  1. Jul 4, 2025 at 6:55 PM
    hudrock
    hudrock New Members only jacket
    So Cal
    25 MGM Limited
    Installed Beat Sonics amp…..easy install and well worth the money, sounds great. You can also install without removing the HU if you have nimble hands
  2. Jul 4, 2025 at 7:14 PM
    AF555
    AF555 New Member
    Michael
    2025 Tundra 1794 - Smoked Mesquite
    Looks great! Was there a reason you dropped from the 20" rims to the 18"? I'm new to Tundras (always had 4runners before going with a 25' 1794 Hybrid a couple months ago) and have already scraped the rims on my 1794 w/ 20"s a handful of times. I was thinking of maybe going to the 18"s with the WildPeaks AT4W's as well. Just wanted to know your thoughts! Thanks much!
    Tundrastruck91 and chrisgibbs707 like this.
  3. Jul 4, 2025 at 7:19 PM
    CappyKD
    CappyKD Older, grayer member.
    Kirk
    2025 Limited 4x4 TRD Off Road CC 6.5 Lunar Rock
    Congrats! I installed mine this past week as well. I am super pleased with the install and the result. Makes a big difference in sound. I intended to do before and after vids, but life got in the way.
    astrength22 and hudrock[QUOTED] like this.
  4. Jul 4, 2025 at 7:36 PM
    manofsteele2003
    manofsteele2003 New Member
    24 Sequoia TRD Pro, 03 Tundra Limited 4WD
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    I'm glad everyone has great things to say about the Beatsonics, I'm about to pull the trigger on one.
    astrength22 and CappyKD like this.
  5. Jul 4, 2025 at 8:39 PM
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    35s and 17s = it’ll never look like you’ve curbed your wheels;) I’m sure with 18s it’d be hard to scrape the wheels + you can actually get skinny 35s and more positive offset wheels like the BBS’s
  6. Jul 4, 2025 at 8:42 PM
    bailey bulldog
    bailey bulldog New Member
    Or 255/85r17s!
    chrisgibbs707[QUOTED] likes this.
  7. Jul 4, 2025 at 10:58 PM
    TerraOnMyTundra
    TerraOnMyTundra New Member
    I am newer to Tundras as well, but well versed in Tacoma's.
    I went with smaller rims for a few reasons....
    -More sidewall. I prefer the look, and it keeps the rims safer from rocks/potential curb strikes
    -Better offset. TrdOR rim is +60, and these are somewhere in the 40s. ~34-38 is ideal for max clearance for bigger tires IIRC
    I didn't want the tires to stick out and have the "bro" look so these are perfect, plus I like that style of rim that Toyota does. The Tacoma variant is similar and I loved it as well.
    The wild peak AT4s are one of the best truck tire I've ever used. They aren't loud, have amazing traction in the rain and snow, and look great. You can't go wrong with them, tho, I would shy away from Es unless your really offloading or heavily towing.
    Tundrastruck91 likes this.
  8. Jul 5, 2025 at 6:31 AM
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    I put some Matt black inlay in the 1794 Limited Edition stamp on the tailgate. I wasn’t sure if I’d like it but I do!
    It rained right after my SIL and I installed them and I was to lazy to wash it before I took the after photos but even dirty it looks good.
  9. Jul 5, 2025 at 6:55 AM
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    Farmers Branch , Texas
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    Not bad. Just had a thought. Anyone ever try to hand paint the tailgate letters? Me personally would like a smooth tailgate. No letters.
  10. Jul 5, 2025 at 6:59 AM
    JayDee
    JayDee New Member
    The Beatsonic is a great first audio mod. After having mine for a few months I upgraded the front corner speakers from the OEM 2" to a coaxial 3.5". The speaker upgrade resulted in cleaner mid (vocals) and high tones. My rig has the non-JBL 9 speaker system (now with 11 speakers).
    Blufin and SilveradoSwap like this.
  11. Jul 5, 2025 at 9:17 AM
    TerraOnMyTundra
    Is it an actual amp or is it just tweaking the sound for it "sounds better"
  12. Jul 5, 2025 at 9:19 AM
    Kerplunk
    Kerplunk New Member
    • Maximum output 45W x 4ch (4Ω)
    • Compatible impedance 4-8Ω
    • Input sensitivity 0.5-5V
    • Frequency characteristics 15-80kHz (+0, -1dB)
    • Total harmonic distortion 0.01% (1kHz / 4Ω)
    • Power supply DC12V (minus ground)
    • Power supply voltage DC11V ~ 15V
    • Current consumption 0.2A (when there is no signal)
    • Fuse used 15A
    • Audio input AUX level (RCA)
    • Speaker level (supports high level input)
    • Dimensions 96 (W) x 40 (D) x 113.5 (H)
    • Weight 420g (main unit only)
    CappyKD likes this.
  13. Jul 5, 2025 at 9:24 AM
    TerraOnMyTundra
    Could have checked myself, noted.
    Going to lookup the stock JBL HU to see how much more juice the best sonic pushes vs stock
  14. Jul 5, 2025 at 9:26 AM
    CappyKD
    Kirk
    I have the stock JBL. Huge upgrade over stock.
  15. Jul 5, 2025 at 2:06 PM
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    mikev25, MAC25Tundra, kirkb and 8 others like this.
  16. Jul 5, 2025 at 3:39 PM
    JayDee
    JayDee New Member
    The Beatsonic does push more power to the speakers but not a tremendous amount more power. The OEM speakers are not really designed to handle much more than the factory amp puts out.
    It also cleans up the sound via a non adjustable DSP. (There is an expensive unit that is adjustable via a pc connection)
    It is not a high-end audio system but if you want better sound and don't crank your music up to ear damaging levels then it's a fine upgrade. The factory door woofer speakers are actually pretty decent at moderate volume.
  17. Jul 5, 2025 at 4:03 PM
    SilveradoSwap
    The stock JBL system is lacking in a lot of areas imo. The front door speakers carry almost all the bass load, the rear sub is joke to say the least. I also recall the JBL system to put out 1200w, I call bs.
  18. Jul 5, 2025 at 4:55 PM
    TerraOnMyTundra
    Wait there's a sub? Lol
    SilveradoSwap[QUOTED] likes this.
  19. Jul 5, 2025 at 5:37 PM
    G8Santini
    G8Santini New Member
    25 Tundra SR5, 4x4, PremCnv, Perf. Pkg., Blackout, TRD 3”Lift, 20”TRD rims
    Heritage grille, fog lights, 35x12.5x20” Nitto, low profile toolbox, F/R tow hooks
    Added a few TRD logos…
    - New quarter panel TRD Off-Road logos (Amazon) in all-black to keep the white truck’s blackout look going.
    - Picked up 2 TRD aftermarket emblems I got in the dealership’s parts mart. One was small TRD letters with red/white flags. The 2nd was larger but had orange/yellow flags attached to TRD. Broke the flags off both.
    - Used smaller rd/white flag w/ larger TRD letters on tailgate.
    - Put smaller TRD letters on passenger dash panel. Tossed the orange flags. Also added Tundra emblems into passenger dash insert to match.
    Does any of this make it a TRD Tundra? Nope.
    But it does have more TRD equipment than most TRD Off Road package trucks.
    20” TRD rims, TRD 3” Lift/suspension, TRD skid plate, TRD center exhaust, & TRD dual tip tailpipe, Heritage grill.
    Added aftermarket fog lights back from the TRD fog-delete, & AFE tow hooks.IMG_0554.jpg IMG_7493.jpg IMG_7492.jpg IMG_7497.jpg
    mikev25, kirkb and Degausser like this.
  20. Jul 5, 2025 at 6:08 PM
    Toklas
    Toklas New Member
    2023 limited TRD OR CM short bed blueprint
    Which speakers did you go with and did you need any adapters?
  21. Jul 5, 2025 at 6:10 PM
    Toklas
    Toklas New Member
    I wrote to beatsonic and asked about this. Their amp is not an amp and doesn't drive the speakers. It functions more like a preamp. So the head unit still drives the speakers at the same wattage.
    BdBoyitz likes this.
  22. Jul 5, 2025 at 6:26 PM
    Degausser
    Degausser New Member
    Kevin
    GA
    2024 LR SR5
    Installed the TRD dual tail pipe. Wiggling the stock tail pipe out was a huge pain in the ass, but worth it in the end.
  23. Jul 5, 2025 at 6:28 PM
    Degausser
    Kevin
    GA
    2024 LR SR5
    Also picked up parts for the Pro tailgate spoiler and the main piece was broken when I got home. Going to have to call the dealership Monday to get that figured out.
  24. Jul 5, 2025 at 7:01 PM
    bailey bulldog
    What's the part number on that?
    HomieDontPlayDat likes this.
  25. Jul 5, 2025 at 7:08 PM
    bailey bulldog
    Found it! PT226-34220-02
    Degausser[QUOTED] likes this.
  26. Jul 5, 2025 at 7:24 PM
    G8Santini
    Nice job doing the tail pipe in your driveway. Rough doing it w/o a lift. It’s so easy if you can get the truck just 3’ or more off the ground - just slides out/in over the axle.
  27. Jul 5, 2025 at 7:25 PM
    to-yo-da
    to-yo-da New Member
    I was worried about it before installing but I don’t even notice it anymore. This one was a scratch n dent and he only wanted 400 for it, well worth it! I will say the ladder is not worth it. It’s VERY easy to have slip out from under your feet and it’s not fun when that happens.
  28. Jul 5, 2025 at 7:51 PM
    HomieDontPlayDat
    HomieDontPlayDat New Member
    Vinny
    Southwest
    2025 Tundra TRD
    IMG_1103.jpg IMG_1104.jpg IMG_1110.jpg IMG_1114.jpg IMG_1113.jpg Installed a 12V, USB, and bed lights on a switch panel. Wiring was pretty simple and everything worked perfectly. Next is to get a eletrical cooler to plug in the back…
  29. Jul 5, 2025 at 7:55 PM
    Degausser
    Kevin
    GA
    2024 LR SR5
    Ended up having to jack up the body just enough to let the axle droop and slide it over. I fought with it for way too long before realizing that was probably the answer though.
    Bulldog6 and G8Santini[QUOTED] like this.
  30. Jul 5, 2025 at 8:24 PM
    Kerplunk
    Kerplunk New Member
    I had a 2021 Highlander with the JBL. The brochure said it "Sounds Like 1200 watts". They quit advertising it as such for very obvious reasons. A service tech looked up the specs on the system, and it was something like 32 watts. Oh yeah, the system in the Highlander was real trash. My 24 Tundra has the standard system that comes with the Limited trim, and it sounds much better. Sure, different system, different vehicle, but the fact that JBL anything is a waste of cash is a truth that will last forever.
