  1. Jul 1, 2025 at 8:23 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Typical for first differential service
    MikroT[QUOTED] likes this.
  2. Jul 1, 2025 at 10:46 PM
    Retroboy1989
    Northern Utah
    100% machining debris, or swarf. I wouldn't sweat it unless you are getting noise.
    Hoping none of that is hiding in my engine waiting for to ruin some future day.
    Huckwheat likes this.
  3. Jul 2, 2025 at 7:08 AM
    mikev25
    mikev25 New Member
    Kansas
    2022 MGM SR5
    TRD lift, wheels, tires, AlphaRex headlights
    @BlackNBlu is correct! And if you were asking about headlights, yes, AlphaRex Nova in alpha black.
  4. Jul 2, 2025 at 8:09 AM
    24LTD
    24LTD New Member
    I ordered TRD Pro shift knob with 20% off July 4th deal plus free shipping. Just in case anyone looking for one
    astrength22 likes this.
  5. Jul 2, 2025 at 8:55 AM
    Twin2turbo
    Twin2turbo New Member
    Pacific NW
    2023 Hybrid MGM Platinum
    That looks exactly like what I found when I changed my rear diff oil.
  6. Jul 2, 2025 at 11:39 AM
    sandiegosteve
    sandiegosteve New Member
    San Diego
    24 Limited TDR Lunar Rock
    I decided to add some 12v DC infrastructure. Still don't have a plan for lights, but I think this will help keep things clean when I do.
    First was a dual "charge/compressor" option without opening hood. Viair sells an SAE 12awg pigtail option, so I decided to add an SAE flush mount port for it that will also allow me to attach a trickle charger. I found a 10awg SAE that I was able to hide in my front license place holder. I secured the wires along side the other grill wires to it will easily come off when I start tinkering with the hidden light bars. I debated a PowerPole 50Amp, but that was big and too hard to hide.
    That runs up to a powerpole 50 by the other grill disconnects so I can easily disconnect as well.
    Added a ground bus bar for future organization. I just attached it to the plastic trim with some abs scraps for backing from my amp rack. Wired to battery with #4awg.
    Made a mounting board out of 1/4" ABS screwed to battery bracket with a switch and fuse block. #4 AWG off a 100Amp MRBF -> Switch -> MIDI fuse block. A 40Amp for compressor/trickle SAE, a 40Amp to bed on #6awg and a 60a to my amplifier and sub (Kicker Key 400.1 and the 10" powered sub both stashed behind back seat).
    Won't all run at the same time, and even if they do, current loads are well below. If/when I add a switch pod, I'll probably just do a double MRBF. I grew up on boats an like to keep connections simple with 1-2 max connections. I'll probably get a higher capacity battery at that point too... I do wonder if the fuse block is too close to the battery negative. I can easily redo another ABS board in the future.
    Run to the back is for... future considerations. I did add a BlueSea which is on its own 15Amp fuse for basics USB and 12V. I have the cheap bed power that I can run to charge my BougeRV battery just fine. So far the BougeRV battery on the 30qt fridge will run for 12+ hours no problem, but air temp rarely gets over 70 here. I ran the power like the RealTruck youtube video. Mounted a positive and negative bus bar to one of the composite fins in the hollow space next to bed. BlueSea fused to that. Anything in the future I would fuse off that as well.
    So far, I really like the trickle charger results. I just hope someone doesn't forget to look before they drive away with it plugged in. I park nose in on my driveway and there is power right there. Easy.
    The 5Amp charger can also charge my BougeRV power bank if I want. Now I feel like I am set if I want to add more things. Room on fuse box if I want to do a switch pod in the future.
  7. Jul 2, 2025 at 12:07 PM
    g4waldo
    g4waldo Professional Looking CSM Owner
    2023 Celestial Silver Metallic Tundra Platinum 4x4
    Tim "The Tool Man" Taylor would be proud.
    sandiegosteve[QUOTED] likes this.
  8. Jul 2, 2025 at 12:43 PM
    cvkhuong
    cvkhuong New Member
    May not be much, but finally got new tires after my old OEM duelers wore out. Happy with the purchase so far.
  9. Jul 2, 2025 at 4:03 PM
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    I honestly dont understand how that is acceptable debris. They pull parts from molds, cncs, however they are fabricated and dont clean them up prior to install in any sense. Looks like cutting corners to me.
    Not barking at you, just dont see that as something that should be the norm.
  10. Jul 2, 2025 at 4:12 PM
    MikroT
    MikroT New Member
    Dom
    2024 Tundra Hybrid
    That's the thing - it's not acceptable. It's become the norm for large producers to cut corners - accountability has to happen sometime.
  11. Jul 2, 2025 at 4:15 PM
    eddiefromcali
    Eddie
    100% Stock
    I dont think its acceptable either...just typical. Those pieces of metal have no business being in there before assembly, 100%. Dont think I've heard of that causing any issues, so it might be a moot point but still.
  12. Jul 2, 2025 at 6:13 PM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    I'm really liking the DIY 12V power distribution you have there. I'm doing something similar and will be incorporating several of your ideas. :thumbsup:
  13. Jul 3, 2025 at 9:12 AM
    Rockytrdpro
    Rockytrdpro New Member
    Rocky
    2020 black tundra trd pro
    i want one also, but how do you feel about the overhang on the sides? is it too much ?
  14. Jul 3, 2025 at 3:58 PM
    Daedalus
    Daedalus New Member
    Expected the Dominator D6s.
    Got the DSSs instead. (Scratch and dent sale).
    Can’t say I’m disappointed
    hudrock likes this.
  15. Jul 3, 2025 at 4:56 PM
    hudrock
    hudrock New Members only jacket
    So Cal
    25 MGM Limited
    Looks nice…care to share a few more pics, I like those
  16. Jul 3, 2025 at 5:01 PM
    Daedalus
    Daedalus New Member
    Here’s some more. I don’t have any from distance yet.
    hudrock likes this.
  17. Jul 3, 2025 at 5:29 PM
    hudrock
    So Cal
    25 MGM Limited
    Nice thanks…I like how low pro they are - enough for a step into the truck? I’m 6’5” so don’t really need a step but wife does
  18. Jul 3, 2025 at 5:38 PM
    Daedalus
    Daedalus New Member
    They are pretty low profile.
    You can get the ball of your foot in there and side of your foot if you choose to do it that way.
    hudrock[QUOTED] likes this.
  19. Jul 3, 2025 at 8:27 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    If anyone is wondering. If you spill coffee on your drive mode selector the part is 480 plus tax. If you want to go the much harder route I can save you time and tell you how to tear it all apart.
  20. Jul 3, 2025 at 8:30 PM
    60centenergy
    60centenergy I'm not superstitious, but I am a little stitious
    Zack
    GVL
    2024 Lunar Rock SR5 Tundra TRD Sport
    That sucks! Did you just tear it apart to wipe it down then let it all dry? Still work?
  21. Jul 3, 2025 at 8:37 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    The top two buttons would stick when you press them and it was getting annoying. Toyota told me today the assembly isn’t designed to come apart and if have to replace it. While it was difficult it’s not impossible. The main issue I’m having is figuring out how to clean it out. Tried an ultrasound cleaner and no luck. Some of the cavities are too small for a qtip so I’m not sure what to try next.
  22. Jul 3, 2025 at 9:31 PM
    6rian
    6rian New Member
    warm water, dish soap, and a soft long bristle brush. Easy and done. It's just coffee. lol
