothing leading to a big change... Something along the lines of a 15mm increase in rotor diameter will yield a very minimal torque advantage (even 25mm+ increase in rotor size doesn't yield a huge difference while retaining a non-performance caliper).
    You'd feel a bigger difference in fade resistance and torque by switching to a different pad compound.
    I'm not sure who makes the 3rd gen brakes, but as per another thread on here the 2nd/2.5 gen brakes OEM supplier was Advics; so that may be somewhere for you to start.
    If you want a legitimate upgrade in stopping power, I would suggest looking into full BBK's from either PowerBrake or Alcon
  6. Jul 8, 2025 at 11:37 AM
    Just_Tito
    23 Tundra
    Brakes are fine, purely aesthetics. I just bought 24s that will make the brakes look small.
  7. Jul 8, 2025 at 4:02 PM
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    Farmers Branch , Texas
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    The Hybrid brake don't help either if there was an upgrade size. I'd you have a hybrid.
    Stop pressing the brakes with only your big toe. Using your whole foot makes a difference in stopping.
