  1. Jul 2, 2025 at 3:58 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Nice!!
    woods and Tripleconpanna like this.
  2. Jul 2, 2025 at 8:58 AM
    vdubnut
    vdubnut New Member
    No pictures, but did the rear diff fluid change with valvoline 75w-90 synthetic and the t-case with ravenol 75W. rear diff was replaced under warranty at 35k so got new fluid then, and now just approaching 70k. both fluids were fairly dark. the replacement fluids were nearly clear! this was the 1st t-case change. will probably shorten the interval for both seeing the condition of the fluids, as I do a lot of towing. also did a drain and fill on the trans. started doing them annually at 50k with the toyota trans fluid...also darker than i'd like but no weird smells...need to figure out a better way to put the new fluid in. using a extractor syringe for lack of a better term, to pump the new fluid in takes forever and is a messy PITA.
  3. Jul 2, 2025 at 9:21 AM
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    Got the P0418 code and decided to replace both of the SAI pumps, which was a pain to align properly. I then tried to erase the code, but had no luck, the OBD scanner said it was erased, but the light is still on and the code keeps coming back.
    I've been doing some research and decided to check the SAI relay, but I can't seem to access it or figure out how to replace it. There doesn’t appear to be any standard access, and I can't see inside to determine if anything is shorted. The fuse box lid indicates there are four relays or fuses on that line, but I can’t seem to see or access them to test.
    Any help on how to remove the A/PUMP NO. 2 50A fuse or relay would be greatly appreciated.
    PXL_20250702_161037437.jpg PXL_20250702_154027901.jpg PXL_20250702_154009065.jpg PXL_20250702_154035826.jpg
    Corndog123 and bulldog93 like this.
  4. Jul 2, 2025 at 9:27 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Much better way from up top from the engine bay with qt bottle fill tube and 5/8 ID hose from Home Depot. Poke a vent hole in the bottom of the transmission fluid bottle.Screenshot_20250323-083541.png
    Tool Demo Guy has a good YouTube video on the process
    https://youtube.com/shorts/huk5fPAw84c?si=caW17xxyAhOud_t4
    Henry1jg, PKFan, TreeCat and 2 others like this.
  5. Jul 2, 2025 at 10:05 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    Looks awesome. When you start to think about it, a flat bed make way more sense than a standard bed..
    woods likes this.
  6. Jul 2, 2025 at 10:09 AM
    vdubnut
    vdubnut New Member
    thanks, i'll give this a go next time. that looks much better.
    BR73 likes this.
  7. Jul 2, 2025 at 11:34 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
  8. Jul 2, 2025 at 12:52 PM
    Leedaar
    Leedaar New Member
    2016 Tundra CM
    Oil change, 8qts out, 7.5qts in.
  9. Jul 2, 2025 at 1:23 PM
    Rick52Chevy
    Rick52Chevy New Member
    Rick
    2020 Quicksand SR5
    Leveling kit. 33X12.5X20 Klever RT with 20X10 Fuel wheels Ceramic Tinted windows
    Finally made the grab handle upgrade. My wife loves it and I am finding that I am using it!
    The start: 20250607_152230.jpg
    ATV25, coldcanuk, rdiddy5 and 13 others like this.
  10. Jul 2, 2025 at 2:33 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    New wheels! Discount Tire damaged my last set and paid for a replacement set so I got a different color.
    Corndog123, caboj, Yota303 and 7 others like this.
  11. Jul 2, 2025 at 9:46 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Oil change, tire rotation, yadda yadda today.
    Also finally got the last ABS sensor guard installed - while I had the wheel off I had to dremel a slot on the original stripped out bolt head.
    Then got the Yakima HD rails mounted on my TC USA cover in place of the older standard rails. Now I can get the rack for hauling stuff…
  12. Jul 2, 2025 at 10:10 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    What tie rods are those?
  13. Jul 2, 2025 at 10:25 PM
    RobertD
    Robert
    DFW, Texas
  14. Jul 2, 2025 at 11:28 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    RobertD[QUOTED] and RainMan_PNW like this.
  15. Jul 3, 2025 at 3:33 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    I was scrolling through your build and saw those G-Tek door sill protectors and sadly found out they are no longer made.....dang the luck :(
  16. Jul 3, 2025 at 4:32 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    Coachbuilder
    bulldog93 likes this.
  17. Jul 3, 2025 at 4:48 AM
    TundyManFL
    TundyManFL New Member
    2021 MGM TRD Pro CrewMax
    Just looked through your thread but couldn't find (or I'm blind) where you swapped for the TC USA Work Cover Jr.
    How do you like it?
  18. Jul 3, 2025 at 5:51 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Yeah - which is too bad because they are well built.
    BR73[QUOTED] likes this.
  19. Jul 3, 2025 at 5:57 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Shoot - looks like I missed getting that in my build thread…I have a few things to get added but been super busy lately.
    I just ordered the tool box from them that replaced the lid for the canister - takes a standard cover and makes it a “work cover junior”
    They take the serial number and make sure the locks are keyed the same at the cover itself, which was nice.
    I’m still reconfiguring what I store where (between this box and the ESP under the rear seat), but overall I really like it. It’s built solid and is enough room to hold commonly used/accessed stuff that is someone’s a pain under the rear seat to access.
  20. Jul 3, 2025 at 7:24 AM
    TundyManFL
    Do you find the loss of visibility through back window/rear view mirror noticeable at all?
  21. Jul 3, 2025 at 9:30 AM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    Oil change, and swapped over to a metal oil filter housing. Only spilled a couple of drops in the driveway.
  22. Jul 3, 2025 at 11:53 AM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    Can you hear or feel the pumps come on with your hand under your fender well? It might be the SAI “valves” and not the pumps causing the problem if you can confirm the pumps have power to them and are functioning properly. Found this video that might have some helpful information.
    https://youtu.be/2KGoxyarJFQ
  23. Jul 3, 2025 at 12:01 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Blacked out set arrived. I’ll just use the left panel or just the button i need
  24. Jul 3, 2025 at 12:03 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    I ended up pulling the trigger on it, too. If you take it apart, the volume button pops out easily from the backside w/ a couple small screwdrivers. Expensive button!
  25. Jul 3, 2025 at 12:07 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yea I took it apart. You could also run the left grouping just unplug the harness and use the old harness but the blacks may be slightly different to like the Ajt but not sure since my trucks not here.
  26. Jul 3, 2025 at 12:18 PM
    Uhhhh....
    Dave
    Virginia
    7” BDS, 37s
    Good point. Yeah that's why I just used the button...wasn't sure the new left side would match an SEM-trim-painted right side very well...so I just popped the button off & used SEM for both sides.
    bulldog93 and reywcms[QUOTED] like this.
  27. Jul 3, 2025 at 1:03 PM
    NWPirate
    Zach
    WA
    I like it.
    What's the part #'s?
    Also, is anyone still making the Toyota steering wheel overlay?
    bulldog93 and BR73 like this.
  28. Jul 3, 2025 at 1:04 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    84250-04040-CO
    HulkSmurf14 and NWPirate[QUOTED] like this.
  29. Jul 3, 2025 at 1:08 PM
    Uhhhh....
    Dave
    Virginia
    7” BDS, 37s
    TRDFerguson and NWPirate[QUOTED] like this.
  30. Jul 3, 2025 at 1:10 PM
    NWPirate
    Zach
    WA
