TRD Exhaust actually add HP and Torque?
Discussion in 'Performance and Tuning' started by TRDSport888, Jul 2, 2025 at 10:59 AM.
  1. Jul 2, 2025 at 10:59 AM
    TRDSport888
    TRDSport888 [OP] New Member
    Ivan
    Tint
  2. Jul 2, 2025 at 11:15 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Interesting ... at least the system was dyno'd to prove some gains. Plus the dual side exit looks sick AF :thumbsup:
  3. Jul 2, 2025 at 11:20 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Not surprising, the oem muffler blows
    Mdl likes this.
  4. Jul 2, 2025 at 12:24 PM
    M14 EBR
    M14 EBR Oh No, Rex Kramer!
    I would add an H pipe to the TRD exhaust, and I would only consider adding an X pipe only if I was running higher RPMs more often than not.
    BlueRibbon4x4 and MALIBU1794DC like this.
  5. Jul 2, 2025 at 12:56 PM
    MALIBU1794DC
    MALIBU1794DC Like a Japanese Texas built Rock
    2019 Double cab 1794
  6. Jul 2, 2025 at 1:02 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    You absolutely lose low end torque with the TRD exhaust. So much that you can feel it. I did the “upgrade” a couple years ago and immediately regretted it. The only plus was the sound.
    I recently changed it out for a Dirty Deeds system. They 100% live up to the hype.
    M14 EBR likes this.
  7. Jul 2, 2025 at 2:14 PM
    M14 EBR
    Dirty Deeds is the best.
    BlueRibbon4x4[QUOTED] likes this.
  8. Jul 2, 2025 at 4:02 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Love it or hate it there is nothing with as deep and bassy of a tone as the TRD duals. I’ve tried other things but always come back to it. Removing a set of the rear cats takes the great sound and makes it louder and more aggressive. I tried the DD TRD rep system with the x pipe and noticed a loss of low end torque. I went back to the TRD with true duals. I could see trying an H pipe on it in the future, but I think the true divorced duals are what gives it the unique sound.
    TRDSport888[OP] likes this.
  9. Jul 2, 2025 at 4:13 PM
    TRDSport888
    Ivan
    Tint
    I've heard this on the forum but the dyno numbers don't really show a loss of low end torque. So not too sure if it's made up or I'm the one who doesn't understand. Either way I just thought it was interesting you actually gain torque and HP, I always thought it was just for sound and no gains.
  10. Jul 2, 2025 at 4:14 PM
    TRDSport888
    Ivan
    Tint
    I do love that deep sound it's like no other.
  11. Jul 2, 2025 at 5:15 PM
    MALIBU1794DC
    I read when toyota developed it , they had 30 iterations, settled on this one. I've heard most manufacturers do a few iterations and a choose one.
    Shows toyota tests and tests stuff to get it as close to right.
    I have a trd exhaust, haven't installed it. Expecting a little less torque off idle and then a little bit more power at revs.
    If you tow a lot, it could be annoying to lose a little torque.
    I think the loss of torque is under 2k rpm. And then it settles to feel fine.
    Variable valve timing works with load and back pressure. Taking some back pressure away, doesn't let the motor make max torque at low revs.
