Is it normal for my AC to take 10 minutes to finally cool off the inside of the truck?
Discussion in '1st Gen Tundras (2000-2006)' started by StrawberryBlowpopPrincess, Jul 6, 2025.
  1. Jul 6, 2025 at 1:25 PM
    StrawberryBlowpopPrincess [OP] New Member
    2002 sequoia RWD
    For one, I live in the south where it gets very humid, which seems to compound how hot it feels. I know the truck is 20 years old so I don’t expect it to be perfect, but even when I’m at operating temp it still feels as if the AC is lacking. I have already cleaned the coils out underneath the glovebox and it helped slightly, though it was very hard to even get all the gunk/trash out through the little hole and there’s probably still gunk in there.
    I thought maybe my system was low on refrigerant so I purchased two different brands of refrigerant. (* reason being for buying two- I wanted to see how the pressure gauges compared to each other, and wouldn’t you believe it, they both read the exact opposite of each other)*
    I don’t know what to make of these 2 readings. One says it’s past full, the other says it’s so low it won’t register. I took the readings with the car on and AC at full blast
    Im a little scared to fill it with refrigerant at this point. I had the system recharged 5 years ago in a friends garage (done with “professional equipment “)
  2. Jul 6, 2025 at 2:39 PM
    bfunke
    bfunke Tundra Curmudgeon
    Unless you have proper training and equipment, I would advise you to take it to a specialist AC repair shop.
  3. Jul 6, 2025 at 2:42 PM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    The second pic, you're taking that reading with the AC running, right? Honestly, it's much easier to do more harm than good unless you know what you are doing with these. Those LAPS AC refill cans often contain a lot of crap that do not help your AC at all. Do some research on local AC places and have them at least diagnose it.
    KNABORES likes this.
  4. Jul 6, 2025 at 3:26 PM
    2002 sequoia RWD
    Both pictures are with the car running and ac on full blast. The reason I bought 2 different gauges is because in my mind I thought “ I bet if I buy 2 different brands of gauges I’ll get 2 different readings, so I’ll just take the average from the 2 to get a more accurate reading “
    Well I never excepted one to say it was empty, and the other to say it’s past full….
  5. Jul 6, 2025 at 3:27 PM
    Jack McCarthy My work anxiety is my morning alarm clock
    Never use the cheap gauges supplied with the refrigerant in a can, they never read correctly. Always uses quality gauge.
    Definitely take it to a reputable shop if you feel it’s not blowing cold enough. They can discharge the system and refill it with refrigerant with added UV marker dye. You then come back in a week or two and they’ll point out the leaks in a system.
    You can then go from there how you want to proceed. Live with it, pay to get O-rings and and schrader valves replaced as an example or figure out how to do it yourself although you’ll need a garage to discharge it so you can work on it then refill it.
    Fragman likes this.
  6. Jul 6, 2025 at 3:39 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Given the cooling area of your Sequoia is close to almost double the area of even a 1st Gen Tundra DC, in these 100 deg high humid days, I'd say 10 min's is not too bad. Since this is a Sequoia, are you depending on front AC only or is your rear AC helping out. If your parked outside in this scorching heat, factor that in also. Knowing what degree is actually coming out the center vents would help knowing also.
    I'll also agree with others that AC for some folks is best left to a professional in that business.
    des2mtn and Jack McCarthy like this.
  7. Jul 6, 2025 at 3:50 PM
    vmkeith
    vmkeith Slow is smooth, smooth is fast
    Vince
    Clark County, Wa
    2014 Super White Tundra SR5 CrewMax 4x4
    Rhino Lining bedliner LT275/70R18 Cooper Discoverer ATP II TRD Pro dual exhaust with TRD exhaust tips Lund 5" Cab Length Oval Curved Tube Steps RealTruck TruXedo Pro X15 Tonneau Cover RealTruck Elevate FS Bed Rack Rhino-Rack Carriers Diode Dynamics SS3 LED Fog Light Kit Auxito LED Headlight Bulbs Rydonair 7" antenna
    You can get a thermometer and put it in your vent to find out how cold your AC blows. Something similar to this Air Conditioner Test Thermometer. The amount of space and different cooling vent zones will play a factor. If you're sitting in the driver's seat, does it still take 10 minutes or more to feel a significant temperature drop?
    jimf909 and Retired...finally like this.
  8. Jul 6, 2025 at 3:55 PM
    An example of my leaks (green) when using a UV flashlight (purple).
    G_unit3000 likes this.
  9. Jul 6, 2025 at 4:03 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    Too much or too little freon and it wont get cold.
    jimf909 likes this.
  10. Jul 6, 2025 at 4:13 PM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    I second the opinion to put a temp gauge in the duct, that's the only way to tell the temp of the air coming out. I have a nice analog style in my vent and it's always around 40 F. I'm in SoCal where it's hot, but not too humid most days. I would take it to a specialty air con shop if in doubt of the system. FWIW, my 24 Y/O air con system has never been serviced, still on the factory charge.
    jimf909, G_unit3000 and KNABORES like this.
  11. Jul 6, 2025 at 4:38 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Third...get a temp probe and measure the temperature from the vent. Should be ~ 45 - 50 degrees.
    Also, turn on air re-circulation so you're not trying to cool ~ 100 degree air from outside the cab.
    Also, check your fan clutch.
  12. Jul 6, 2025 at 5:18 PM
    same
