2025 Tundra sr trailer wiring
Discussion in 'Towing & Hauling' started by Tmarkel, Apr 23, 2025.
  1. Apr 23, 2025 at 5:43 AM
    Tmarkel
    Tmarkel [OP] New Member
    2025 tundra sr
    I know there are some older posts about some of the SRs that need a Towing converter relay add to make the trailer lights work correctly. Does anyone know if there is a plug and play out now or if the 2025 still needs the converter added.
  2. Jul 7, 2025 at 9:03 AM
    Shedguy1
    Shedguy1 New Member
    2025 tundra SR5
    I have 25 sr5. The wiring works fine. Just plug it in. Make sure you look at your owner's manual to see you towing capacity. The dealership said mine had the towing package, but it didn't. When I checked The manual it said 8,300. My trailer weighted 6500. My transmission overheated and had a major vibration when I stopped for gas and started out again!
