AI search warns of 2nd gen Tundra's to approach with caution!
Discussion in '2nd Gen Tundras (2007-2013)' started by Donyms, Jul 2, 2025 at 1:32 PM.
  1. Jul 2, 2025 at 1:32 PM
    Donyms
    Donyms [OP] New Member
    Don
    I was searching for the best 2nd Gen Tundra's to buy used and found this. This may not be news to many of you but as someone who is just learning about Tundra's, I would love to get your input, thoughts and your experience.
    Years to Approach with Caution:
    • 2007, 2008, 2010, and 2012: These early models had a higher rate of problems, including air injection pump failure and camshaft issues.
  2. Jul 2, 2025 at 2:39 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I have an 07, bought since new. 315k on 5.7L 2wd. Only problem I've encountered is 1 radiator ( my doing ), 1 starter, hella batteries, 2 blown water pumps 1 under warranty. Have a current electrical gremlin to identify but runs good.
    My advise, find one change all fluids and it should be dependable for a while. Worst case move up to the 2.5 gen same guts updated interior.
  3. Jul 2, 2025 at 2:47 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Any truck from those years that's still around do not have inherent issues with those parts or it would've shown up by now. Mine has 305k, starter went out at 215k, radiator went out at like 250k, anything else was self inflicted. You'd be hard pressed to find a more reliable vehicle in my opinion.
  4. Jul 2, 2025 at 3:12 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
  5. Jul 2, 2025 at 6:26 PM
    Donyms
    Don
    I just ran across one today that had 155,000 miles. It looks really good and is a 2015. The only problem is I prefer the double cab instead of the crew cab. Is the 2015 Gen 2.5?
  6. Jul 2, 2025 at 6:28 PM
    Donyms
    Don
    Good to hear. There are a lot of these that are nice and priced right. What milage should I be looking for? I'm looking now for under 150,000 miles.
  7. Jul 2, 2025 at 7:18 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes. 2014-2021
  8. Jul 2, 2025 at 7:23 PM
    centex
    centex New Member
    AI is right. 2014-2021 is best. And my opinion is totally unbiased and you can take that to the bank.
    Donyms[QUOTED][OP] and j_supra like this.
  9. Jul 2, 2025 at 7:27 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    100%
  10. Jul 2, 2025 at 7:29 PM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub, Rokblokz XL, AVS visors
    Mileage is almost irrelevant depending on maintenance. Within reason. I'd rather a truck with 200k miles with perfect service records done on time, over a 100k mile truck that hasn't had a single fluid changed. These trucks go a LONG time even with just half decent maintenance.
    Never heard of camshaft issues. Air injection system is a common problem but there's ways to bypass it if it becomes an issue. I wouldn't let that sway me away.
    Donyms[QUOTED][OP] and snivilous like this.
  11. Jul 2, 2025 at 7:32 PM
    koditten
    Kirk
    Midland of the Mitten
    Any 18 year old vehicle is gonna be having issues.
    I still drive my '08 with 250k miles with no fear.
    I've changed bearings, starters, radiators, alternator and still think it's a very reliable vehicle.
    I grabbed a '21 just I would get another 15 years out of a very reliable vehicle.
  12. Jul 2, 2025 at 7:33 PM
    82nd Airborne
    82nd Airborne New Member
    2012 SR5 DC
    Whatever :rolleyes:
    Donyms[OP], M14 EBR and blackdemon_tt like this.
  13. Jul 2, 2025 at 7:44 PM
    yakeng
    yakeng 3URFE Apologist
    Hey guys, I asked AI what the best Tundra is and it said this:
    The best Tundra is the Platinum 2020 Crew Max. Super White is the fastest color.
    Sorry to everyone who doesn’t have that.
  14. Jul 2, 2025 at 7:57 PM
    centex
    centex New Member
    Science denier.
  15. Jul 2, 2025 at 8:43 PM
    It has been long proven that Super White is the fastest Tundra. Hell, it rips off the line so fast the paint peels off.
  16. Jul 2, 2025 at 8:47 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    AI is like a drunk getting info from back of a beer bottle and box of fruit loops
  17. Jul 2, 2025 at 9:20 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    For the love of God, will someone please explain to people that AI is nothing more than a series of algorithms and searches of an already flawed internet database... :facepalm:
    The same folks that influence how search results pop up in google, etc. are influencing what AI is generating...
    Enough already... :smash::smash::smash:
    BTW... My 2008 Tundra. I've owned it since it was new. I've towed w/it for years. I've not babied it, but it has been reasonably maintained. It's still running and approaching 300k. Clearly, it needs to spend more time on the internet and realize it should be sitting in a junkyard rotting away at this point...
  18. Jul 2, 2025 at 9:22 PM
    It puts the lotion on the skin……
  19. Jul 2, 2025 at 9:24 PM
    Tripleconpanna
    Sorry, my bad... :anonymous:
  20. Jul 2, 2025 at 9:48 PM
    Aerindel
    Aerindel New Member
    Montana
    We come to forums like these, specifically to get away from AI.
  21. Jul 3, 2025 at 5:02 AM
    I don’t understand any of it. He was a good, albeit lazy, basketball player on a mediocre team. Why does that make everyone think he’s so smart? Because his nickname was “the answer”?
  22. Jul 3, 2025 at 7:56 AM
    bicklebok
    bicklebok New Member
    Ronnie
    I have a 2010 with 140,000 miles. Only issue I have ever had was the steering angle sensor going bad.
    koditten likes this.
  23. Jul 3, 2025 at 8:41 AM
    EmergencyMaximum
    I had secondary sir injection pumps fail and get replaced under recall.
    3010 tundra 4.6l v8
    Truck drove better than new after repair, which makes me wonder if they were faulty from factory.
