Front end
Discussion in '2nd Gen Tundras (2007-2013)' started by MEWaters, Jul 2, 2025.
  1. Jul 2, 2025 at 11:10 AM
    MEWaters
    MEWaters [OP] New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    Front end being redone. 07 with 220k.
    eibach 2” level in front
    JBA UCA
    Oem bar links
    My question is in regards to the tie rods. Am I better off to buy the entire rod end subassembly vs just tie rod ends? subassembly is cheaper than the end. New joint, etc. I’m assuming that’s what I would want
    I tried talking to a parts dept to break down the difference between the two and they were trying to tell me tie rods have no joints and the lca is the only joint and tie rod only has a castle nut and cotter pin
  2. Jul 2, 2025 at 12:36 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    yea just get the whole new end. 45047-09260, should be around $80. it's just a metal bar with a ball joint on the end. coachbuilder makes heavy duty ones if you want to spend three times the price.
  3. Jul 2, 2025 at 12:39 PM
    MEWaters
    Maine
    So what would be in the sub assembly 45046-29195 vs just the end?
  4. Jul 2, 2025 at 12:41 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    MEWaters[OP] likes this.
  5. Jul 2, 2025 at 4:30 PM
    MEWaters
    Maine
    Both Bar links and rod ends $300 shipped with the 4th sale
