I hate not having level driveway. ATF drain and fill
Discussion in 'General Tundra Discussion' started by The Dude, Jul 4, 2025.
  1. Jul 4, 2025 at 5:14 PM
    The Dude
    The Dude [OP] New Member
    Chandler, AZ, not anymore :(
    Just over 4 years and shy of 51k miles in between, I did another ATF drain and fill. This time I did it using ScanGauge 2 at temp range of 99°-111°
    Drained almost the same exact amount, 0.6 oz. less than last time
    I drained 3.5 qts and ended up putting the same amount. This tells me that the method I used before should work, as long as transmission wasn’t low to begin with.
    Last time I did it here: https://www.tundras.com/threads/yet-another-atf-drain-fill.89432/
    Happy 4th of July!
    DrRansom, Bammer, Trooper2 and 3 others like this.
  2. Jul 31, 2025 at 7:18 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    I just went over the post from when you did the previous drain and fill from 2021 it was a good write up I was most interested in the Blackstone report card which actually turned out to be uneventful . You are getting it done with what you have with your slanted driveway. It’s always a good idea to do the fluid leveling process since transmission fluid can evaporate in the transmission
    when I have done the service I will put back in about 1/2 quart more than I took out
    The Dude[OP] likes this.
