Let's see 1st gen with Toyota Rims
Discussion in '1st Gen Tundras (2000-2006)' started by Lupe, Feb 19, 2019.
  1. May 11, 2025 at 6:47 PM
    #1171
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    No shade, because I have the same wheels, but I like the old starfish on your rig. .02
  2. May 11, 2025 at 7:17 PM
    #1172
    Kalannar97
    Kalannar97 New Member
    Michael
    Hillsboro, TN
    2003 Red Tundra SR5 2wd AC V-8 LSD ABS
    New Frame (Recall in 2019), added 17" 4-Runner Snowflake Rims
    I have one of those rims as my spare. Got it with a brand new tire from an FJ for $100. My coworker has those on his Tacoma and is thinking about getting something different. But I have the 17" snowflakes all around on mine. I may see if he'll swap with me if he does decide and then he can sell mine.
  3. May 11, 2025 at 10:46 PM
    #1173
    BoiseG
    BoiseG New Member
    2001 Black SR5 4x4
    A nice little detail about those wheels is they protect the valve stem.
    Kalannar97[QUOTED] likes this.
  4. May 12, 2025 at 3:13 PM
    #1174
    Dustdog
    Dustdog New Member
    01, 05 AC 4wd
    stockers
    My wifes truck...not sure what the rims came off
  5. May 12, 2025 at 3:35 PM
    #1175
    Those are OEM, IIRC. 16x7
    G_unit3000 and KNABORES like this.
  6. Jul 3, 2025 at 6:13 PM
    #1176
    Lucky2
    Lucky2 New Member
    2006 4x4 DC SR5 Tundra 194k
    Okay I've been researching old posts for about an hour and have read the megathread, so please don't shoot me. But is there a list somewhere of what wheels are perfect plug and play without having to use spacers or adapters. I have a 2006 DC on bilstein 4600's (so stock). I'll probably go 17 inches to avoid the potential of any caliper rub? Just trying to get a list of wheels to keep an eye out for on marketplace. What I think I want is a 17 inch wheel, 106.1mm bore, 4.5 backspacing, and of course 6x139.7 bolt pattern. Thanks for any help.
  7. Jul 3, 2025 at 6:44 PM
    #1177
    I don’t think you’d find such a list. Mostly because tire size and aggressiveness variation is too wild of a variable to publish that, and someone would make the mistake of putting a really wide tire on, rubbing, and get pissed it don’t fit. Or put on some super aggressive mud terrain (M/T) and rub, and again, get pissed because it worked for the guy using regular road tires in OEM size.
    You really just need to do your homework, and I’m not saying that with snark or condescension. Know what the backspace and width of the wheels you’re looking at are, know what tire you intend to use, and ballpark the math.
  8. Jul 3, 2025 at 6:46 PM
    #1178
    Lucky2
    Lucky2 New Member
    Ah okay, thanks for the reply. I was hoping to get lucky. Going to set aside a few more hours for research and try to compile myself a list of ones to keep an eye out for.
  9. Jul 3, 2025 at 6:50 PM
    #1179
    Mild edit made to my reply in the time between my post and your reply, to clarify some stuff.
    When I’ve needed to figure this out before for others (something I’m not fond of doing), I’ve gone online to find specs on the OEM wheel they’re looking at. Best bet is to find something with backspace in the 4.5 - 4.8 range. That will push things out far enough to have some flexibility on tires. But knowing your tire specs (actual diameter and width from the manuf’er, not what a tire calculator says) is ideal. Understand that, if you intend to go with an aggressive A/T tire, the actual diameter and width may be 1/4” - 1/3” wider/taller than what a calculator will show, and those knobbies really love grabbing things in the fender and also rubbing frame.
    Lucky2[QUOTED] and CC80guy like this.
  10. Jul 3, 2025 at 6:53 PM
    #1180
    PS - if you need help calculating, give:
    • Wheel you intend to use OR its width and offset specs
    • Exact model and size of tire you intend to use
    That should be adequate to run the numbers. The hard part is finding the width and offset of the OEM wheel, but there are a few websites that sell OEM wheels and gives you those specs.
    Lucky2 likes this.
  11. Jul 3, 2025 at 7:07 PM
    #1181
    Lucky2
    Lucky2 New Member
    I’m hoping to find wheels with tires already mounted. I’ll make sure to take it account if the tire looks agressive. Hopefully the person will be cool and let me test fit them.
