2014 Tundra Died While Driving and Now Won't Start
Discussion in '2.5 Gen Tundras (2014-2021)' started by IMXPLRN, Jun 25, 2025.
  1. Jun 25, 2025 at 1:57 PM
    IMXPLRN
    IMXPLRN [OP] New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    My friend was driving his 2014 Tundra DC to work this morning and out of nowhere it started shaking and then stalled/died. He had to coast it to a safe spot to pull over. The truck has 230k miles on it and is regularly maintained. He had it towed to where we work and I was able to get a video of it cranking and trying to start. It's very noisy. We hooked a scan tool up to it and no codes. Any ideas of what could be going on with it?
    https://www.youtube.com/watch?v=Eeo4SSXJvbs
  2. Jun 25, 2025 at 2:47 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Is that Rod knocking?? Inspect all cylinders for coolant/head gasket failure. Most likely cyl 7 or 8 where most common failures occur.
    Edit: I'm no mechanic though, so its just my 2 cents.
  3. Jun 25, 2025 at 2:52 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    She done, sound like a dropped/cracked valve. With the back firing out of the intake I would guess its a valve issue or a skipped timing chain.
  4. Jun 25, 2025 at 2:59 PM
    Mr Badwrench
    Mr Badwrench New Member
    Sounds like low compression and then there's the rattling when it kicks off. Valve train for sure. 230,000 miles isn't too bad.
  5. Jun 25, 2025 at 3:06 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    That’s a weird sound. I have no idea what it could be, but please post if you ever get a diagnosis.
  6. Jun 25, 2025 at 3:11 PM
    Retired...finally
    Sounds like a V7.
  7. Jun 25, 2025 at 5:22 PM
    IMXPLRN
    Rescue, CA
    This is all kind of what I was thinking myself. Something definitely went bad in the top end.
    I should mention as well, he has to pump the gas pedal to even get it to do what it's doing.
  8. Jun 26, 2025 at 7:58 AM
    equin
    Ed
    DFW, TX
    Fuel injectors?
  9. Jun 26, 2025 at 8:04 AM
    Likely dropped a valve based on the most common failures reported here. Broken valve spring will cause the valve to fall down into the cylinder. Other potentials are timing chain issues due to failed tensioner. The hard start seems worse than single dropped valve honestly.
  10. Jun 26, 2025 at 11:06 PM
    Mend0k
    Mend0k New Member
    2015 TRD Pro
    Damn that sucks :(. Guess these engines aren’t bulletproof after all
  11. Jun 27, 2025 at 8:43 AM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    He got 230K out of it!!
    Thats not bad at all!!
    ZappBrannigan and Mr Badwrench like this.
  12. Jun 27, 2025 at 12:36 PM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    I cant say I've ever gotten that many miles out of a Truck!!!
    Of course I usually trade em in at 60K when you can still get something out of them.
    As I get older about the only thing that excites me is getting a new Truck!!
    .......or maybe a new boat or rifle.
    So the excitement has veringly different levels of excitement based on money spent....or speed and accuracy.
  13. Jun 27, 2025 at 1:15 PM
    IMXPLRN
    Rescue, CA
    Official diagnosis is a dropped valve. Engine is done.
  14. Jun 27, 2025 at 3:02 PM
    Ericsopa
    Ericsopa Old man and the sea
    I wouldn't call that good. Last truck I had was wiped out by hurricane Harvey in '17, with 245K and still going strong. Present '13 Crewmax has 236K, and I'm expecting at least that much more.
    equin likes this.
  15. Jun 27, 2025 at 3:16 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Sorry to hear that bud.
    Tripleconpanna likes this.
  16. Jun 27, 2025 at 3:27 PM
    Jckdanls07
    Jckdanls07 We May Not Know Them All, BUT, We Owe Them All !!
    Keith
    Tampa Area
    2015 White Tundra SR5
    Coworker has an 02 with over 500,000 miles and still going strong with ice cold air...
  17. Jun 27, 2025 at 3:47 PM
    Mr Badwrench
    I'll be entirely satisfied if I get 230,000 trouble-free miles on my 5.7.
    MALIBU1794DC and ZappBrannigan like this.
  18. Jun 28, 2025 at 12:52 AM
    4.7L2UZFEbestengine
    4.7L2UZFEbestengine New Member
    2021 Tundra SR5 SX Doublecab
    You can’t beat the old 2UZ engines for rock solid reliability. Million miles and beyond with proper maintenance.
    As great as the 5.7L is, it definitely needs a stricter maintenance schedule especially coolant changes every 60k miles. And for my peace of mind, 3k mile / 6month oil changes.
  19. Jun 28, 2025 at 3:26 AM
    red61cj5
    red61cj5 New Member
    wv
    2017 Limited DC Inferno
    Just curious, what's the going rate for a good used 5.7?
    equin likes this.
  20. Jun 30, 2025 at 7:59 AM
    equin
    Ed
    DFW, TX
    Bummer. You thinking of replacing it with a used 5.7?
  21. Jul 1, 2025 at 6:47 AM
    IMXPLRN
    Rescue, CA
    He's been looking at his options on where to go with this. For whatever reason Toyota spent the time to work up a quote to rebuild the engine, which came to $38k. LOL. Why would they even waste the time doing that on a truck that bluebooks for $14k.
    He's going back and forth on putting a used engine back in it and either just keeping it or selling it or just cutting his losses and part it out and get something newer.
    equin[QUOTED] likes this.
  22. Jul 1, 2025 at 7:00 AM
    The money spent on a used engine will be worth it to save the truck if the rest of the truck is in great shape.
    JMGmanAZ likes this.
  23. Jul 1, 2025 at 5:34 PM
    MALIBU1794DC
    MALIBU1794DC Like a Japanese Texas built Rock
    2019 Double cab 1794
    I got 220k+ from new on a 07 5.7
    Ran the same from new till I sold.
    Never broke down either. 100% reliable
  24. Jul 1, 2025 at 6:52 PM
    Bham TRD
    Bham TRD New Member
    2017 Tundra Platinum 4WD CrewMax
    $38k!!!!!!!!!
    What in the holy hell?
  25. Jul 1, 2025 at 6:58 PM
    Sarcastic Zword
    Sarcastic Zword What’s old is new again.
    Al
    U.S.A.
    2015 Tundra 5.7
    The dealership should be ashamed of themselves. Just tell the customer you don’t want to be bothered.
    Tripleconpanna and ZappBrannigan like this.
  26. Jul 1, 2025 at 7:02 PM
    Dukhnt
    Dukhnt New Member
    Look at the bright side. People would line up to buy the drivers side grab handle.
    MALIBU1794DC, equin and ZappBrannigan like this.
  27. Jul 1, 2025 at 7:10 PM
    and transmission cooler plumbing
    ZappBrannigan likes this.
  28. Jul 1, 2025 at 11:03 PM
    AZBoatHauler
    So.Arizona
  29. Jul 14, 2025 at 12:24 PM
    IMXPLRN
    Rescue, CA
    Update:
    Valve steam was in the intake, injectors got smacked and were leaking. The rest of the valve is bouncing around in the cylinder. He is not going to tear it down any further. He is having a used engine put in and will call it good.
    HulkSmurf14 and equin like this.
  30. Jul 14, 2025 at 12:46 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Well that’s not awesome. Sorry to hear that.
