Trying to repair rear door functions on 2011
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by Gc8nate, Apr 2, 2024.
  1. Apr 2, 2024 at 5:50 PM
    Gc8nate
    Gc8nate [OP] New Member
    Recently picked up a 2011 platinum and the rear window, defrost and wiper weren't working.
    Read up on it a bit and tried a few things. Resetting with the long button press, disconnecting the battery etc. Still wasn't getting anything so I took off the rear panel.
    Regulator and tracks were absolutely toast. Previous owner had installed blocks to attempt to keep the window in the up position. Ripped them out and installed new tracks and a new regulator. Buttoned everything back up and I'm still not getting any functionality back there.
    Does anyone know if there is some sort of fuse, relay or switch that I should be looking for? Or does anyone happen to know what pins in the regulator harness are power and ground so I can test if it's even getting power?
    Thanks for any info you guys can provide!
  2. Apr 2, 2024 at 6:01 PM
    https://www.tundras.com/threads/ultimate-tundra-wiring-diagrams-collection.81448/
  3. Apr 2, 2024 at 6:15 PM
    Gc8nate
  4. Jul 8, 2025 at 11:58 AM
    Sloww85
    Sloww85 New Member
    Austin
    2010 Sequoia
    Stock
    Gc8nate,
    did you ever get to the bottom of the issue?
