  1. Jul 3, 2025 at 9:55 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Ok ready to start LED project so read through mostly old threads on mini-projectors being preferred vs plug and play. Megathread points to here.
    https://www.tundras.com/threads/best-1st-gen-headlight-solution.122680/#post-3145307
    https://www.tundras.com/threads/colight-mini-projector-lifespan.132133/#post-3359853
    Didn't find Braveway @shifty` used from the rainforest so is the co-light Y6 still the min-projector to use?
    https://www.led-colight.com/products/y6-mini-projector-6000k-led-headlight-blub-h4-9003-hb2
    Are these the plug and play kind of bulbs that don't need the projector mod?
    https://www.amazon.com/MIFMIA-H4-Brighter-9003-Waterproof/dp/B0FBJWS8PP
    TIA.
  2. Jul 4, 2025 at 4:56 AM
  3. Jul 4, 2025 at 6:13 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I've done it a handful of times. I typically soak it with non diluted simple green then get as much off with the pressure washer. Rubberized undercoatings suck. Get bed liner in a can or a satin black paint for best results.
  4. Jul 4, 2025 at 6:37 AM
    Whatever rubberized undercoating they used is awesome. I have gotten a single bit of rust underneath the wheel wells as a result in all the harsh salt laden winters I’ve driven through. Although I do religiously wash my undercarriage when it gets above freezing.
    Any orher pickup I run into around here from the early 2000s usually has rusted out panels around the wheel wells.
  5. Jul 4, 2025 at 7:23 AM
    Yup. Haven't seen this video in his channel yet, but the ratchet failures I was referencing get tested at the 12m04 mark. I make a point of never using ratchet wrenches to break fasteners free, it's served me (and my wallet) well.
    Those Olsa look like a pretty good bang vs. buck ultra-budget buy, I'd trust just about anything made in Taiwan, like the Tekton. I use plenty of Tekton tools. I currently have a mix of Mountain and Gearwrench ratcheting wrenches.
    Guy has a really awesome channel, one of my faves.
    des2mtn[QUOTED] likes this.
